Old 01-11-2019, 09:53 PM #1
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
5 lbs of air makes a difference
I had low air at my oil change @31 per tire so put 36 in and that still didn't improve the ride. I looked closer at my tires and they indicate 55 max cold. 265/55/17...
I only have them at 41 now but might go to 44.. steering bounce over random bumps is a ton better. I was actually starting to become disappointed in my 6-month-old KYB struts, but it was just winter cold draining my air.
gaber6 is offline   Reply With QuoteReply With Quote
Old 01-11-2019, 10:17 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Cool... run what feels and works best for you within the tires limits.
It helps to know what tire and load range you are actually working with it... perhaps others can chime in with their experiences.
Old 01-11-2019, 11:34 PM #3
Frederick1's Avatar
Frederick1 Frederick1 is offline
Frederick1 is on a distinguished road
Frederick1's Avatar
I'm running 36lbs in my stock 2014 tires. The funny thing is my tire pressure light came on the other day. I drove home and parked in the garage. Next morning went out and checked pressure. 36lbs in all four. But, the idiot light is still on!
Fred from West Michigan
Frederick1 is offline   Reply With QuoteReply With Quote
Old 01-11-2019, 11:59 PM #4
MT Runner's Avatar
MT Runner MT Runner is offline
MT Runner will become famous soon enough
MT Runner's Avatar
Check the spare, theres a TPMS on there too.
2005 SR5 V6
URD headers and MAF Cal
AFE Intake
Dobinson, JBA UCAs, 255/75R17 KO2s, Level 8 MK6 wheels
MT Runner is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 12:02 AM #5
Bumbo's Avatar
Bumbo's Avatar
Spare tire.
Old 01-12-2019, 12:15 AM #6
Frederick1's Avatar
Frederick1's Avatar
Thanks guys! I never thought of that.
Old 01-12-2019, 07:39 AM #7
Jim_A Jim_A is offline
Jim_A is on a distinguished road
If your doing most driving on pavement your tires will wear in the center much faster! You don't go by the tires inflation rating, you go by what the vehicle manufacturer recommends, that is if you want even tire wear.
Jim_A is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 08:56 AM #8
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Just an fyi, if a tire is overpressurized then the light will go on too. Alot of manufacturers are doing this now. Not on ours but newer vehicles.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 09:35 AM #9
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
In my experience, what you mention here is only applicable when using tires of the same size and load rating the vehicle came with. Once you deviate from that, as most here do, you have to go by the recommendation of the tire manufacturer, or experiment to find the best balance of ride quality and wear. Obviously how the vehicle is being used makes a difference too. For example, you may want to increase pressure if doing mostly highway driving and towing, where for off road, you generally have to air them down, depending on terrain. For my situation with 265/70/17 Wildpeak AT3W tires, Ive found 38psi to be the sweet spot for everyday driving.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 10:26 AM #10
There are many variables, I'm talking generally speaking.
Old 01-12-2019, 11:38 AM #11
Swipter Swipter is offline
Swipter will become famous soon enough Swipter will become famous soon enough
I learned that and putting air in with the valve on top was a blast.
Swipter is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 02:28 PM #12
BlackCloud's Avatar
BlackCloud BlackCloud is offline
BlackCloud has a spectacular aura about BlackCloud has a spectacular aura about
BlackCloud's Avatar
I don't care what a vehicle mfr says to do with tires. They didn't manufacture or test that tire. The tire company did. Remember all those Ford Explorers flipping over? Ford was telling people to way under inflate the tires for a more comfortable ride. The tire is the only part of your vehicle that touches the road, so I do what they say.
BlackCloud is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 02:41 PM #13
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
Only if your running the OE sized tire
otherwise you go by the tires inflation rating b/c it is based on that specific tire size ...
jrm is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 05:10 PM #14
LarsBars LarsBars is offline
LarsBars is on a distinguished road
Correct me if I'm wrong, but I'm not aware of tire manufacturers providing a recommended inflation, there's too much variance between vehicles for a one-size-fits-all recommendation. They DO provide a max inflation rating, which is just that, the maximum. You don't want to be running that or you're in for a harsh ride and uneven wear.
When I switched to 265/70/17 Falkens, I started at 35, but after noticing the center wearing more than the sides, dropped down to 33 and that fixed it, plus it feels a little more stable at highway speeds.
Sent from my SM-G950U using Tapatalk
LarsBars is offline   Reply With QuoteReply With Quote
Old 01-13-2019, 10:42 PM #15
ElZilcho's Avatar
ElZilcho ElZilcho is offline
ElZilcho will become famous soon enough
ElZilcho's Avatar
Tire manufacturers only specify maximum inflation pressure. This has no correlation to the "correct" inflation pressure. Their are two good ways to check for "proper" tire pressure. The chalk method (which you can google) and the temperature test (below). Both of these tests are meant to make sure that tire pressures used are creating the ideal contact patch between the tire and pavement. In my experience, even tires of wildly different characteristics and sizes, when mounted on the same vehicle, are usually happiest at or near the pressures indicated on the vehicle manufacturers door placard.
This isn't a one size fits all thing though... If your rock crawling the "best' pressure might be significantly lower, and if your towing the "best" pressure might be significantly higher. YMMV (literally). You may personally prefer higher or lower pressures for efficiency or comfort, but any pressure that compromises the contact patch may upset the handling dynamics of the vehicle or cause excessive tire wear. If you and your wallet are okay with wearing out tires a little faster for the sake of comfort... then gal' dern it, I won't judge ya'.
For those interested the temperature tire pressure method is:
1) Drive the vehicle normally for ten to fifteen minutes.
2) Stop the vehicle in a safe location and, using a non-contact thermometer, measure the temperature of the tire tread in three places. Once at the outside edge of the tread, once in the center of the tread, and once at the inside edge of the tread.
3) Compare these temperatures. A properly inflated tire will show that all three temperatures are approximately equal.
Significant temperature differences (>5 degrees F) indicate improperly inflated tires or suspension/alignment issues and can be interpreted as follows:
If temperatures are read from outside to inside and indicate
High, low, high = tires under-inflated
Low, high, low = tires over-inflated
Low, high, high = Excessive toe out or negative camber
High, high, low = Excessive toe in or positive camber
The temperature test does not require letting the tires cool between testing. If pressures are off add/release air and repeat.
Sorry if this is all a bit dry, but... science!
Be healthy.
Be nice.
Do interesting things.
2008 4WD SR5 V8. 2.5/1.5 Daystar. 265/75R16 Duratracs #UZN215
Last edited by ElZilcho; 01-19-2019 at 02:19 AM. Reason: Screwed up my math symbols...
ElZilcho is offline   Reply With QuoteReply With Quote
air , bounce , bumps , cold , steering
Rear UCA, who makes them? kolelt 3rd gen T4Rs 0 01-08-2019 11:57 PM
who still makes headers for 4R's? Whitson Metalworks 3rd gen T4Rs 4 09-06-2013 03:52 AM
Another one makes it to 200,000 Nashvegas34 3rd gen T4Rs 7 11-27-2012 10:56 PM
Who makes them..... Falls Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-30-2007 01:23 AM
