Old 01-31-2019, 02:26 AM #1
benjamin247's Avatar
benjamin247 benjamin247 is offline
benjamin247 is on a distinguished road
Part numbers for backlight bulbs for Climate Control and LCD
Just bought a 2006 Sport Edition V8 and found that the backlight for the climate control and LCD above (displaying info like MPG and avg speed) is out. The right side of the LCD is out, and for climate control "knobs", the left and center knob lights are out. I found these part numbers in another thread, but I'm not sure which part I need:
90010-09019 long green
90010-09015 long yellowish
90010-09017 short white
Which ones do I need? These are all available on amazon.
Thanks!
1999 Black SR5 5-speed 4WD
Purchased: 3/15/2019
Miles at purchase: 234K
benjamin247 is offline   Reply With QuoteReply With Quote
Old 01-31-2019, 08:17 AM #2
RL Lemke's Avatar
RL Lemke RL Lemke is offline
RL Lemke is on a distinguished road
RL Lemke's Avatar
Keep searching this forum because there is a thread with photos and all details. I found the bulb replacement easy.
RL
Dallas, Texas
2004 4Runner Sport Edition
RL Lemke is offline   Reply With QuoteReply With Quote
Old 01-31-2019, 02:33 PM #3
mikewhiskey's Avatar
mikewhiskey mikewhiskey is offline
mikewhiskey is on a distinguished road
This thread here is very helpful
mikewhiskey is offline   Reply With QuoteReply With Quote
Old 01-31-2019, 02:45 PM #4
TenTwelve's Avatar
TenTwelve TenTwelve is offline
Real Name: Eric
TenTwelve will become famous soon enough
TenTwelve's Avatar
Real Name: Eric
I'm going to break down and get the right lights. I put LEDs in a few spots that were out, but the brightness isn't there.
2007 4.7 Limited - Let the fun begin!
TenTwelve is offline   Reply With QuoteReply With Quote
Old 01-31-2019, 03:33 PM #5
Perfect. Thanks!
Old 01-31-2019, 03:43 PM #6
I found the individual bulbs I need and also this set that contains all bulbs needed to replace all:
https://www.amazon.com/dp/B01HIAZRJS..._k70uCbMTWKSFZ
Buying the bulbs I only need versus buying the complete set will save me $30. Since I'm already replacing some of the bulbs, should I go ahead and just replace all? Will the newer bulbs be brighter than the older, 13 year old, bulbs?
Old 01-31-2019, 05:06 PM #7
Since you're already buying the whole set might as well just replace them all and keep your working old ones as spares. The new ones might be slightly brighter than the old if the little colored condoms on the bulbs are cooked
Old 01-31-2019, 07:30 PM #8
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker is a name known to all AuSeeker is a name known to all AuSeeker is a name known to all AuSeeker is a name known to all AuSeeker is a name known to all AuSeeker is a name known to all
Real Name: Skip
Keep in mind that the Limiteds with the dual climate controls have a little different bulb layout than the single climate control.
Look at the diagram below, the bottom is the bulb layout for both the Limited (Dual) and the SR5 (Single).
Part numbers for backlight bulbs for Climate Control and LCD-4-runner-ac-control-jpg
2004 Limited V8
Old 08-10-2019, 10:45 AM #9
DRVOVRU DRVOVRU is offline
Real Name: GL
DRVOVRU is on a distinguished road
MY GARAGE
Real Name: GL
MY GARAGE
The diagram is awesome and is exactly what I was looking for. These lights appear to be a continous issue and I would think this would be a great sticky. Along with the URL for removal step by step that is here. Center Console Lights
GL - Iowa
You can fix stupid... its just a felony
DRVOVRU is offline   Reply With QuoteReply With Quote
Old 08-23-2019, 09:53 AM #10
Christomy95 Christomy95 is offline
Christomy95 is on a distinguished road
Number of bulbs to purchase
I haven't taken apart the console yet but I'm wondering if anyone can tell me how many bulbs I need to buy to replace the lights for the climate control section.
Christomy95 is offline   Reply With QuoteReply With Quote
Old 08-23-2019, 07:18 PM #11
Real Name: Skip
Real Name: Skip
If you read my post above you should know that it varies depending on what model you have, the diagram I posted show the bulb layout and part numbers for the different bulbs needed for the Limited model and the SR5 which will be the same for a Sport Edition as well.
That being said you should be able to determine which bulbs and how many you need from the diagram, no one here can give you that answer because we don't know which model you have!
Also note that no matter which model you have you will need several different bulbs to replace them all.
2004 Limited V8
Old 08-23-2019, 07:21 PM #12
royal T4R royal T4R is offline
royal T4R is on a distinguished road
Sounds like you need less resistant resistors or better LED's
royal T4R is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 02:31 PM #13
CV4RNR's Avatar
CV4RNR CV4RNR is offline
Real Name: Richard
CV4RNR is on a distinguished road
MY GARAGE
CV4RNR's Avatar
Real Name: Richard
MY GARAGE
Thanks for the diagram- Exactly what I needed!
CV4RNR is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 02:02 PM #14
IRONLUNG IRONLUNG is offline
IRONLUNG is on a distinguished road
What would be the LED equilvalent (superbrightled) for bulbs A, C, and D? Do you use 3mm T-1 for all?
IRONLUNG is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 05:46 AM #15
Fishead Fishead is offline
Fishead is on a distinguished road
This...bulb 900100915 is very difficult to find an LED equivalent with respect to it’s shape (post height) and twist lock size on Amazon etc.
Any recommendations?
I’ve read through almost all 110 pages of HVAC swap thread. Lots of info on LED but much of discussion seems to have started almost 10 years ago with ppl soldering raw leds and making things work. Now there is a mind-numbing multitude of these led’s available on Amazon etc. but neo wedge 3-4 are now being called T3 T4.2 / T5 T10 and so on...with basically zero reference to the replacement oem part numbers. Even the superbrightleds.com do not have the tall post.
Can anyone clarify how they complete led swaps for this particular bulb?
Thanks in advance!
Fishead is offline   Reply With QuoteReply With Quote
climate , control , lcd , numbers , part
4th Gen HVAC/climate control backlight out Bushwacka Engines / Suspension / Wheels / Tires / Audio / Accessories 3 11-15-2013 05:08 PM
Climate Control Panel Backlight Snoug 4th Gen T4Rs 16 10-07-2012 02:29 AM
Climate control backlight dimmer? cmoney 4th Gen T4Rs 6 11-05-2011 07:18 PM
2001 4-runner bulb part numbers for climate control theedudenator 3rd gen T4Rs 1 02-05-2011 01:46 PM
Climate control backlight pingzing 3rd gen T4Rs 3 12-11-2007 12:46 AM
Copyright © 2019
