01-24-2019, 08:00 PM
New aftermarket front calipers for those with sticking issues
As one who has gone thru Centronics (8 mos) and Cardone (2 years) rebuilt calipers, I'm tired of changing them and yes, I service them yearly with lubricating sliders, flush brake fluid by dealer every two years. So, when I saw that Raybestos was actually making a brand new caliper decided it was worth a try. Unfortunately these are for WG castings only and only the front but the fronts are the ones that have given me the most problem.
Yes, as shown in the pictures, they are made in China which is a big negative but probably unavoidable for something at a reasonable price ($90 each through Rockauto, no core charge). Nicely plated, fittings properly protected, minor hardware included and they visibly look well made (which I know means nothing).
Installed them today, everything bolted right up properly and they are holding pressure, no visible leaks. I'll go to the dealer tomorrow to get a proper brake flush and then track how well these hold up.
01-24-2019, 08:08 PM
Real Name: brian
Real Name: brian
I just picked up a set of new Callahan calipers from amazon, look exactly the same, come with all the clips, slides for 108.00 pair. Put them on yesterday. So far so good.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
01-24-2019, 11:09 PM
The description shows them as remanufactured, I wanted to try something new and see if it made any difference.
01-25-2019, 07:06 AM
Real Name: brian
Real Name: brian
They were not reman. These were brand new castings. The box even said they were brand new calipers. You can tell the difference between a new and reman caliper.
The listing on amazon was incorrect.
Good luck with the raybestos.
06-24-2019, 08:42 AM
Real Name: Matt
Real Name: Matt
Bump... so how are the new calipers working out?
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
07-26-2020, 06:11 PM
Any updates on the Raybestos or Callahan front calipers. My front driver's side (WH) are frozen and need to be replaced.
