01-10-2019, 09:31 AM
Real Name: Emory
Real Name: Emory
Rear spoiler backup camera mounts?
So after almost 14 years of listening to my stock head unit, I've finally replaced it with a Pioneer MVH-2400NEX (and love it, can't imagine why I waited so long). With the nice display, I've become intrigued with the idea of a backup camera and have been doing some research. I like the idea of mounting the camera in my rear spoiler for a couple of reasons ... first, I think it would look cleaner, less obtrusive, and second, I intend to install a rear bumper with a swing out tire carrier at some point in the future and believe that a spoiler mounted camera would give me a more unobstructed view.
I have a couple of questions though ... - Am I correct that a swing out tire carrier would obstruct a more traditional mount?
- And any recommendations for lip mount cameras for the rear spoiler?
I've seen a couple of write-ups that are several years old, and seen several other folks indicate they were interested in doing the same. Just wondering what folks experience has been with spoiler mounted cameras ...
2006 4Runner Sport Edition V6 4WD - Shadow Mica
2005 4Runner SR5 V6 - Titanium Metallic
2004 Sequoia SR5 V8 4WD - Natural White w/ Silver Sky Metallic cladding
2002 4Runner SR5 Sport V6 4WD - Black
Yes, I still own all four ...
01-10-2019, 09:38 AM
I had my amazon Esky rear camera (one of those $20 license plate mounted ones) 3m taped to the underside of the spoiler for about a year. Went thru 2 of em due to build quality (water and ice got in). I liked the camera view from up top. Definitely gave me a wider, usable angle and saw the hitch for the times I needed to hook up the trailer.
This past winter, I moved the replacement camera inside behind the hatch glass. Just bolted it up on the headliner. Camera view is a bit narrower now, but at least I wont have to warranty it every 6 mo's. And the lens isn't coated in salt and dirt, just the hatch glass now.
07 T4R Sport Edition V6 4x4
01-10-2019, 11:49 AM
Real Name: Eric
Real Name: Eric
I just received one of these...
https://www.amazon.com/BRAUTO-Revers...42203430&psc=1
... I haven't had time to install it yet, but I like the factory look.
2007 4.7 Limited - Let the fun begin!
01-10-2019, 11:50 AM
Real Name: Emory
Real Name: Emory
Thanks ... so do you think the salt and dirt issue is due to the spoiler location? Or would it be an issue regardless for any external mounted camera?
01-10-2019, 11:52 AM
Real Name: Emory
Real Name: Emory
Originally Posted by TenTwelve
I like the factory look as well, but I'm pretty sure that a tire carrier would obstruct that location?
01-10-2019, 11:54 AM
Real Name: Eric
Real Name: Eric
Yeah, quite possibly. I'm not familiar with the carriers.
01-10-2019, 01:51 PM
I hate having to wipe the camera lens when covered by dirt or snow so I put my licence plate style inside.
Wiper cleans the window and if need be, I just roll down the window.
01-10-2019, 03:17 PM
My rear hatch and spoiler is always dirtier than the rest of the car. Physics. Low air pressure and the likes. Or I tell myself.
I think its every vehicle. Think its just worse on SUV's and trucks due to the big flat rear ends. My other vehicles, always have to run my thumb over the lens to clean em off before going anywhere.
01-10-2019, 04:36 PM
Real Name: Emory
Real Name: Emory
Interesting ... that's two that have moved their license plate mount inside. I'm assuming that it narrows your field of view some ... how noticeable is it? And do you see reduced low light capability looking out through the tinted rear window?
01-10-2019, 05:09 PM
I compare the view as another "fish eye". You do see less side to side as the body of the vehicle is in frame now. And its not as clear as mounted outside as you now have 1 more lens to filter thru (the rear glass). Night vision isn't the best. But these camera's aren't the best at night anyways. I do have LED reverse pods mounted on the bumper so that helps. (Reminds me, I need to cover up the LED's on the camera for night vision. They just glare and reflect on the rear glass when used).
01-10-2019, 09:43 PM
Nice work on upgrading the head unit. I recently did that with a pioneer and it's a world of difference.
I purchased a camera for this unit as well but I've been waiting until I get a spoiler and install that. I'm not the biggest fan of the lower traditional mounting spot (by the license plate) as objects typically just get larger but you have no distance gauge. My solution was to mount it up high so you get a clearer view of the bumper to object distance.
I think with a rear tire carrier either the traditional spot or spoiler are going to be rendered pretty useless. The tire usually sits up quite high and you definitely won't clear the tire so it will be a pretty obscured view. I have seen some kits that actually mount into the center of your spare tire giving you an unimpeded view backwards. Won't get that high angle look but honestly probably your best solution.
I have been a little concerned with the spoiler mounted camera getting filthy but if I put it inside the vehicle I'll have to roll the window down every time I back up. Plus might not get a view of the actually bumper.
I'll let you know my results when I get around to testing this out.
Whytey's 07 V8 Build Thread
2007 Toyota 4Runner Sport Edition V8, Elka 2.5 Suspension, Total Chaos UCA w/ Delta Uniball, Dobinsins C59-677V Rear Coils, Timbren Bumpstops, Prinsu Design Roof Rack, Baja Designs Squadron Sport Fogs, 285/70R17 BFG KO2, Blacked Out TE Rims, Spidertrax 1.25" Wheel Spacers, Satoshi Grill
01-11-2019, 09:47 AM
Real Name: Emory
Real Name: Emory
Fair point about the tire carrier obstructing the view ... I think it'll obstruct the view, in one way or another, regardless of where I might put camera but was hoping someone might have some direct experience. I'll be interested to hear how your install goes ...
01-11-2019, 09:49 AM
Real Name: Emory
Real Name: Emory
Hmmm ... it's backing up in low light that I'm most interested in, so this might not be the best solution for me.
01-11-2019, 10:21 AM
OMG That's perfect!
I've had a license plate style backup camera for more than a year but never installed it!
I didn't have the time to run the wires thru the hatch.
But this is easier in so many ways.
I may try this!
04-12-2021, 02:18 PM
I have an '06 SR5 with no backup cam & I like the idea of inside the hatch. I have a Garmin backup cam that has a transmitter to the GPS unit up front (no direct wiring). I would like to wire that transmitter into the reverse light wiring at the tail light. Just have to run the wiring down from the top of the rear bay to the tail light and then done.
Does anyone know what colour wires are going into the "harness" (where the tail light bulb is seated) at the tail light? I saw yellow on a Tacoma forum thread, but I think I saw yellow/red here somewhere.
Thanks for the assist.
