Old 02-08-2019, 07:20 PM #1
CanuckinTX's Avatar
CanuckinTX CanuckinTX is offline
Real Name: Sam Korman
CanuckinTX is on a distinguished road
CanuckinTX's Avatar
Rear Window Exploded
Hello, (Writing this on behalf of a friend)
This morning I was driving to work and my rear window broke. I had the defroster on and it just poped out of no where. I called my Toyota dealership and they said that the recall had expired in April of 2018.
Have any of you guys had luck with your Toyota dealers? And if so how?
Thanks
Sam
____________________________________________
2004 Toyota 4runner Sport Edition 4x4
Galactic Gray
Mods: Weather Tech Mats, CB radio, Treaty Oak Offroad Recovery Points, and Garmin 65w Dashcam
CanuckinTX is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 07:44 PM #2
tom4416 tom4416 is offline
tom4416 is on a distinguished road
There are several long threads on this issue and the consensus seems to be that no, Toyota is not venturing beyond any warranty periods, much as with the cracked dash and headgasket failures. They fear doing one out of the warranty period (extended or regular) will create a cascade of lawsuits from others that were denied. I understand their concern but wish there was some middle ground on these types of obvious problems - something like them paying for the parts and owners paying for labor. It's not ideal but it's better than fronting the entire costs of the rear window replacement. Many of us have pulled the rear defroster relay to prevent this from happening - an easy thing in Tucson, AZ, not so much in areas with snow and frost
tom4416 is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 09:01 PM #3
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
TSB-0189-17 "Rear Hatch Glass Shattered" - Toyota 4Runner Forum - Largest 4Runner Forum
Rear Window Shattered. For NO REASON!
Rear window busted by defroster...read here!
Well my rear hatch window shattered from the defroster
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 12:52 PM #4
atalarico's Avatar
atalarico atalarico is offline
atalarico will become famous soon enough
atalarico's Avatar
What's the out of pocket cost to get this replaced?
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
atalarico is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 01:26 PM #5
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
It happens… I disabled my rear defrost because of reports like this… not interested in paying out of pocket for a repair or fix.
Old 02-11-2019, 03:15 PM #6
nuron nuron is offline
nuron is on a distinguished road
Where is rear defroster relay located?
nuron is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 06:03 PM #7
BR06run BR06run is offline
Real Name: Bill R.
BR06run is on a distinguished road
Real Name: Bill R.
Join the club.Happened to us about two months ago.Same story we had the defroster on and boom. No Toyota won't do anything about it. We tried.Pull the defroster fuse instead of the relay and you can still use the heated mirrors. Haven't heard of those exploding. A non OEM glass should be in the $260 range depending on who does it. Actually they call it a OEM glass ,it's just not a Toyota glass which would cost a whole lot more. We used Glass America. We were happy with them.
BR06run is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 09:04 PM #8
CanuckinTX's Avatar
CanuckinTX's Avatar
Update:
He ended up just filing with insurance. Thanks for the help.
Galactic Gray
Old 02-27-2021, 02:24 PM #9
HIMILESV8SPORT's Avatar
HIMILESV8SPORT HIMILESV8SPORT is offline
HIMILESV8SPORT is on a distinguished road
how did you disable it? can I just pull the 30amp fuse?
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
HIMILESV8SPORT is offline   Reply With QuoteReply With Quote
Old 02-28-2021, 10:55 AM #10
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
Angry
As we have seen many times before Toyota will not on their own fix any problem, unless it’s a safety item and then only if the government forces them.
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 09:56 PM #11
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
There was never a recall for this issue, there was a TSB and a limited Customer Support Program (CSP/Extension of Warranty) but nothing else.
The way I understand it, after the whole debacle with the unintended acceleration thing; they're really skittish to do anything regarding recalls/CSPs unless they absolutely have to because of the ambulance chasers chomping at the bit for an excuse for a class action against Toyota or any other company they feel they can take to court.
Post Note-
From what I remember of a lot of those threads (it's been a few years and I haven't been as active as I used to be for various reasons, so I apologize for being a bit rusty) a lot of the failures seemed to be due to excessive resistance at one of the solder points on the glass. Thinking on it, my rough guess is that the weather stripping on the rear glass wears out/dries up and allows corrosion to form on that and when you go to use it, POP! instant hot spot on a tempered glass causing it to shatter. :/
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 07:02 AM #12
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Totally disagree with this statement. Toyota is the absolute best at taking care of their customers. Try Chrysler if you want a company that runs from their responsibility. No car company stands behind their vehicles better than Toyota. Try again.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 10:31 AM #13
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
So I saw something about this originally on Reddit. Does someone have a fuse layout that shows which fuse to pull to disable it?
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 02:14 PM #14
lightfreak lightfreak is offline
lightfreak will become famous soon enough lightfreak will become famous soon enough
Lower the rear window about 3/4 the way down, then Pull the cover off the tailgate, peel back the vapor barrier back a bit and unplug the 2 defroster connectors from the glass. Cover and secure them to prevent future electrical problems. The connectors are on the passenger side of the glass.
This way your side mirror defrosters will still work.
What I did was every year or so, I’d clean out those connectors with battery terminal cleaner foam and compressed air. After reconnecting put a liberal dab of dielectric grease on them to help block out water and road salt.
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
lightfreak is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 02:51 PM #15
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Pulled the fuse on mine.
Engine bay.
After that spat of rear windows blowing up.
Never use it anyway.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
dealers , rear , recall , toyota , window
How-To: Replacing an exploded rear window emoore924 4th Gen T4Rs 18 11-02-2021 06:38 PM
BOOM! Rear window exploded this morning emoore924 4th Gen T4Rs 52 10-11-2018 03:15 PM
Rear diff exploded...kinda. owyheerat 3rd gen T4Rs 14 07-24-2018 04:18 PM
Rear brake lines exploded while bleeding brake fluid benztech82 4th Gen T4Rs 3 08-11-2017 08:16 PM
Rear hatch exploded??? fightman80 3rd gen T4Rs 5 08-10-2011 10:59 PM
