Old 01-20-2019, 03:24 PM #1
Beckee Beckee is offline
Beckee is on a distinguished road
OEM Auto Dimming Mirror Installation, need some help..
I purchased a OEM Auto Dimming Mirror thinking I can just remove the old one and plug the new one in. I was wrong and turns out I need a wiring kit. I searched the forum but I just couldn't find anyone that only sells the wiring kit / harness.
Can anyone help me finding the wiring kit? my apologies if there is a post that covers this.
50792606-640379443048243-8824366547104432128-n
thanks in advance!!
OEM Auto Dimming Mirror Installation, need some help..-50226122_610732766043844_9143113829830361088_n-jpg  OEM Auto Dimming Mirror Installation, need some help..-50807003_323964221659901_1885953498684588032_n-jpg  OEM Auto Dimming Mirror Installation, need some help..-50670009_398491607621717_3759707434822664192_n-jpg
Beckee is offline   Reply With QuoteReply With Quote
Old 01-20-2019, 06:41 PM #2
morphious's Avatar
morphious morphious is offline
Real Name: John
morphious is on a distinguished road
morphious's Avatar
Real Name: John
This may help, good luck!
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
morphious is offline   Reply With QuoteReply With Quote
Old 01-21-2019, 03:09 PM #3
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
It looks like you bought a used mirror without the connector and wiring that comes with it. You definitely need that.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 01-22-2019, 03:37 AM #4
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
I know people have added auto dimming mirrors, but not sure about OEM route. I can tell you that the harness is part of the headliner harness which runs down the A Pillar to the driver kick panel fuse box. On mine there’s 2 connectors that come down. 1 that connects to something by the footwell, and the othe the fuse panel. Not sure which one is for the mirror, but the harness is definitely 1 piece for the whole headliner.
My guess is if you want the OEM auto dimming harness, you’re either going to have to buy the entire headliner harness, which is probably in the hundreds if not 1000s. Or you could hit up a junkyard and maybe pick up an entire headliner for a 100 with the harness. Or maybe you can get a pigtail with the connector from the junkyard if you’re lucky. I certainly wouldn’t recommend dropping the headliner to do this.
Or you can look at this thread. May even be universal...
Instal of Auto-dim Rear-View mirror (Gentex)
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 01-23-2019, 10:44 AM #5
smyles1632 smyles1632 is offline
smyles1632 is on a distinguished road
You can tap into the existing wiring or to fuse box. Typically these mirrors need just 3 wires: ground, constant +12 and switched +12; two more may be needed for the temp sensor, if exists. If the mirror came from a 4Runner or other Toyota model, you can find pigtail/wiring on ebay or junk yard, just make sure it's the 7 pin as there're also 10 and 12 pin connectors.
Sometimes you'll also need to figure out the pin-out, as even the same mirror model (they all made by Gentex, with few exceptions) can have different pin designations for different manufacturers.
P.S. I have a mirror for sale in classifieds.
smyles1632 is offline   Reply With QuoteReply With Quote
auto , kit , mirror , oem , wiring
Auto Dimming Mirror with Compass and Thermometer Installation nissanh 3rd gen T4Rs 48 01-29-2019 07:03 PM
Need Help: Auto-Dimming Mirror Install 4Runnerguy Engines / Suspension / Wheels / Tires / Audio / Accessories 38 12-30-2012 01:40 PM
Auto dimming mirror/compass NDRYDEN123 4th Gen T4Rs 2 04-16-2009 11:09 PM
Auto Dimming Mirror gapboi210 3rd gen T4Rs 6 03-31-2007 11:01 AM
FS- Auto dimming mirror T4RUSAF Classifieds - buy & sell (no commercial ads please) 9 07-03-2006 10:51 PM
