Old 02-07-2019, 03:46 PM #1
Smurray Smurray is offline
Smurray is on a distinguished road
Air Fuel Ratio Sensor and o2 Sensor Replacement - P0136 and P2195
Dash cluster did a fun light show. Have a long drive ahead of me this tomorrow so brought it to the stealership by work. The codes that hit were Air Fuel Ratio Sensor and o2 Sensor. They quoted me at about $1200 which was comical. Found what I believe to be each part on amazon from Denso for about $200 total (model #234-4261 is o2 sensor and 234-9051 is AFR sensor).
I have found a few different guides for 3rd gens or different located sensors on 4th gens but was hoping for a little help here. Does any one have any experience with these jobs or have any guides on hand? Is there anything else I might need in the way of parts? I know this isnt an imperative fix but I would like to do it myself and get it done right.
07 V8 SE
Smurray is offline   Reply With QuoteReply With Quote
Old 02-07-2019, 05:03 PM #2
djpope09 djpope09 is offline
djpope09 will become famous soon enough
07 V8 SE
I don't have any experience with the V8, but on the V6 there is an AFR and O2 sensor on each side so 4 sensors total. The AFR sensors are harder to get to since they are against the firewall.
Just go out to your truck and look for them. Look in the engine bay and follow the exhaust manifolds down until you see the AFR. Then get under the truck and lookfor the O2 sensors on the exhaust. They should all be visible.
djpope09 is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 09:53 AM #3
Levinz11 Levinz11 is offline
Levinz11 is on a distinguished road
This is an easy job. Buy the correct OEM/Denso sensors and an O2 wrench.
Two are behind the fender liners on each side. My Runner is lifted and I could change them by just reaching above the tire. Other two are easily found under the truck. Might want to hit them with penetrating fluid for a few days before attempting removal. I didn't have any issues getting mine out. Use the supplied anti-sieze!
2003 SR5 V8 4WD. 173K.
1995 SR5 Limited. 3.0, 4x4, 5 spd., 210k, BFG 32x11.5 KO's
Levinz11 is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 03:28 PM #4
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
I changed both on the driver's side a year ago. As said, the rear O2 sensor is accessible from under the truck. Might want to drive it up on ramps for easier access.
Best way to get to the front AFR sensor is through the wheel well. Put the front of the truck on secure jack stands and remove the wheel; that will make the job a lot easier. An O2 sensor wrench helps - I used a crow's foot wrench that also worked well.
The hardest part on the front sensor for me was figuring out how to activate the connector release. It's hard to see the tab you need to press, and to get your hand in there in such a way so as to apply adequate force.
I did not have to use penetrating oil and had no trouble breaking them loose, but my truck has essentially no rust underneath.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 02-25-2019, 10:24 AM #5
Is there a way to verify the correct Denso part number for these codes? I have been researching for days and I can't seem to find a straight answer.
I ordered Denso 234-9051, 234-4261, and an o2 socket off amazon. I am now having my doubts about the correct part number.
Old 02-25-2019, 08:21 PM #6
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Go on a online Toyota parts store that uses your VIN to search for the proper part #s. I usually use Conicelli Toyota Conicelli Toyota of Conshohock | Genuine OEM Toyota Parts
air , found , fuel , gens , sensor
H02 Sensor (Bank 1 Sensor 2) P0136 Code??? petepup Maintenance/Detailing 32 01-06-2023 06:49 PM
Fuel ratio sensor gone bad PCF4runner 3rd gen T4Rs 5 03-23-2016 09:41 PM
Introduced P0171 by Changing Upstream Air/Fuel Ratio Sensor aawolf 3rd gen T4Rs 10 02-22-2015 03:22 PM
Air-Fuel Ratio (A/F) Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) vipblades 3rd gen T4Rs 33 10-25-2014 11:06 AM
99 4runner: Do I need an Air/Fuel Ratio Sensor or O2 Sensor? SPFCCMT 3rd gen T4Rs 2 08-05-2014 11:59 AM
