Old 01-27-2019, 12:03 PM #1
hntz4x4 hntz4x4 is offline
hntz4x4 will become famous soon enough
Leaf Sprung 4th gen
Hi guys, new here. Trying to help my son find info on his build he has planned for his 07 4runner. He picked up some axles yesterday to start gathering parts to build his rig (Dana 44 front with ARB and Tacoma rear with E-locker). He wants to do leaf springs. I've tried to do a search but can't find on here if anybody else has done it. If you have any links to more info that would be helpful.
Thank You,
Ryan
hntz4x4 is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 02:13 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Is he swapping the front to leafs too?
Huskey's Build - Toyota 4Runner Forum - Largest 4Runner Forum
And a couple on instagram that I know of:
Estevan Jose Fregeau (@estofregeau) • Instagram photos and videos
JD Brittain (@jd_brittain) • Instagram photos and videos
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 02:36 PM #3
Yes that is the plan.
Old 01-27-2019, 03:28 PM #4
Fern's Avatar
Fern Fern is offline
Fern will become famous soon enough Fern will become famous soon enough
Fern's Avatar
Sounds like a build thread is in order!
2005 4R V8 4x
Fern is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 04:05 PM #5
Ida4runner Ida4runner is offline
Ida4runner will become famous soon enough
Have you figured out things like ABS,transfer case and steering issues? I looked into doing sas and when you add just the parts to do it right you're looking at $15k easy with mostly used parts,that's doing all the labor myself.Why not stick to coils/coilovers? I wish you luck and look forward to your progress.
Ida4runner is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 07:52 AM #6
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Sounds like an interesting build, and maybe I’m missing something, but why would you want/need to go through all of that work? I understand wanting to install lockers, heavier cases, etc., but why leaf springs? In my opinion leaf springs are a step backwards in suspension design, especially for handling and articulation. About the only advantage I can even think of is for carrying massive amounts of weight, as it’s easier to build heavier leafs than to source coils for that. Anyway, I’m truly curious about this, so hopefully the OP, or someone else can enlighten me on the reasons why one would want to do this, other than just to be different with the build.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 12:44 PM #7
Inv4drZm's Avatar
Inv4drZm's Avatar
I agree, the only thing that comes to mind is
The Tacoma axle and maybe the front axle is already set up for leafs. Though if you have the expertise you can convert them.
Leafs are easier to retrofit vs links and link mounts. Leafs do the 2 jobs that coils and links do. Locate the axle and support weight.
Old 01-28-2019, 01:11 PM #8
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I’ll be following this one closely… very interested in learning about these types of modifications applied to the 4Runner.
Old 01-28-2019, 02:21 PM #9
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Thank You,
Ryan
wait...What? What is the reason for going with a Tacoma rear axle? I have never seen anyone put a weaker axle on a 4runner than it came with. The typical SAS for a 4th gen is Sterling 10.5 and Dana 60 from an 03+ F350. The reason is because they are already set up for coils and the transfer case is on the correct side AND the full width allows for turning the wheels without impacting the frame. Standard width axles do not allow for this and if I'm not mistaken the Tacoma rear axle housing is bother narrower and weaker than a stock 4th gen rear axle. I happen to have the tacoma e-locker in my truck currently. Its lame. I have already broken the gearset and had to modify the motor after it failed and wore down the copper tracks on the internal gears. Its just a bad idea for trucks this heavy.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 08:24 PM #10
Update. Sold off those axles. Going to do a 3" lift with new UCAs for now. Keep it simple. But he is in the middle of doing a SAS on my other sons 86 4runner.
build , e-locker , find , info , leaf
4th gen leaf sprung SAS t-man 4th Gen T4Rs 32 05-19-2018 11:31 AM
Sprung a leak. But from where? 68whiskey 3rd gen T4Rs 14 11-04-2016 05:57 PM
Need help, she's sprung an oil leak g8rdmd 3rd gen T4Rs 18 12-24-2015 11:41 AM
leaf removal from rear leaf springs 86yoga4runner Engines / Suspension / Wheels / Tires / Audio / Accessories 1 04-18-2014 03:28 PM
I sprung a leak Ekimrm Classic T4Rs 9 03-28-2012 11:35 AM
