Old 12-30-2019, 05:53 AM #16
Fishead Fishead is offline
Fishead is on a distinguished road
Looks like my image is blocked for some reason...Imgur has an 18+ prompt on it ...guest it may look like something nsfw
Originally Posted by Fishead View Post
This...bulb 900100915 is very difficult to find an LED equivalent with respect to it’s shape (post height) and twist lock size on Amazon etc.
Any recommendations?
I’ve read through almost all 110 pages of HVAC swap thread. Lots of info on LED but much of discussion seems to have started almost 10 years ago with ppl soldering raw leds and making things work. Now there is a mind-numbing multitude of these led’s available on Amazon etc. but neo wedge 3-4 are now being called T3 T4.2 / T5 T10 and so on...with basically zero reference to the replacement oem part numbers. Even the superbrightleds.com do not have the tall post.
Can anyone clarify how they complete led swaps for this particular bulb?
Thanks in advance!
Fishead is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 11:45 AM #17
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Neowedge Instrument Panel Gauge Colored Led Bulbs Lights Lamps | Autolumination
Been going nuts on this site, they have EVERYTHING. The console and climate control lights are 5630 style, t4 for the display, t3 for everything else. They work great, only thing you may need to do is take a small file to the fiberglass board the led is mounted to so it will fit in the hole provided. But beyond that, I've replaced all in the console display, and I'm currently waiting on my next order to update the buttons as well. Those are 5628 t3. Multiple colors, no issue with voltage, I have everything I've installed so far working. Nice to finally SEE the backlights in my buttons, even in daylight.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 04-16-2020, 01:44 PM #18
sidho11 sidho11 is offline
sidho11 is on a distinguished road
How many lumens?
Just bought an 07 4runner and looking at the link in your post, it shows 2 options for 5630 style, 1 at 150 lumens and 1 @ 50. which one did you end up getting as i dont want an overkill of brightness on the panel.
Cheers
sidho11 is offline   Reply With QuoteReply With Quote
Old 04-16-2020, 09:35 PM #19
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
I went with the max brightness. I'm happy with it. I went blue, so it's not hard on the eyes.
Old 04-21-2020, 02:31 AM #20
dsanford dsanford is offline
dsanford will become famous soon enough
Which bulbs did you choose for the HVAC display on Autolumination? Everything else I’ve read is these are 6V T4 and 12V will not work. Every bulb I looked at (all T4, including the tall) show as 12V. Just curious what you used. Pics would be great.
dsanford is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 09:43 PM #21
redninja's Avatar
redninja redninja is offline
redninja is on a distinguished road
redninja's Avatar
Alright, I'm going out of my mind reading page after page after page. All I want to know is how many bulbs, what kind of bulbs, and I want them in white LED for the climate, clock buttons and screen. Please help because I have no lights in my gauge right now and don't want the OEM ones.
redninja is offline   Reply With QuoteReply With Quote
Old 06-07-2020, 12:33 PM #22
White4runner305 White4runner305 is offline
White4runner305 is on a distinguished road
The same thing happend to me you need 2 bulbs. sold on ebay oem factory bulbs perfect brightness solves the problem for under 8$. Installation takes no more than 15 min. I tried going the after market route and the cheap route . I ended up putting in factory oem bulbs and im happy. Anyway id buy these for now and take your time sourcing out a kit for led bulbs or what not.
Look up in case link doesnt work.
Toyota OEM 03-09 4Runner Control Knob Clock Dash Display Bulb 90010-09017 Type C
Toyota OEM 03-09 4Runner Control Knob Clock Dash Display Bulb 90010-09017 Type C | eBay
White4runner305 is offline   Reply With QuoteReply With Quote
Old 06-20-2020, 10:26 PM #23
redninja's Avatar
redninja's Avatar
But, what LED bulbs?
2005 4Runner, Black, New Shocks and Struts, 265/70/17 Falken Wildpeak AT's, Matte Black TRD 17 inch Rims,
Old 11-02-2020, 02:29 PM #24
caeavesrsx-s caeavesrsx-s is offline
caeavesrsx-s is on a distinguished road
Huzzah! https://www.toyota-4runner.org/2196874-post18.html
Per 81Runner
This shows 8 bulbs total.
HVAC and info center bulb information
This shows bulb heights.
Amazon.com: GENUINE TOYOTA OEM COOLER CONTROL CONSOLE BULBS (SET OF 10) 90010-09015 - 90010-09019: Automotive
These are the bulbs.
C = 09017 = T4= NEO4 led Main screen/clock 2 qty (These are the only two with the 6 volt/12 volt concern)
D= 09018 = T3 = NEO3 Reset and Mode 1 qty
A= 09015 = T3 = NEO3 Three control buttons 3 qty
E = 09019= T3 = NEO3 defrost/recirc 2 qty
12Volt mod info:
Concern with only 6 volts going to the main sceen/clock bulbs. Most LEDs need more. 81Runner seems to be working. Read about using non SMD bulbs or doing a "12 volt mod".
Originally Posted by mizak82
I did the 12v mod for neo4 hp bulbs.
Separate the positives on the LEDs. Solder wire to them. Run to a 12 volt source. I chose my accessory wire on my head unit wiring harness. I used a male/female connector so I could remove it easier.
DIY: Interior LED swap (cluster, HVAC, switches, window, *steering wheel)
Originally Posted by USMCEngineer View Post
I used this method to get the Neo 4 HP white bulbs in my info display and it worked great. I ended up using the green wire with silver striping for my 12V source. The wire is on the top row, second wire from the passenger side with the white connector oriented the way it is when it is connected to the HVAC. I have a 04 sport and the inner contacts were also the positive side of the board. I just soldered wires to the positive lead on the LEDs, and then taped up the exposed area. I then used a posi-tap to tap into the 12V wire. I feel this is better than using a regular inline tap or soldering since they just screw together and can be unscrewed and screwed back together as many times as you like
LED vs SMD: What's the difference? LED stands for Light Emitting Diode. ... SMD stands for Surface-Mount Device.
Up next: figure out differences between 5630 and 5628.
Neo Wedge
https://www.superbrightleds.com/more...panel-led/221/
http://www.autolumination.com/instru..._led_bulbs.htm
More info with picture of back of HVAC.
https://www.toyota-4runner.org/2768721-post1537.html
caeavesrsx-s is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 01:47 PM #25
Nashvillerunner Nashvillerunner is offline
Real Name: Jason
Nashvillerunner is on a distinguished road
Real Name: Jason
Go to Youtube and search for Canadian Gearhead and the name of the video is "An Idiots Guide to Fixing LCD Screen and Temp Control Lights". He gives you the link for the Toyota part number and also the video on how to do the install. I did it in less than 10 mins. If you know how to use a screwdriver you can do this.
FJC SUSPENSION/DEBADGED/DDM TUNING 5000K HID KID/DDM 9006 YELLOW LED FOG LIGHT BULBS/YAKIMA MEGAWARRIOR BASKET/265-70-17 FALKEN WILDPEAK MT-01.
Nashvillerunner is offline   Reply With QuoteReply With Quote
climate , control , lcd , numbers , part
Climate Control Panel Backlight Snoug 4th Gen T4Rs 20 08-31-2023 01:35 PM
4th Gen HVAC/climate control backlight out Bushwacka Engines / Suspension / Wheels / Tires / Audio / Accessories 3 11-15-2013 05:08 PM
Climate control backlight dimmer? cmoney 4th Gen T4Rs 6 11-05-2011 07:18 PM
2001 4-runner bulb part numbers for climate control theedudenator 3rd gen T4Rs 1 02-05-2011 01:46 PM
Climate control backlight pingzing 3rd gen T4Rs 3 12-11-2007 12:46 AM
