Old 01-23-2019, 05:39 PM #1
Samm25's Avatar
Samm25 Samm25 is offline
Samm25 is on a distinguished road
Samm25's Avatar
Consistent wheel vibration
Hey guys, kind of a long one here...
In November of 2017, I bought new tires for my Ď05 SR5 4Runner. Had them on stock wheels but put on pathfinder sport ats from discount tire. Noticed that the wheel would start to vibrate anytime between 60-70mph. Took it back to have discount balance them about 4 times. Fast forward to May of 2018, I bought some American outlaw Lonestar wheels, didnít change the wheel size, kept the same 17Ē wheel on 265/70/17 tires. Was still getting a vibration.
Well, fast forward to August of 2018 and I upgraded to an Ď08 SR5 with 17Ē wheels on it as well. Had the dealership I bought it from swap out the tires and wheels with the ones I had on my Ď05, however, since they promised me new tires when I bought the Ď08, the only thing they carried over to the Ď08 was the wheels themselves. Started getting the vibration on the new truck as well. Granted they put some knock off Ironman all country tires on there. So I brought it back to discount tire to ask them to rebalance them, letting them know my issue. After some time, the guy convinced me that it was my tires causing the issue. So he talked me into buying some Cooper ATPs 265/70/17, so I did it. They guaranteed me that it would stop the whee vibration. It didnít. I came back the next week, they rebalanced them, a few days later I was getting the same wheel vibration. I then went back a few days later and discount told me theyíd put some Goodyear Wrangler Ultra Terrains on it. So, they did, but the vibration came back again.
After talks with cooperate and getting an area manager involved, they got me some knock off TRD Pro wheels thinking that the wheels themselves could be defective that I bought from them. So, they put those on the Ultra Terrains. The issue came back a few days later. All of this was done in November and December of 2018.
Fast forward to now. Iím currently sitting inside of discount tire after getting their area manager involved again, they are putting on some Michelin LTX A/T2ís on it right now. The reason I specifically requested that tire is because my dad has an Ď05 4Runner, bought the same American Outlaw Lonestar wheels I had and put them on these Michelin tires...hasnít had a single vibration issue at all.
Curious if this doesnít work out, any other ideas at all? They have road force tested them, etc. however, I will tell you while sitting here right now the manager just came up to me and said that the Michelinís are road force testing a hell of a lot better than the Ultra Terrains did. So crossing my fingers that this works.
Anyone else have this issue at all with AT tires or even just any tire or wheel at all? For it to happen on 2 different 4Runners, with different sets of wheels AND tires, Iím stumped.
Samm25 is offline   Reply With QuoteReply With Quote
Old 01-23-2019, 05:46 PM #2
JVC8790's Avatar
JVC8790 JVC8790 is offline
Real Name: John
JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about
JVC8790's Avatar
Real Name: John
I'd look to see if the wheel is bent laterally. I have had a few wheels that "balance" just fine, but then vibrate because the spokes of the face were actually bent. If the guy running the balancing machine isn't watching the wheel there is a good chance they might not notice it and the machine will keep "balancing" just fine.
The other thing to look at would be if the wheels are hubcentric, if the wheels have a different hub bore than factory it makes it a bit harder to get the wheel centered when mounting and can cause vibration that is pretty hard to track down if you're not aware of the difference.
Just two initial thoughts, not making any promises given the situation you've been through!
2004 4Runner V8 Limited - TRD Exhaust, LED Interior Swap, Pioneer HU, Tacoma TRD Front Suspension, FJ Rear Springs, 10" + 32" Light Bars, Prius Shift Knob, 275/65R18 Falken Wildpeak, 18x9 Level 8 MK6 Et0, GOBI Ladder, 06-09 Headlight Swap, TOTALED NOV 2019, RESURRECTED APR 2020 Build Thread
1998 Volvo S70 T5 - Custom Airlift Suspension, BBS Nebula Wheels, Brada Seats, Engine Bolt Ons - StanceWorks Build Thread
2010 Subaru Forester 2.5X - Wifes Car
JVC8790 is offline   Reply With QuoteReply With Quote
Old 01-23-2019, 06:08 PM #3
Ida4runner Ida4runner is offline
Ida4runner will become famous soon enough
With vibrations happening using different sets of wheels/tires I would look at something like your CV axles or even the steering rack.Anything worn in your front end could lead to vibrations.
Ida4runner is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 11:14 AM #4
JVC8790's Avatar
Real Name: John
JVC8790's Avatar
Real Name: John
Good point on the CV. I had a bad CV in my Volvo that did this exactly, had a bad vibration and I did the usual rotate tires to see if its a tire issue, and then swapped wheels and tires to see if its a wheel centering issue etc.
I'd also look at axle nuts and anything else that can be tightened, possibly something worked itself loose and is now causing your grief.
Following your timeline, it doesn't seem like the issue has come and gone much at all which would lead me to believe that it's something that hasn't been touched that became a problem and hasn't been fixed. There's always the possibility that there was one problem first that got rectified and then this is a second problem that is causing a very similar symptom.
Have you taken the vehicle to a true mechanic rather than a tire shop? Or do you have anyone near by that might be willing to lend you a set of wheels so that you can try on a "confirmed" balanced set that doesn't vibrate on another truck?
Old 01-24-2019, 11:22 AM #5
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
really no help but, i got the falken at3 on the lonestar outlaws & no vibrations at all. did they mount the tires correctly? even tho you tried them on 2 different 4r, have you had the alignment checked? strange that the vibrations go away for a week then come back.
chaz is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 11:34 AM #6
Fern's Avatar
Fern Fern is offline
Fern will become famous soon enough Fern will become famous soon enough
Fern's Avatar
If the vibration didn't change at all with wheel and tire changes. It has to be mechanical as stated above.
2005 4R V8 4x
Fern is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 03:35 PM #7
chaz's Avatar
chaz's Avatar
i would agree but strange that the same problem has happened on both his 05 & 08 4r, also that it goes away for a short period then comes back.
Old 01-24-2019, 03:46 PM #8
JVC8790's Avatar
Real Name: John
JVC8790's Avatar
Real Name: John
Have you had others verify the vibration? Or is it a vibration that you feel and others claim not to feel?
I worked in the automotive service industry for about 5 years and recall a handful of customers that sensed things that were not able to be replicated by a technician. Are you certain that it doesn't happen on just a specific stretch of road, or after a certain type of weather? Or only when it's going a certain speed in a certain gear?
There are just so many variables to consider that you have to thing about when it comes to diagnosing an issue.
Old 01-25-2019, 02:34 AM #9
Samm25's Avatar
Samm25's Avatar
Good question. So before they swapped out the tires to the Michelin AT2ís yesterday, the manager from discount tire drove my truck and even verified that he felt the vibration as well. So he saw first hand what Iíd been dealing with.
The weirdest part for me is that it happened on BOTH of the 4Runners I had. It would go away for about 150-200 miles after they were rebalanced and then would come back.
Old 01-25-2019, 02:37 AM #10
Samm25's Avatar
Samm25's Avatar
Update:
After the Michelin LTX AT2ís were put on, holy crap. Night and day difference so far. No vibration, nothing. Crossing my fingers that it stays this way. According to the manager yesterday he said when they were road force balancing the Michelinís before they put them on, they were balancing SO much better than the Ultra Terrains did.
I donít imagine that it could be possible that I just got a couple of bad batches of tires that wouldnít balance correctly, right?
Iíll keep yíall updated but so far so good on the Michelinís. Donít look too bad either, I was worried theyíd look like a highway tire, but they look decent!
Old 10-06-2023, 06:28 PM #11
Dirty Dingo Dirty Dingo is offline
Real Name: Matt
Dirty Dingo is on a distinguished road
Real Name: Matt
Glad your vibration got better.
I am having a vibration/weird low rumbling noise coming from beneath me. Basically starts the second I get rolling down the road. Stays there even when I put the vehicle in neutral. I recently put on a LT kit in the front. After a couple good weeks of off roading the noise started coming too. I have no clue what it is at this point. I assume the drive shaft continues to turn even when in neutral???
Dirty Dingo is offline   Reply With QuoteReply With Quote
Old 10-06-2023, 10:30 PM #12
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Yes the drive shaft still turns when in neutral, if the wheels are turning the drive shaft is also.
2004 Limited V8
bought , tires , vibration , wheel , wheels
NGK 6619 gaps not consistent? p00flakes 4th Gen T4Rs 4 05-08-2018 12:58 AM
Wheel vibration at 60 to 65 MPH WTERUNNER 5th gen T4Rs 11 07-23-2015 07:30 PM
Humming noise... but isn't consistent jonesmw10 4th Gen T4Rs 3 09-23-2014 10:39 AM
2wd to 4wd shift not smooth or consistent Jersey Woods 3rd gen T4Rs 0 03-11-2012 08:27 PM
Anyone have wheel vibration? Pillar 4th Gen T4Rs 4 02-13-2011 11:40 AM
