Old 02-06-2019, 03:32 PM #1
anonymousgromers's Avatar
anonymousgromers anonymousgromers is offline
Real Name: Brody
anonymousgromers is on a distinguished road
Real Name: Brody
New problem with steering
First it was a grinding sound coming from the right side when I turned right now its extremely hard to steer left or right
I just had my dealer replace the pwr steering fluid a few weeks ago no air is in the system either any ideas on what could be causing this stiff steering?
2004 toyota 4Runner limited 4WD 4.7L V8 | Gibson cat back exhaust
2004 Toyota 4Runner Limited 4.7L V8 | Practically stock | Gibson cat back exhaust
anonymousgromers is offline   Reply With QuoteReply With Quote
Old 02-06-2019, 06:53 PM #2
Gatafly Gatafly is offline
Gatafly is on a distinguished road
Try spraying a lubricant into the u-joints for your stearing shaft. You can get to it through the driver side wheel well or from underneath driver side if I remember correctly. If that fixes it just be aware that you may have to do it again in a week or two then it should be fine. This is assuming the u-joint is not beyond help. I had this happen 4 years ago and bought a new half shaft, but sprayed it while i waited for it to arrive. I ended up spraying it 3 times and never had a problem since. Still have the new shaft in the box, lol.
Gatafly is offline   Reply With QuoteReply With Quote
Old 02-06-2019, 07:16 PM #3
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
2005 4Runner Stiff Steering - Toyota 4Runner Forum - Largest 4Runner Forum
Steering Column U-Joint
Greasing steering intermediate shaft U joints
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 02-06-2019, 07:32 PM #4
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
I sprayed some lube in mine then added grease on top of it and it's much better. When it warms up I will probably replace it. I think I'd find a new dealer if they don't know about this common issue.
Here's a video about the issue.
YouTube
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 02-07-2019, 04:27 PM #5
Real Name: Brody
Real Name: Brody
Yeah the tech was with me outside and straight up said he doesn't know what it is the second nearest dealer is over a hour away from me I'll take a look at these suggestions and see if I can figure it out also when they put the fluid in they never topped it up and they got some air in the system brought it back they fixed that and now its overfilled New problem with steering
air , causing , ideas , steering , system
05 4Runner Steering Problem gargan333 4th Gen T4Rs 28 05-07-2015 03:59 PM
05 4 Runner Steering Problem gargan333 Problems & Warranty Issues 4 03-08-2011 07:28 PM
steering problem profuse007 3rd gen T4Rs 3 08-09-2007 06:28 PM
Steering Problem sswv Problems & Warranty Issues 5 06-06-2007 10:08 AM
85 4R steering problem garey Classic T4Rs 1 05-02-2007 12:18 PM
