Old 02-02-2019, 12:58 AM #1
truckhigh's Avatar
truckhigh truckhigh is offline
truckhigh is on a distinguished road
truckhigh's Avatar
transmission output shaft bearing replaceable???
I'm working on my buddies 06 2wd v6 and it has a very loud roaring and vibration. i tore down the driveshaft to replace the u joints and it has a lot of play at the transmission output shaft. It looks like i might be able to pull off the tail end to replace the shaft bearing. but i see gasket material at the rear section above the transmission mount.
Does anybody know if the tail end can be pulled to replace a bearing and if it needs to be pressed???
04 4runner Sport Edition V8
-MODS- Maxtrac Lift Spindles | Bilstein 5100/5160| Tacoma frt springs | MT LT 3in reat springs | eBay UCA | SS brakelines | 4crawler body lift | 17 level8 punch | At3 315/70/17 | K&N cai | black clazzios |
Build thread
truckhigh is offline   Reply With QuoteReply With Quote
Old 02-02-2019, 03:42 AM #2
truckhigh's Avatar
truckhigh's Avatar
digging in more I found that the extension housing is removable and and the fluid is probably going to come out. i only found a number for a tacoma extension housing bearing and saw bushings also.
I'm trying to help a buddy who's lift i did does anybody have any info???
like would that bearing cause play in the drive shaft like a bad u joint when there isn't that much play when the driveshaft is out.
Build thread
Old 02-02-2019, 07:54 PM #3
4RunnerMexico 4RunnerMexico is offline
4RunnerMexico is on a distinguished road
How much play are we talking about here?
I have two 2WD 4Runners, they both have some play at the transmission extension housing...
Ive chased driveline noises in both of them, ended up being a rear diff and then rear wheel bearings in the other...
Put the rear on jack stands, chalk the front wheels, put the truck in drive and then wach the drive shaft for any movement.
Edit: On one 4runner the first time i felt the play in the extension housing I freaked out and thought it was a lot, but my other truck felt the exact same way, so I figured it was normal
4RunnerMexico is offline   Reply With QuoteReply With Quote
bearing , output , replace , shaft , transmission
front axle output shaft bearing... Schady44 3rd gen T4Rs 7 05-17-2018 06:07 PM
Inner cv shaft bearing,,differential bearing replacement razerface 4th Gen T4Rs 5 03-25-2018 09:27 PM
Front diff output shaft bearing opie74 3rd gen T4Rs 2 10-01-2013 08:31 PM
HELP! How to-Rear Transfer case output Beari (Tail Shaft Bearing) 4runnertank Classic T4Rs 13 08-10-2012 10:16 PM
help!!!!!! loose output shaft Red2ndgen Classic T4Rs 4 03-14-2012 02:16 AM
