Old 02-01-2019, 03:12 PM #1
skywalker1020 skywalker1020 is offline
skywalker1020 is on a distinguished road
Will a driver's door from a 2003 fit my 2008?
I bought my 2008 about 1.5 years ago. Low mileage, one owner, clean CarFax - a beauty!
Apparently, the driver door had been damaged at some point and repaired shoddily. There were two symptoms: the door opens too far and contacts the hinge, and a little "bump" that occurred every time I rolled the window eventually turned into a "thump" then a "crack."
I took the car in to have the window looked at and they informed me that the door check device was coming loose because of the earlier damage and crappy repair. The metal frame of the door is twisted inside and the solution is to put on a new door.
Short story long, I found a door at a local junk yard in the right color for $130, but it is from a 2003 or 2004.
Should I be able to swap this door in?
I have all of the pieces to the current door so I can swap out the door handles and locks, body cladding, window, etc...
Thanks!
2008 4Runner Urban Runner V6 4X4
1999 4Runner Limited V6 4X4 (Sold)
1994 4Runner V6 4X4 (Sold)
skywalker1020 is offline   Reply With QuoteReply With Quote
Old 02-02-2019, 04:20 PM #2
2003-4x4runner's Avatar
2003-4x4runner 2003-4x4runner is offline
2003-4x4runner will become famous soon enough
Thanks!
The door should fit in theory, but the 2008 body cladding may not fit and the electrical connectors may not fit. I'm not 100% positive, but that's what I would be worried about.
A few years back, I bought a engine harness from a 2007 for my 2003 and all the connectors were different.
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
2003-4x4runner is offline   Reply With QuoteReply With Quote
Old 02-02-2019, 04:25 PM #3
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Expect to swap out all electronics. I would be surprised if all the window regulator stuff is different. Cladding should swap over as well. I doubt they would change the mounting holes. Compare part numbers to be safe.
door , put , solution , swap , window
Driver door handle won't open door anymore? Jason B 3rd gen T4Rs 19 07-08-2016 12:54 PM
Driver door .. key does open driver door only werminghausen 3rd gen T4Rs 11 03-26-2015 03:39 PM
2003 4Runner Driver Door Unlock Issue 2003T4Runner 4th Gen T4Rs 0 11-14-2010 12:55 PM
2008 driver side turn signal out! 2Crunk 4th Gen T4Rs 4 05-05-2010 09:15 AM
2003 Driver side door lock not unlocking ajjaaron Problems & Warranty Issues 6 11-25-2008 07:38 PM
