Old 01-24-2020, 05:01 PM #61
V8Limited4wd's Avatar
V8Limited4wd V8Limited4wd is offline
V8Limited4wd is on a distinguished road
Originally Posted by xtremewlr View Post
Any install tips you might have would be supremely helpful. I'm going to start on it tonight after work.
Which year/trim do you have? I mainly used youtube videos to figure out wiring up my backup cam and steering wheel controls. Other than that it was pretty straight forward with wiring the harness to the adapter. Make sure you adjust the gain for your music before putting the unit in and putting the dash back together.
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 1.5" lift
V8Limited4wd is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 07:03 PM #62
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr has a spectacular aura about xtremewlr has a spectacular aura about xtremewlr has a spectacular aura about
xtremewlr's Avatar
Real Name: Todd
03 Limited with the JBL crap system. Working on it now, trying to figure out what is what.
xtremewlr is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 11:33 PM #63
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Got the head unit installed and working. No steering wheel controls yet. I got a Maestro SW and was all set to wire it in and come to find out it looks like I'm missing the harness that plugs into the stereo. Have the side you are supposed to wire into the vehicle harness but that's it.
Also have gaps all around the head unit since it didn't come with any trim pieces. @V8Limited4wd , what did you use to fill the gaps?
Old 01-25-2020, 01:06 PM #64
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Pioneer sub installed this morning.
Old 01-25-2020, 02:54 PM #65
adkfinn's Avatar
adkfinn adkfinn is offline
adkfinn will become famous soon enough
adkfinn's Avatar
Was your factory sub blown? Let us know how the sound is (both the sub and overall) once you get up and running.
2007 4Runner with some crap on it. Nice crap.
adkfinn is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 03:33 PM #66
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
It was working, kind of. It basically fell apart in my hands when I removed it tho.
Not getting a lot of bass out of the Pioneer. I didn't turn up the volume or other settings before pulling the old head unit, which apparently you are supposed to. But it does work just fine and overall, the sound isn't horrible. I do have a blown passenger front speaker so the next step is to replace all the door speakers. Just need some funds and to decide with what. Then I'll look at replacing the amp with something else.
Old 01-26-2020, 10:37 AM #67
I wired up the SWC directly to the ATOTO so you donít need that adapter. I had the OEM nav so I didnít have that empty space around the unit. You might have to buy the entire center frame from a limited.
2004 V8 LIMITED 4WD
Old 01-26-2020, 10:40 AM #68
You werenít able to remove just the sub screen cover?
2004 V8 LIMITED 4WD
Old 01-26-2020, 01:17 PM #69
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
I have a limited, just didn't have nav. I'll have to do some searching to see if there's a difference in the systems.
When I got the whole panel off, you could see where the smaller cover should pop out but it was plastic welded in place from the factory. Maybe later years changed that.
Old 01-26-2020, 02:34 PM #70
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
So it does look like if your 4R had nav or the basic, non-JBL system, without RDS and all that crap, the dash bezels ARE different. So I need to buy a new dash bezel to resolve the gaps that I have.
You can see the differences in the attached pics. The first one was with nav or at least non-JBL/RDS.
The second pic is what I have that had the JBL system with RDS but no nav.
Ordered a "Plug and Play" Android headunit-radio-bezel-nav-jpg  Ordered a "Plug and Play" Android headunit-radio-bezel-without-nav-jpg
Old 01-26-2020, 05:46 PM #71
Trigle Trigle is offline
Trigle is on a distinguished road
what am i missing? i can get a 7" Alpine android auto unit for $299 from best buy with free installation. whats the difference between what you are getting and what this is?
Ordered a "Plug and Play" Android headunit-alpine-jpg
Trigle is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 06:34 PM #72
Real Name: Skip
AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold AuSeeker is a splendid one to behold
Real Name: Skip
Who exactly are you asking this question of?
If you want an answer from someone in particular or even several posters you need to either quote them or mention them like this @Trigle , a @ symbol and then their exact user's name with no space, doing either will notify them of your interest in their post or subject matter, otherwise no one will most likely answer your question because no one knows who you're directing the question too!
2004 Limited V8
Old 01-26-2020, 06:35 PM #73
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Go for it. I have no idea what the difference is. I actually enjoy working on my vehicle instead of having someone else do it.
Old 01-26-2020, 06:49 PM #74
my bad, im a noob, lol. my question in general is the same across a couple of forums that people are ordering no name head units from online when you can just go to best buy and buy a name brand android unit for 2-300 bucks with free installation! i get if you like to do the work yourself but youre also getting a warranty whereas these no name brands might not stand behind their products as much. i just got my 4runner today and this is the first thing i need to do so just learning.
Old 01-26-2020, 10:14 PM #75
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
ATOTO support has been great so far. Little slow due to Chinese New Year but they are responsive and have a support website as well. The HU is also well liked by the FJ guys. I'm not overly concerned.
fit , ordered , play , stock , supposed
"plug-n-play" Remote Start Kit! rigtec 5th gen T4Rs 12 04-14-2020 06:57 PM
Has anyone ordered this "Air Compressor Switch" from Amazon? alia176 4th Gen T4Rs 11 12-07-2016 09:06 PM
Ordered this Cargo Basket---RockyMounts "14er" Did I do good? Pseudo-Fed 5th gen T4Rs 4 07-26-2016 08:32 AM
"Play" in throttle body valve thing. poser 3rd gen T4Rs 2 10-09-2014 03:05 PM
Android Auto Link (Car Play version for android) NoDak Off Topic 0 06-18-2014 04:03 PM
