Old 01-20-2019, 12:35 AM #1
dalandshark's Avatar
dalandshark dalandshark is offline
dalandshark is on a distinguished road
(Another) XREAS replaced with Monroe!
Hey All,
At 135,000 miles, I Replaced my failing XREAS system with a Monroe set that I bought from JC Whitney for $315.00 total. The part number is SET-TS171371R-C which has the Monroe Quick struts for the front.
If you are not looking for a lift, this is the way to go! As others have noted, the Monroe quick struts levels out the front by raising it about half an inch. I'm guessing this is due to the old springs were probably worn out and had sagged?
Anyway, the truck is much quieter and drives like a new truck. I wouldn't hesitate to go this route again. There is really no point in replacing with the XREAS when you can replace these several times and still pay less than new XREAS shocks. Plus, If I ever want to lift it I'm half way there.
Some notes about my swap:
1. Once I removed the wheels it was obvious that 3 of the shocks had been leaking slowly (discolored dirt). Enough fluid had leaked out allowing the rear to bounce off the stops when driving over speed bumps. Due to this fact, I disconnected the XREAS shocks at the their banjo bolts. It didn't make a big mess as I just put a catch pan underneath. Yes, there are check valves, the rear play hard to get.
2. I have a V8 and therefore the larger sized sway bar. I DID NOT have to remove it completely. I only had to take the holder off the side I was working on and slide the bar forward. This allowed enough space for the complete strut assembly to slide down and out once the LCA was separated from the hub assembly.
3. Make sure to torque the nut on top of the struts (the one that holds the shock inside) after you lower the truck back onto the ground. One of mine was loose and the instructions note that this is needed.
4. It took me 6 hours, but I have a crappy jack, stands that could be bigger, and a gravel driveway.
5. I was going to take pictures, but I got frustrated so I'll have to console you with pictures of the failed XREAS shocks.
2003 4runner sport (V8, RWD, Mostly Stock)
dalandshark is offline   Reply With QuoteReply With Quote
Old 01-20-2019, 08:14 PM #2
chris in ky chris in ky is offline
chris in ky is on a distinguished road
A question...
My '06 V6 rides super stiff with the original xREAS at 205k miles, slight leakage on one of the fronts. I know the system is designed to prevent lean, but was yours hard riding over bumps?
Mechanics keep telling me "it's a truck, the ride will be rough" but I'm not convinced.
2006 Sport V6
Bought used @ 185k miles
My first T4R, previous XJ owner
chris in ky is offline   Reply With QuoteReply With Quote
Old 01-21-2019, 11:02 PM #3
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Originally Posted by chris in ky View Post
A question...
My ‘07 is also a V6 and that’s exactly why I just replaced my X-REAS at 149K. Handled okay but the ride was harsh. See the link in my sig for more info.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 02-02-2019, 10:19 PM #4
A question...
We bought ours 5 years ago with 95000 miles. The ride was smooth and comfortable for about four years. I started noticing the bounce over speed bumps last year. It never felt like a rough ride to me. Perhaps in the years after 03 the system was made to ride stiffer... Or maybe the center damper things mounted on the frame are faulty on yours (not at a computer to look up the name of those).
Old 02-04-2019, 12:49 PM #5
Sporin's Avatar
Sporin Sporin is offline
Sporin is on a distinguished road
Sporin's Avatar
This sounds like a great option on a budget. Thanks!
Sporin is offline   Reply With QuoteReply With Quote
Old 02-07-2019, 01:01 PM #6
MaddT4R's Avatar
MaddT4R MaddT4R is offline
MaddT4R is on a distinguished road
MaddT4R's Avatar
good to know, i am replacing mine soon.
2004 4Runner limited - bone stock for now
MaddT4R is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 01:58 PM #7
MSRP. MSRP. is offline
MSRP. is on a distinguished road
Man, yours look 3x better than my set of XREAS at 185k.. mine have rust that have corroded the actual shock body..
Still ride decently though with the metal tech conversion for the rear airbags.. time will tell.
MSRP. is offline   Reply With QuoteReply With Quote
half , monroe , shocks , truck , xreas
Monroe Shocks spoiler900 3rd gen T4Rs 39 06-30-2023 01:25 PM
Replaced under warranty, what have you had repaired/replaced? WandaRunner 5th gen T4Rs 40 12-29-2018 08:07 PM
Modify Xreas to fit non Xreas sliders Brian3676 4th Gen T4Rs 1 01-21-2016 09:33 PM
The reason why Non-Xreas takes on ramps better than Xreas. MICA4R 4th Gen T4Rs 14 05-14-2013 09:14 PM
Monroe shocks MudbogPete Engines / Suspension / Wheels / Tires / Audio / Accessories 4 08-10-2003 02:28 PM
