Old 01-23-2019, 03:54 AM #16
HCWatson997's Avatar
HCWatson997 HCWatson997 is offline
Real Name: Cole
HCWatson997 will become famous soon enough
Real Name: Cole
Trimming for 34s
Hi, I think I can be of some help here. I hope you’re talking about 285/75/17 instead of 285/70/17. The first is a 34 and second a 33. I put on 34s back in September with 3.5-4” lift up front and 2” in the rear. I rubbed on my stock bumper with stock UCAs REALLY BAD on the street...I cut off 1” from the front fender including both metal and the flare. I also cut a tapered line from the corner where the fender meets the bumper in the fenderwell with up to 2” cut off the front bumper. For the rear bumper, I had to trim 1/2” off up to the fender. I have 2” bumpstop drops as well as a 1” body lift. Did an aggressive body mount chop and removed all fender lining. Sitting on bumpstops, I still have 1” or more of clearance in the fenderwell when it’s tucked in there. I still rub on the firewall/body mount some with stock UCAs when flexed out. I really tried to make the cuts as clean as possible.
Rear tire rub with 34's-4961b6be-dd3d-4d2b-bc18-23e548a6f378-jpg  Rear tire rub with 34's-aad70ee6-f473-4b4d-b084-1e8ca5ebbb4e-jpg  Rear tire rub with 34's-6fe96f34-e3f1-408b-b241-8a08a383a5d5-jpg  Rear tire rub with 34's-a2bed64e-022f-4d79-a627-9b59ff10a39f-jpg
03 V8 2WD converted to 4x4 | 3/2” sus lift | 1” BL | 34” Falkens | first Coastal Offroad hybrid bumper | FiberwerX fenders | JBA UCAs | VVTI intake/fuel rail/TB swap | white/green cluster swap
HCWatson997 is offline   Reply With QuoteReply With Quote
Old 01-23-2019, 11:39 AM #17
phqduphead's Avatar
phqduphead phqduphead is offline
Real Name: Kyle
phqduphead is on a distinguished road
phqduphead's Avatar
Real Name: Kyle
Running 295 70 17 mud terrains, I have metal tech lower rear arms which I extended 1/4”. That keeps me from rubbing on my door fender. I trimmed the bumper side if the wheel well and hammered the pinch weld. I’m running the long travel setup so I have 2” bump stops. My front is cut aggressively, has a caster of 5 and I don’t rub. No body lift.
06’ Sport 4WD, locked on 33’s
phqduphead is offline   Reply With QuoteReply With Quote
point , rear , thread , tire , wheel
4th Gen rear tire carrier crozhawk Engines / Suspension / Wheels / Tires / Audio / Accessories 42 08-08-2013 07:16 AM
Rear Tire Carrier 4RUN0326 3rd gen T4Rs 10 01-03-2013 04:24 AM
Rear tire Carrier. 94Beast4Runner Classic T4Rs 14 09-10-2009 01:51 PM
Rear mount tire Spencer 3rd gen T4Rs 9 09-04-2009 02:24 PM
rear tire carrier is done! lee 3rd gen T4Rs 20 05-09-2007 09:49 AM
