Old 01-11-2019, 02:14 PM #1
anonymousgromers's Avatar
anonymousgromers anonymousgromers is offline
Real Name: Brody
anonymousgromers is on a distinguished road
Real Name: Brody
5th gen seats in 4th gen?
Alright so my seats are due to be replaced as the foam is showing in some places and just doesn't look good, so I was thinking would 5th gen seats fit in a 4th gen?
if not has anyone used katzkin or leatherseats.com? as those are the two I'm looking at.
I'm probably going to replace my carpet with one I found on Ebay as well as there are some stains in that that just wont come out.
2004 toyota 4Runner limited 4WD 4.7L V8 | Gibson cat back exhaust
2004 Toyota 4Runner Limited 4.7L V8 | Practically stock | Gibson cat back exhaust
anonymousgromers is offline   Reply With QuoteReply With Quote
Old 01-11-2019, 02:24 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold
Bumbo's Avatar
Thatís a really good questionÖ I would consider doing this if it was a direct drop in.
Old 01-11-2019, 07:31 PM #3
Real Name: Brody
Real Name: Brody
The only thing is I think 5th gen seats would fit but I'm not sure about the wiring such as the airbag and controls for the seat.
if they are the same I believe it should be a direct fit
Old 04-20-2020, 11:16 PM #4
T4R416 T4R416 is offline
T4R416 will become famous soon enough
Resurrecting old thread!!!! Does anyone know of the 5th gen seats would bolt up to the 4th gens? Iíve come across a good deal on a full set of 2012 seats, I have a 2004 can anyone confirm?
T4R416 is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 12:59 AM #5
Anyone? Bump.
Old 04-24-2020, 09:00 AM #6
doofenshmirtz doofenshmirtz is offline
doofenshmirtz has a spectacular aura about doofenshmirtz has a spectacular aura about
Anyone? Bump.
Pretty sure it's NO. I researched the option a year or so ago, and I think the physical seat is too wide, such that the bolsters would rub hard against the center console. Bracket swaps and fabs are pretty common to do a seat swap in general, but the seats have to be roughly the same size. After having sat in a current gen Highlander, if there was a swap for those seats, I would kill for it, lol.
I bought new oem foam for the driver's seat, put seat heaters, and new leather upholstery in my 4runner for Christmas. Out the door was about $1400 with me installing it myself. Foam was $300ish, $100-$150 for seat heaters that also go on the bolsters, and leather was $900ish. I used leatherseats.com and they were awesome all around. Highly recommended.
doofenshmirtz is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 02:52 PM #7
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 will become famous soon enough
I think I did a search for something similar a few years back.. They dont fit right and look weird for minimal gain in comfort was the end result. I ended up purchasing a replacement OEM foam bottom for my seat.. put it in myself.. my thread is somewhere on here.. not hard just slightly time consuming.. Made a HUGE difference. If I was going to replace the covers, id go with Clazzio's.
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 04-26-2020, 07:15 PM #8
Thanks guys !!
Old 04-26-2020, 08:07 PM #9
AZRoamer AZRoamer is offline
AZRoamer is on a distinguished road
Katzkin leather is fantastic from my experience.
I picked up a new set of old stock on eBay, entire leather interior for $300.
Install is a labor of love, takes some time, but even an amateur like myself was able to do it without any issues.
Best upgrade my truck has received hands down.
Just my two cents. Thanks!
AZRoamer is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 07:56 PM #10
Jackkill1's Avatar
Jackkill1 Jackkill1 is offline
Jackkill1 is on a distinguished road
Jackkill1's Avatar
What seat heaters did you install? Thanks.
Jackkill1 is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 08:20 PM #11
joshik joshik is offline
joshik is on a distinguished road
How's the lumbar on the new foam? My lower back always hurts on long drives. I hate those office chair lumbar supports. They are always too bulky.
2003 4Runner Limited 4wd V8. JBA UCA, Bilstein 6112 & 5160. Icon 2" springs. Cooper AT3 275/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 08:19 AM #12
I think it's much better, but keep in mind that it's still the driver's seat of a 4runner. It's only as good as it was from the factory. If that isn't/wasn't good enough, you won't be happy. For me, the first 140k miles on this car were in butts other than my own, so the seat foam was broken in in a way that wasn't quite comfortable for me. The new foam has settled in nicely over the last 3-4k miles. I forgot to plug back in my power lumbar, but it's set just right, so I never mess with it. If you rarely have a front passenger, the foam will be similar to you passenger's seat, just more dense. Kind of like a fresh bread versus stale - that's a weird description, but you'll see.
Old 04-28-2020, 08:31 AM #13
Other than the OEM foam, I used leatherseats.com for everything. Here's their heated seats. I got both front seats and both with the side bolster addons during a Black Friday sale, so I think it was actually a bit over $200. I recalled the price incorrectly I guess. Really nice kits though. Comes with a switch, fuse, and a good relay. High gets really warm, and low is nice and subtle. Compared to my wife's Subaru, they get warm a little slower, but the high setting is hotter than hers. The bolsters are probably not worth the extra cost if you aren't a wide individual.
My only suggestion would be to get their hog rings, but not the hog ring plyers they sell. I was ready to throw them out the window. The seatbacks are near impossible to hog ring, so I ended up using zip ties on some that were being difficult. probably 10-15% were zip tied.
Old 04-28-2020, 08:28 PM #14
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
the lumbar is a jack screw that pushes out the factory foam. So new foam I doubt would have an appreciable difference. I've taken several seats apart from junk yards and have found foam that seemed like new to completely disintegrating seats. But for the most part, the only foam in bad shape was the bottom seat cushion.
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 04-28-2020, 10:05 PM #15
cwilliams563's Avatar
cwilliams563 cwilliams563 is online now
cwilliams563 will become famous soon enough
Iím happy with my Clazzio perforated leather seat covers. They fit well and hard to tell they are just covers. Everyone thinks theyíre leather seats and are shocked when I tell them theyíre just covers. They sell a pair of seat heaters with switches for $119-$169 that Iíve been considering getting as well. May consider it before next winter. I have heated seats in my Subi and they sure spoil you.
The leather seats.com covers are a little pricey but look very nice.
5th gen seats in 4th gen?-842af332-9fa5-49bc-afc0-d187b37fd659-jpg  5th gen seats in 4th gen?-114e15d6-3383-4d7b-b3ad-b01d01094cac-jpg  5th gen seats in 4th gen?-adb6337c-614e-40e0-a4a9-75c59b08be4a-jpg
2019 Subaru Crosstrek Limited in Venetian Red Pearl
2008 Titanium Metallic 4WD 4Runner V6 SR5/ 17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires/ Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger/Front Diff. drop spacer kit/ Red energy Poly sway bar bushings with sway bar relocate kit/ Rear-Bilstein 5100's with ToyTec superflex black springs/ Red energy Poly sway bar bushings/ Moog 2nd gen rear sway bar links with red Energy bushings/ Tyger Bull bar with LED's/Lund HX tube side steps
cwilliams563 is online now   Reply With QuoteReply With Quote
4th , 5th , gen , seats , stains
Is there a TSB for squeaky seats on the 2014/2015 seats? brian0128 5th gen T4Rs 31 08-12-2016 01:11 AM
2014 trail Softex seats or old school seats longeuayms 5th gen T4Rs 10 08-07-2016 08:58 PM
Replacing the Back Bench Seats with Bucket Seats. dse911 3rd gen T4Rs 14 08-03-2016 02:52 PM
Looking to swap my grey leather seats for your cloth seats. Denver HustleHard 4th Gen T4Rs 10 07-10-2015 05:36 PM
Worth $200? Leather seats vs Cloth Seats piperoo 3rd gen T4Rs 13 08-18-2010 11:56 AM
