Old 02-07-2019, 07:55 PM #1
wmflyfisher's Avatar
wmflyfisher wmflyfisher is offline
wmflyfisher is on a distinguished road
No heat in floor when switch pressed??
Having an issue with the heat in my 05 V8. Pressing the heat switch for the floor does nothing. The light comes on but it doesn’t switch over. Couldn’t find much from searching. Any ideas? Is this blend door hard to get to?
Thanks
wmflyfisher is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 03:11 AM #2
andreylights's Avatar
andreylights andreylights is offline
andreylights will become famous soon enough
Can you switch the air flow to any other setting? Does the defogging work?
andreylights is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 09:41 PM #3
No. I just checked and it’s not blowing out the defrost either. Only the front vents for whichever button I press.
Old 02-08-2019, 10:50 PM #4
46runner's Avatar
46runner 46runner is offline
46runner has a spectacular aura about 46runner has a spectacular aura about
46runner's Avatar
May be the servo motors. DIY: Replace Servo Sub-Assy
46runner is offline   Reply With QuoteReply With Quote
Old 02-09-2019, 01:01 AM #5
Wow thanks for that. Helpful if that’s the issue. I just investigated the issue more and determined that the heat does blow in the floor when you switch it to floor mode but it doesn’t shut the face vents. They remain open. The defrost vents never open though... I’m puzzled on how to even diagnose what the issue is...
Old 02-09-2019, 03:13 AM #6
Can you hear anything when you switch the flows? If it only blows in one direction despite selecting different modes it could be as simple as the HVAC actuator.
Old 02-09-2019, 09:33 AM #7
Nope I can’t hear anything. No clicks or sounds.
Old 02-09-2019, 10:16 AM #8
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
It sounds like your blend door servo/actuator is stuck/or died in between floor and vent postions leaving the blend door paritally open in each position.
2004 Limited V8
Old 02-09-2019, 12:40 PM #9
Do you know which specific servo controls that function?
Old 02-09-2019, 02:54 PM #10
Real Name: Skip
Real Name: Skip
If you click on the link @46runner post above he has not only posted the location of the blend door servo/actuator/motor and also the temperature servo/actuator/motor, he also gives you part numbers and a step by step tutorial with photos on replacing them.
2004 Limited V8
Old 02-09-2019, 04:18 PM #11
Sithrebel15 Sithrebel15 is offline
Sithrebel15 is on a distinguished road
I ****ing hate working on those. It's such a tight space and if it's not the very bottom one good ****ing luck unless you have baby sized hands.
Sithrebel15 is offline   Reply With QuoteReply With Quote
couldn’t , find , floor , heat , switch
Shuddering When Gas Pedal is Pressed CowboyBob 3rd gen T4Rs 6 11-14-2017 06:00 PM
Stupid question. Seat heat switch light. How do you remove the switch? Gavin S. 4th Gen T4Rs 6 02-15-2016 02:02 PM
No Floor Heat Coming Out? Wiring Harness. flojules 4th Gen T4Rs 2 02-04-2014 08:50 PM
Seat Heat Switch - 4th Gen 4Runner bigdon Maintenance/Detailing 4 12-14-2013 10:02 AM
