Originally Posted by wv_lx450
His was. The switch fell off the lock cylinder and was hanging by the wires
This might be tough to recall, but do you remember what the switch looks like? And is it as simple as disconnecting it?
So it is between the window and the external panel? I see where it all is but don't know what to exactly disconnect.
I have a feeling it might be this solution/issue because I tried rolling the window up with the key but thats when it stopped working. It also is tough to even insert the key without reinserting a couple times (Seems like it gets jammed in there a bit).
