Originally Posted by MrEMan
So I'm not sure what your mean by "track pack" gauges and whether or not you're specifically referring to gauges you mentioned (0-60, 1/4 mile, braking, etc.). I can check those specific gauges if you'd like. I'm using the Maestro RR w/T01 harness and Pioneer MVH-2400NEX in my 06 4Runner with JBL. The only gauges that the system indicates do NOT work are:
Boost/Vacuum
Dist to Empty
Engine Oil Temp
External Air Temp
Fuel Level
Fuel Pressure
Intake Manifold Air Pessure
Torque
Transmission Fluid Temp
But I haven't tried all of the gauges that supposedly work, so I can't verify ... but the ones I've used so far all seem to work.
Sorry for the confusion, I was using ADS iDatalink's marketing terms. Their definition of "Track Pack" is for the gauges that show performance data (0-60, 1/4 mile, braking, etc...). The other gauges ("Performance Gauges" using their marketing lingo) are for ODB data.
I have no problem with the "Performance Gauges", all the OBD data works fine, besides the exceptions you listed above. However, the "Track Pack" gauges (0-60, 1/4 mile, braking, etc...) do not work.
So basically, I'm just curious if anybody else's "Track Pack" gauges (0-60, 1/4 mile, braking, etc...) are working.
As an aside, If the "Track Pack" gauges don't work with the T01 harness (like they claim), it would certainly be nice if ADS would prevent them from even being added in the gauges display. Also, their marketing lingo is ridiculous, and not exactly transparent.
