Old 10-18-2020, 05:15 PM #1
RD9146 RD9146 is offline
RD9146 is on a distinguished road
4wd problem 4th Gen
Newby just purchased a 2007 v6 very clean 100K. When I switch to 4H both green &yellow lights flash and is not in 4wd. If I push the diff lock (take a little bit to come on) it turns both lights solid and turns off vsc (light comes on). It looks like the transfer case accuater is brand new. It also appears the lock switches to 4wd. I don't have a qwners manual yet. Any help would be great. Thanks Rick
RD9146 is offline   Reply With QuoteReply With Quote
Old 10-18-2020, 05:25 PM #2
montijo505's Avatar
montijo505's Avatar
If it's going into 4hi when you lock the diff then it works. Try letting it roll slightly forward when the lights are blinking. Usually helps. Sometimes if it's taking too long I'll put it in drive and very slowly ease off the brake and then it'll clunk into 4hi.
Sent from my SM-G986U using Tapatalk
Old 10-18-2020, 05:52 PM #3
Thanks for the reply, It does not appear to engauge when I switch to 4H while driving. I have tried it from a dead stop and same thing both lights just flash. The last time I tried 4L from a dead stop in netural they flashed and it was beeping. It looks to have a new transfer case accuater I could not see if the front one was replaced.
Old 10-18-2020, 07:02 PM #4
metramm metramm is offline
metramm will become famous soon enough
If the lights are blinking, then it isn't engaging correctly.
Try shifting from 2wd to 4wd high with a slight roll.
Mine takes a few seconds to engage.
For 4wd Low, you need to be completely stopped before shifting. If it is beeping, then there is a problem and the 4wd isn't fully engaged.
There should be no beeping and you should have the 4wd indicator on the dash (when shifting into 4wd high).
Sometimes the actuator gets stuck so shifting from 2wd to 4wd and back again multiple times frees it up.
try this and let us know how it goes.
Metramm
2006 4Runner Limited 4x4 v6
241,000 miles and counting!
metramm is offline   Reply With QuoteReply With Quote
Old 10-18-2020, 07:35 PM #5
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Try steering left and right to help the gears mesh.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 10-18-2020, 08:12 PM #6
2007 4runner v6 4 wheel lights (green&yellow) flash when switched to 4h
I may have not explained that I just bought it and it appears the transfer case accuater was replaced (looks brand new). Could it be installed improperly?
Old 10-19-2020, 03:28 AM #7
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
IF the new unit cogs aren't timed correctly, then the little shafts that engage the 4wd system won't engage all the way. A dealership or Toyota specialty shop should be able to verify that tho.
I only have the AWD model, so my 4wd option is either hi or low.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 09:41 AM #8
4 wheel problem
Thank you will take to dealer. Rick
Old 10-19-2020, 04:26 PM #9
Piggity Piggity is offline
Piggity will become famous soon enough
Try rolling the vehicle in Neutral then go from 2H to 4H. Mine intermittently doesn't want to go into 4H while I'm in drive. It sure doesn't help when I'm at higher speeds but it normally works well for me. 2L requires the vehicle to be at a dead stop.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 10:39 PM #10
CameronMagee's Avatar
CameronMagee CameronMagee is offline
CameronMagee is on a distinguished road
Following
2008 Toyota 4Runner SR5 4WD | V6 | 32,727 Odometer | Grey/Grey
CameronMagee is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 11:22 PM #11
o9T4R's Avatar
o9T4R o9T4R is offline
o9T4R is on a distinguished road
o9T4R's Avatar
Having same issue with mine. 2009 V6 4x4 with only 82k miles....
I noticed at around 75k miles when trying to engage into 4h/4LO that it was taking a bit more time than usual to switch over, but would eventually go with doing the normal forward to reverse method....but now it wont engage at all no matter what.. Pretty disappointed for this to be happening at fairly low mileage. I dont have the time or space to be able to work on it so I took it to a local Toyota/Lexus shop near me and dude was telling me its the actuator in the rear not up front? Anyways , he quoted me 800 to get it fixed. Will probably end up going this route cause I refuse to take it to the stealership.
2009 4Runner Limited V6 4WD
Mods- Too many
o9T4R is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 08:59 AM #12
m3y3rRunner m3y3rRunner is offline
m3y3rRunner is on a distinguished road
This is a very common issue with the 4th gen design. With lack of use the mechanism gets "gummed" up and will get stuck. Many people on the board subscribe to the process of putting the truck into the different modes, 4HI, Diff Lock and 4LO once a month to make sure all the actuators stay exercised.
There is a bunch of threads on here on solutions. Replacing, manually moving with force or electricity, etc.
I bought a 08 Limited V6 with a bad timing chain and had been sitting for quite some time. I had the same issue and followed the electricity thread and was able to get it back to functioning.
Fixed my T-Case actuator w/ electricity and logic.
Good luck, hopefully it doesn't cost you too much money to get it sorted. Replacing can be expensive as the part is not cheap $500-1000 and involves removing and splitting the transfer case.
Matt
m3y3rRunner is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 09:48 AM #13
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Yeah, mine seems finicky at times as well. I have the best luck switching from 2H to 4H while moving, either at a crawl or ~35mph going down the road. I believe the manual says you can engage it up to 60mph.
Most recently it didn't want to disengage. The lights just kept blinking. Came to a stop, switched the dial back to 4H, starting driving slowly down the road and switch it back to 2H and it switched almost instantly.
I think the only thing is that you need to keep the wheel straight while it's engaging/disengaging, is that correct?
Like someone said above, I try to use the system once a month just to keep thing lubed up, but it does seem to be a finicky system.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 01:08 PM #14
Brentcollins Brentcollins is offline
Brentcollins is on a distinguished road
Yea manual says you can engage 4hi up to 65 MPH. 4hi you need to be rolling a little bit to engage. 4lo needs to be stopped in neutral. Mine always takes a little longer to engage the first time but after running all day on the trails it will go between 2wd, 4hi, and 4lo in a second. Just needs to get warmed up a little bit.
Brentcollins is offline   Reply With QuoteReply With Quote
4wd , lights , lock , transfer , turns
New 4th Gen owner ABS Problem Youtube video of problem soloone Problems & Warranty Issues 4 08-11-2016 12:01 AM
Is this Tacoma problem a problem on 4Runners? SavageRunner 5th gen T4Rs 4 09-02-2014 04:25 PM
Brake problem and Lock problem Fldivemaster16 4th Gen T4Rs 3 05-15-2013 03:45 PM
Brake problem and Lock problem Fldivemaster16 3rd gen T4Rs 1 05-14-2013 02:09 PM
A/C Problem 2003 bigger problem with Stealer sambo989 4th Gen T4Rs 2 07-04-2008 11:00 PM
