01-27-2020, 10:16 AM
#76
Real Name: Todd
Real Name: Todd
Originally Posted by V8Limited4wd
Yeah I meant a limited with Nav. I don't think there's any other way to close that gap around the unit.
Yeah, that is the only solution with this particular head unit. Not a big deal, just extra $$. Console bezels aren't cheap on ebay or elsewhere. Most I'm seeing are over $150.
01-27-2020, 10:36 AM
#77
Originally Posted by Trigle
what am i missing? i can get a 7" Alpine android auto unit for $299 from best buy with free installation. whats the difference between what you are getting and what this is?
The ATOTO A6 Pro is an android tablet which has been customized for use in automobiles - you can use it as an android tablet OR you can have Apple CarPlay or Android Auto. All the other name brand stereos that are limited to their own UI with the option of using Apple CarPlay or Android Auto.
2004 V8 LIMITED 4WD
[INT/EXT] 06+ Projectors & HIDs/LEDs/CDN Hood deflector/SS Bull Bar & Hitch Step
[ENGINE] aFe Pro DRY S Air Filter/DT Headers/TRD Dual Exhaust
[WHEELS/SUSPENSION] OEM 20" Rims(265/50R20)/Dobinsons Suspension 2" lift
01-27-2020, 11:09 AM
#78
Anybody know about installing this with the Tomtom head unit? I'm sure it isn't, but hoping it's still plug and play
2009 Shadow Mica Trail Edition - 2" Dobinson lift, 285/75r16 Cooper ST MAXX, gunmetal FJ Cruiser 16" TRD wheels, 1.25" Spidertrax spacers, Powerstop rotors and pads, Rola roof rack with 4xInnovations low pro mounts and LED's front and rear, NAPA awning, Rago ditch light brackets with Caliraised side shooter led pods, Caliraisedled 2012-15 Tacoma fog light mounts with amber led pods
01-27-2020, 10:38 PM
#79
Originally Posted by xtremewlr
So it does look like if your 4R had nav or the basic, non-JBL system, without RDS and all that crap, the dash bezels ARE different. So I need to buy a new dash bezel to resolve the gaps that I have.
You can see the differences in the attached pics. The first one was with nav or at least non-JBL/RDS.
The second pic is what I have that had the JBL system with RDS but no nav.
@ xtremewlr
found this dash kit after lots of digging. A couple reviews specifically mention this piece working for a 2004 T4R limited w/ jbl and rds. That's exactly what I have. Thought it might be worth checking out!
SCOSCHE TA2079B 2003 to 2009 Double DIN Stereo in-Dash Installation Kit Compatible for Toyota 4Runners with a Factory RDS/JBL System Amazon.com: SCOSCHE TA2079B 2003 to 2009 Double DIN Stereo in-Dash Installation Kit Compatible for Toyota 4Runners with a Factory RDS/JBL System: Car Electronics
Sent from my SM-G975U using Tapatalk
Instagram: @boejucci
'04 Limited V6 ("Mugatu")
01-27-2020, 10:42 PM
#80
Real Name: Todd
Real Name: Todd
[QUOTE=boejucci;3432564]
The second pic is what I have that had the JBL system with RDS but no nav.[/QUOTE
@ xtremewlr
Nope, that won't work with the ATOTO A6Y, even if you have the same radio/console bezel I have. Your only choice with the ATOTO is to replace that trim piece with the non-JBL or nav one.
02-02-2020, 12:45 AM
#81
So to sum things up, what I understand is with a basic non-JBL/RDS headunit, get the Atoto A6 Pro Toyota unit and it comes with everything you need, plug and play.
If you have JBL, then find a base console or console bracket.
Any others with feedback on the A6? Does it improve on the base headunit sound quality?
02-04-2020, 09:22 AM
#82
With the JBL system you also need an additional wiring harness/adapter mentioned by
@ xtremewlr
above. Just clarifying for anyone who revisits this thread in the future.
02-04-2020, 11:17 AM
#83
Real Name: Todd
Real Name: Todd
@ xtremewlr
Another caveat I have discovered about the non-nav JBL head unit.
Not only is the radio bezel different but so are the HVAC controls. I got a replacement radio bezel off ebay and it fits the A6Y perfectly and there are no gaps on the sides any longer. HOWEVER.... There is still a gap at the bottom because of the different HVAC controls. With the larger JBL head unit, the plastic molding at the top of the HVAC controls extends UP about 1/4" and doesn't extend BACK like the nav or non-JBL head units.
So, off to ebay to find a new HVAC control unit that will finally finish the project. I'll post pics of the difference once I have one.
02-08-2020, 07:44 PM
#84
Real Name: Todd
Real Name: Todd
Replacement climate controls received. Here are the visual differences.
Original to my 4R on the left. This fits the JBL system without nav. The right side is either a standard radio or the JBL system WITH nav. Notice the difference at the top, above the display.
And here is a comparison of the tops from the side. The non-nav fold back and over the top to fill the gap between it and the radio.
02-08-2020, 09:02 PM
#85
Real Name: Skip
Real Name: Skip
Is the top bezel removable so you can swap your old bezel to the new one?
2004 Limited V8
02-08-2020, 09:11 PM
#86
Real Name: Todd
Real Name: Todd
On the climate controls? Possibly, I didn't look at that.
Looking at my original climate control, I would say yes, you can do that. It would involve disassembling the whole climate control to swap out the face, since that is one piece.
So you could buy a cheap climate control, even one that doesn't have all the same functions as your original and then swap the face on them, retaining the functionality of your current one and getting the correct face/bezel for the radio swap.
02-24-2020, 10:38 PM
#87
I have the non-JBL and the A6 Pro Toyota version still didn't fit perfectly because the Atoto unit sticks too far out on the stock brackets.
2004 SR5 4WD | 5100s | Level 8 MK6s
02-25-2020, 09:28 AM
#88
Real Name: Todd
Real Name: Todd
Interesting. I had no problems with the stock brackets from mine (JBL unit, non-nav) when I did it. All my issues were otherwise noted and resolved with factory parts off ebay.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
02-25-2020, 05:52 PM
#89
I emailed Atoto support and they said the A6 Pro Toyota version is not compatible with the 4th gen 4Runner.
I'm really confused. I'm going to return it and go traditional name brand headunit.
02-25-2020, 05:55 PM
#90
Real Name: Todd
Real Name: Todd
Which did you get? This is the one I have installed in my 4runner right now. Fits great.
https://www.amazon.com/gp/product/B075W9H5P3/
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
