View Poll Results: Pick a tire size
255/80R17 6 16.22%
255/80R17
6 16.22%
275/70R17 14 37.84%
275/70R17
14 37.84%
255/75R17 5 13.51%
255/75R17
5 13.51%
265/70R17 12 32.43%
265/70R17
12 32.43%
Voters: 37. You may not vote on this poll
Old 02-06-2019, 06:07 PM #16
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Originally Posted by BagiMT View Post
I am very happy with my 255/70R17 LR C but was looking at 255/80R17. There are two factors to consider when choosing a tire, size and load range. If you off-road a lot or carry a lot of weight you probably want LT tires in the C-E range. But E rated tires are stiff and heavy. Generally larger tires (e.g. 285/70R17 in LR E) can result in a loss of 2-3 mpg (compared to stock), don't know how important that is to you.
One of the biggest limitations when choosing tire size is availability. Most brands only come in some of the sizes you listed (and 255 are generally harder to find) and not always in the load range you want. That was what led me to pick the 255/75R17 over a 255/80R17.
Thanks for the explanation. The Falkens happen come in all the 4 sizes.
I'm flexible when it comes to load range. I wouldn't mind a firmer ride.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 02-06-2019, 06:26 PM #17
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
I'm rocking a 255/80/17 shod in Cooper ST MAXX (33") had to push some fender liner in a bit but still had more rubbing then I wanted. I ended up buying some MetalTech body-mount chop plates and cut the front body mounts and welded in the plates...fixed my rubbing issues and it is solid as can be...Best $20 I have spent in a long time...tho the time for welding always makes one questions justifications :P
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 02-06-2019, 07:39 PM #18
andreylights's Avatar
andreylights andreylights is offline
andreylights will become famous soon enough
Originally Posted by Berty_K View Post
Lol. Well now I'm in totally sure what my lift is.
My hub to fender before lift was 17.6, and now its 20. Xould my suspension have been sagging 1.5 inches?? This would mean in reality I have a 1" lift.
I'm confused.
Yeah that's a question I am working on as well. According to my measurements my lift is 2.5" which means I could run 255/80r17 but it is 2.5 comparing to a 12 years old set of coils which is not a correct comparison any more.
andreylights is offline   Reply With QuoteReply With Quote
Old 02-06-2019, 11:56 PM #19
Primetime4370's Avatar
Primetime4370 Primetime4370 is offline
Primetime4370 will become famous soon enough
I'm also in a similar boat. I'm looking at going to a 255/75/17 or a 265/70/17.
Leaning more towards the 255 in a Duratrac though. At a cost of just over $50 a tire more than a 265 Wildpeak.
Primetime4370 is offline   Reply With QuoteReply With Quote
Old 02-07-2019, 10:32 AM #20
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
I have the 255 75 17 and they perform awesome off road and moving forward its a comfy ride w good looking profile. I'm glad I have to wheel offset for them because maneuvering into corners or side to side on road they feel hippies (with a 3" lift too) but it isnt bad.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 08:24 PM #21
hstexan's Avatar
hstexan hstexan is offline
hstexan will become famous soon enough
hstexan's Avatar
I've got a 2" lift, so not quite what you're going to run and chose 275/70/17. I had to trim the fender liner and a very, very small sliver off the outside edge of the front bumper too. I also had to remove the mudflap, but that got me enough clearance and did not require the BMC. Now that it's done I'm happy...I had to trim more than I thought and I elected to straight up take it off rather than try to force it forward enough to get out of the way.
2006 Toyota 4Runner Limited 4x4 V6 Shadow Mica Sold
Dobinsons Suspension 300/221 Front & 505/637 Rear | FN Wheels f(x) pro | BFGoodrich KO2 275/70/17 | Front Runner Slimline II | ARB 2000 | Gobi Ladder | Treeline Outdoors Tamarack RTT
hstexan is offline   Reply With QuoteReply With Quote
Old 02-09-2019, 12:51 AM #22
Berty_K's Avatar
Berty_K's Avatar
I'm a fan of your stance
Sent from my SM-N950U using Tapatalk
Old 02-09-2019, 03:39 PM #23
YetiX's Avatar
YetiX YetiX is offline
Real Name: Scott
YetiX has a spectacular aura about YetiX has a spectacular aura about YetiX has a spectacular aura about
YetiX's Avatar
Real Name: Scott
Originally Posted by Bumbo View Post
6112 front, one down from the highest setting. (1/4" spacer on driver side only)
OME 2895 rear coil
17" OEM FJ rims
No fender mods
No BMC
No rubbing from lock to lock
Fits a full size spare in the stock location (it’s getting snug, but I think I can make an 80 fit)
Do you have, or could you take, a picture of your 4Runner from the side? I am about to install exactly your lift and tire size so I'd like to get an idea what it'll look like.
(I currently have the 6112 set at mid-height with FJ springs in the rear.)
-Semper Fi-
2006 4Runner Sport Edition 4WD V6/Suspension/Armor/Lights/Wheels and tires/Drawers/Camping things/Surfboards/Rhodesian Ridgebacks . . .
BUILD AND ADVENTURE THREAD
YetiX is offline   Reply With QuoteReply With Quote
Old 02-09-2019, 09:14 PM #24
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Old 02-09-2019, 09:23 PM #25
YetiX's Avatar
Real Name: Scott
YetiX's Avatar
Real Name: Scott
Perfect, thanks! That's exactly what I'm hoping for. Thanks again.
-Semper Fi-
Old 02-09-2019, 09:32 PM #26
Bumbo's Avatar
Bumbo's Avatar
I should have mentioned it's sitting on some 255/75/17 size tires.
Old 02-10-2019, 12:10 PM #27
YetiX's Avatar
Real Name: Scott
YetiX's Avatar
Real Name: Scott
That's what I'm thinking of going with next. Right now I'm on 265/70.
-Semper Fi-
bilstein , move , springs , tires , trd
3" Lift/leveling kit tire size j0nb0n Toytec Lifts 1 09-25-2014 01:19 AM
Tire Size with 3" lift Layne.Saliba 3rd gen T4Rs 4 12-25-2012 01:26 PM
Biggest tire size for '04 w/ 2" lift BenSD 4th Gen T4Rs 2 12-23-2012 08:29 PM
"Best" tire size after lift/leveling kit install? NAdams65 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 07-05-2010 09:38 AM
Tire size advice for Daystar 2.5" lift jsmarine 3rd gen T4Rs 14 12-19-2009 08:55 PM
