Old 04-25-2021, 07:01 PM #16
john123drury john123drury is offline
john123drury is on a distinguished road
So after YEARS of attempting to figure out the issue, I believe I have isolated the problem. Let me say that I tried every single thing an internet search (and forum suggestions) yielded. So all the things like calibration, gas cap, brake booster, electrical lines, sensors, brake light switch, etc. - ALL of it was looked at or replaced and nothing helped.
About a month ago I swapped out my rear brakes and decided to remove the ABS sensors on the bearing assembly (simple one-bolt, pull out removal). They were caked in bearing grease. The REAR wheel bearings are no good. The grease that's been flinging from them internally covered up the rear sensors and caused the issue. I cleaned them, put them back, and the lights now function perfectly as they should. I have since replaced the driver side wheel bearing / axle, and have plans to do the passenger side next when finances allow.
For anyone who has struggled with this issue as long as I have, this may be your solution. Check your rear wheel sensors to ensure they are clean. Hope it helps someone out there in the future.
john123drury is offline   Reply With QuoteReply With Quote
Old 04-26-2021, 05:30 PM #17
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Same lights were on for me, but it was my rear wheel speed sensor/abs wire harness. For any future readers of this thread, a gas cap will NOT cause ABS lights without check engine light!
For OP, if your lights do come back, I suggest you get a code reader that is capable of reading ABS codes and it will point you in the right direction.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
car , dash , fine , lights , start
Dash Warning Lights?Alarm Sound? Hi-Tek RedNek 3rd gen T4Rs 17 07-23-2018 09:23 PM
VSC not engaging, no warning lights on dash Majindan 3rd gen T4Rs 0 06-24-2018 05:45 AM
Dash Warning Lights On <<<< 4th Gen T4Rs 10 04-03-2016 02:10 PM
Dash warning lights staying on? Ill Classic T4Rs 8 02-04-2014 08:16 PM
Dash warning lights lit for apparently no reason... UoD Problems & Warranty Issues 2 02-13-2006 09:00 PM
