01-22-2019, 07:50 PM
VSC OFF, VSC TRAC, Brake! And ABS lights on – need help ☹
Hey all – I could really use some help. Driving home today, and as I get off the off-ramp and come to a stop, my Brake! light went on. A second later, it was joined by VSC OFF, VSC TRAC, and ABS. The Skid Light and Check Engine lights are NOT lit. The brakes feel normal, and the car drives fine.
I get home and pull the codes, and I get:
C0125 – Rear Speed Sensor LH Circuit
C1223 – ABS Control System Malfunction
and most puzzling of all
C1340 – Open Circuit in Center Differential Lock Signal (During Center Differential Lock On)
I can’t use the OBDII reader to clear the codes (I have one of the older models prone to the ISO/CAN language barrier that deletes the Zero Point Calibration issue – been there, done that, don't wanna do it again), so I disconnected the battery, touched the cables to each other, and reconnected. When I turned the T4R back on, all the same lights lit up immediately. So, I’m guessing it is an ongoing fault.
Just out of curiosity, I locked the center diff, drove back and forth, then unlocked it. I had no issues either locking or unlocking (at least that I could see).
I’ve googled and am getting nowhere. Any idea what I am looking at? Are all three codes related? Are the first two related (can a bad speed sensor also trip C1223?) and the C1340 is an unrelate “red herring”? In short, how the heck do I fix this speedily and, hopefully, without mortgaging what is left of my soul?
Any and all help is greatly appreciated.
2003 SR5 V8 in Stratosphere Mica - OME lift, Light Racing UCAs, 265/70/17 Terra-Grapplers
There is no problem so large or so complicated that it cannot be solved with brute force and ignorance - Anonymous
"Attack Everything" - Lanoe Hawker, WWI Ace
01-22-2019, 08:35 PM
Check for physical damage to the abs sensor or corrosion of wiring/connectors Sensor is plugged into the back of each hub. First code is referencing drivers side rear wheel sensor so check there first.
If everything looks good you’ll need to dig further , the sensor can be tested using a voltmeter.
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
01-22-2019, 11:05 PM
Thank you. The sensor and harness look fine, but I found one on Amazon for $29 (80% of the OEM price), so I ordered it. If swapping it out doesn't work, I haven't wasted much beyond time.
Any ideas if the other codes might be related to that sensor (as unrelated as they seem to be)? I had read on one post that the wheel speed sensors can throw clusters of seemingly random codes alongside the C0215 when they go?
01-22-2019, 11:20 PM
I have heard of the gas cap (no joke) causing this problem. Needs to be turned until one click. Also if defective causes this problem. That and the cables already mentioned are two primary culprits. Good luck!
01-23-2019, 12:28 AM
Battery
Another cause could be your battery. We have had similar problems with our 4runner in the past. Now we know that the battery is weak and once replaced everything is back to normal. Living in the desert you have to replace a battery every two to three years.
We have to replace the gas cap ever three years or so also.
--<2004 4x4 Sport V6: FJ Springs and Bilstein 5100's All Around, Hidden Hitch Receiver, B&M 70264 Transmission Cooler, Weathertech Floormats, Brake Line Mod, Sway Bar Mods, Tekonsha Brake Controller and Dual Outlet Ashtray.
2014 Eclipse Evolution T225: Our house on wheels!
01-23-2019, 11:00 AM
I had the same thing going on last week. Turned out it was low brake fluid causing the dash lights. As the pads wear it takes more fluid to push them against the rotors. It's worth a quick look. I topped off the fluid and no more dash lights, just need to find the time to do a brake job now.
01-25-2019, 06:40 AM
Thanks guys!
I know it isn't the gas cap; I've seen that happen before, but it usually throws the check engine light too, and never the Brake! light. This was different. It wasn't the battery either. It has been really cold here, and my battery died three weeks ago, so I'm running a brand new Optima Red Top.
I went with the only code that made sense, and replaced the driver's side wheel speed sensor last night. I cleared the codes and drove up and down the mountain on which I live - drove about ten miles. So far, so good (finger's crossed) - No codes or lights.
The new sensor seems to have done the trick. I'll update if the issue returns . . . but hopefully not. Thanks everybody!
02-08-2021, 11:54 AM
Real Name: Blake
Real Name: Blake
Specimen: 2007 V8 Limited - 210k Miles
I believe I've come across the same problem. I was driving home and came to a stop at a light, all the sudden the dashboard was lit up! Lights on: VSC OFF , ABS, VSC TRAC, Anti-Skid, and Brake!. While the "Gas Cap" code/solution is common, I knew it was odd that the Brake! light was on. Additionally, I started the truck up the next morning and got the codes scanned and on my drive home, the lights were off! And now they're back on again... So I did some searching and found this thread, as I believe it to be a similar problem but some variation in the codes that were pulled:
C0215: Replaced ABS Wheel Sensor
C1223: ABS Control system Malfunction
C1239: Foreign Object is Attached on tip of Rear Speed Sensor LH
C1241: Low Battery Positive Voltage
C1246: Master Cylinder Pressure Sensor
C1256: Accumulator Low Pressure
So, for the first 3 codes it seems wheel speed sensor related. The latter 3 though, I'm struggling if they're of concern or if the speed sensor caused them haphazardly. I've seen other threads with similar dash light results (except no Brake! light was on) and it turned out to be the Brake Motor/Accumulator causing the problem, with a result of $3k+ at the dealer or still $600+ DIY fix. I checked my brake fluid level and it's still full, and was last bleed Feb, 2020. Any insight to this potential larger problem would be helpful.
@ Tuthmose
, do you have any updates/tips/tricks/advice from when you replaced the speed sensor? I'm hoping I can get a replacement similar to yours ($30 aint bad) and reset the codes and that solves everything.
22 SR5 Prem 4X4- Magnetic Gray
07 V8 Limited 4X4 - Natural White (SOLD)--> "Moby Dick" Build Thread
05-19-2021, 12:53 PM
@ Tuthmose
Any luck solving your issue? I just had the same lights (and crazy siren) come on this morning. Everything seemed to work fine for a few blocks then I felt a weird click through my brake pedal and it became very difficult to press down and almost rear-ended the guy in front of me. I checked around the MC assembly, didn't see any leaks, brake fluid is full. I need to try to limp it somewhere to pull any codes, but I'm guessing this is not just a bad switch, ground, or gas cap issue.
2004 v8 | bilstein 5100s | ome883 + wheelers t12 | 2013 FJ cruiser wheels
06-07-2021, 01:12 PM
Just a follow up post in case anyone else had the same issue. I found a remanufactured motor and accumulator assembly on ebay for $350. My local mechanic installed it and the siren is off, but the VSC + VSC Trac lights are still on. The motor/pump assembly works as it's supposed to I think. But it does come on every time I hit the brake pedal, which is something it didn't use to do, even in quick succession. If I'm stopped at a light with the pedal depressed it might cycle on again after 15-20 seconds. Does this sound like another issue like the system isn't holding proper pressure?
10-06-2021, 05:10 PM
Same problem - my solution
Hi All,
I had the same problem of brake!, VSC off, slip, ABS, VSC Trac lights on. NO CEL. I took it to a chain and they told me the problem was my right rear ABS and they could fix it to the tune of $1000. They also told me tire pressure was 11 and I knew that wasn't true, so I walked out.
I spent some time looking through the threads on this subject and decided I'd try some relatively cheap and easy things before taking my 2007 4Runner to the stealership. Here's what happened:
1. Replaced the gas cap - yes, I know, no CEL. But it was $13 so what the heck.
2. Cleared codes with a friend's OBD scanner. Didn't work.
3. Replaced the brake switch - $20 on Amazon. Interestingly, this turned the lights off for about a day, but they came right back on.
4. Zero point calibration - tried multiple times, never worked.
5. Removed leads from battery, touch together, wait, hook back up - didn't work.
6. Replaced my burned out 3rd brake light, didn't work.
7. Here's where it gets better - got an OBDLink MX+ OBD2 Bluetooth Scanner for $100. Pulled codes and got
C0215 Rear speed sensor LH circuit
C1223 ABS control system malfunction
Tried clearing codes, didn't work.
8. Figured maybe this means left rear ABS sensor, so replaced that. Roughly $30 for two sensors as I remember. That didn't work, so replaced right rear as well since drive through chain said that was the problem initially. Didn't work.
9. Used the "create dashboard" tool on the OBDLink app. Could clearly see that there was no left rear wheel speed signal coming through. Since we already replaced the sensor, ordered a new ABS wiring harness for about $100 and replaced.
And... lights have been off for days. Not counting the OBDLink, spent $163 and some hours instead of $1000. (Actually, probably would have been more since they diagnosed the wrong problem in the first place.) I'll use the OBDLink again, so I'm happy to have spent that money. I'll attach a screen shot of the dashboard showing all four wheels getting a signal now that it's fixed.
Thanks to everyone who posted in threads about ways to solve this problem!
10-07-2021, 12:03 AM
what happened with me was i found out one of my wheel bearings were toast. pulled it apart and it came out in 10 different pieces, never rattled or wobbled or grinding noise. fixed the problem with ABS and BRAKE light, i still never was able to get ride of VSC and TRAC OFF. but i think it's due to my check engine light for a different problem.
10-07-2021, 03:46 PM
Originally Posted by adot1999
Hi All,
Cool, I might have a similar issue. My lights come on when it's wet out. BTW, the picture is not showing up.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
10-08-2021, 01:34 PM
Real Name: Marc
Real Name: Marc
Similar issues 🙃 please help
Please help. I’m having similar issues with my 2007 4Runner!! Any advice or insight is greatly appreciated!
2007 Toyota 4Runner SR5 codes:
P0456- gas cap (could be an easy fix, just buy a new gas cap) that might fix that and the below issue as well…
P0441- Evaporative Emission Control System
P0455- Evaporative Emissions System Malfunction - Gross (Large) Leak Detected
P0894-Transmission Component Slipping
P2714- Pressure Control Solenoid ‘D’ Performance or Stuck
C1201-Brake control / Dynamic control system : Vehicle stability control system
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Brake, VSC OFF, VSC TRAC, ABS lights on
Luvtodrive |
General Discussions |
9 |
05-03-2018 04:34 PM |
Brake, VSC and Trac lights.....
Dry-fly |
4th Gen T4Rs |
7 |
08-03-2016 07:22 AM |
'check engine', 'trac off', and 'vsc' lights came on. Plus 'abs' and 'brake' lights
thehadley4 |
3rd gen T4Rs |
0 |
10-23-2011 01:51 PM |
VSC TRAC, TRAC OFF, ABS and BRAKE lights
ENRIQUE |
Problems & Warranty Issues |
3 |
02-03-2011 10:57 PM |
Brake, VSC Off, VSC Trac, ABS Lights
024runnerrich |
1 |
01-14-2006 01:30 PM |
