Old 01-18-2019, 11:07 AM #1
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Brake Flush Question
I've read threads and watched videos and feel confident in doing a full brake fluid flush, but there's one thing nobody mentions (unless I missed it).
I plan to replace the stock bleeders with Speed Bleeders. Will brake fluid come out when the stock bleeder is removed, or does fluid only come out if the brake pedal is pressed while the bleeder screw is loosened or out?
It seems to me some fluid must come out if the bleeder is removed. If that's the case, how much and how hard? Spray, trickle, gush, or somewhere in between? Just want to be prepared so as not to have fluid everywhere.
Thanks in advance.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 11:20 AM #2
mwebster22 mwebster22 is offline
mwebster22 is on a distinguished road
Thanks in advance.
An ooze.
2012 4Runner Limited 2WD
2006 4Runner Sport 4WD
2006 4Runner Sport 2WD
mwebster22 is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 12:47 PM #3
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
Hold down the brake pedal + open bleeder = the squirts
No pedal pressure, it'll dribble out (gravity. Brilliant!). Enough to make the surrounding caliper area messy, but slow enough that you can take the bleeder out and put in your speed bleeder.
Hose down with brake cleaner afterwards, done.
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 06:10 PM #4
Just be careful holding down the brake pedal. It’s different than other vehicles, in that there is a pump that will activate and continue to bleed the system, including pumping the reservoir dry, which reportedly is a big problem. But it makes it easier if you’re careful. Easy, but a coordinated two person job.
Old 01-18-2019, 06:25 PM #5
Real Name: Skip
Real Name: Skip
As stated it should only dribble/ooze out fluid....BUT if you have a stuck caliper it could squirt out until the pressure ie released.
I would put a piece of plywood or double up some cardboard to keep any that dribbles out from staining your driveway, and as stated use brake cleaner to cleanup the cailper/s.
2004 Limited V8
Old 02-01-2019, 06:48 PM #6
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Thanks in advance.
What size speed bleeders did you get? Or do you have a link to the ones you bought? I'm going to be replacing my calipers and would like to put speed bleeders on while I do it.
djpope09 is offline   Reply With QuoteReply With Quote
Old 02-01-2019, 11:21 PM #7
Bluesky 07's Avatar
Bluesky 07's Avatar
Top is front, bottom is rear. Haven’t installed them yet.
Always good to doublecheck the website. It’s here.
bleeder , bleeders , brake , fluid , flush
Never done a brake fluid flush. Should I? JohnnyT 4th Gen T4Rs 15 05-15-2019 12:01 AM
New Radiator with Coolant Flush? Power Steering Fluid Flush, and Brake Fluid Flush? jdotlim 4th Gen T4Rs 4 09-17-2017 07:52 PM
Brake Fluid Flush Boaz Maintenance/Detailing 34 09-22-2016 09:59 AM
4th Gen Brake Flush Atlanta_man 4th Gen T4Rs 4 11-02-2012 02:06 PM
Brake Flush??? MikeinCincy Maintenance/Detailing 17 11-02-2008 01:24 AM
