Real Name: Ron
Real Name: Ron
If the battery is more than 3-4 years old or so, it's 95% a bad battery. That's how they fail; work one day, flat dead the next, give it a jump and it's good for a day or two, and so on. Basically the plates get thin and you get intermittent open or short circuits internally. These days I have a "1 strike your out" policy on old batteries.
If it's not the battery it's probably a bad connection at the battery. Clean the connections until they're bright and shiny and reassemble.
Fire your crack diagnostic crew at your dealer.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
