Old 02-10-2019, 08:43 PM #1
f250ben f250ben is offline
f250ben is on a distinguished road
A/T Oil Temp light came on, in 4wd, with diff locked, driving on the beach
Soooo this happened today. Not sure if this is a big deal or not, but here's the background.
206K miles, limited maintenance history. I've had the vehicle for about 8K miles, its had no drivetrain issues that indicated poor maintenance or abuse, but its not one of those impeccably maintained vehicles with service records every 5K for the life of the vehicle.
Drove about 10 miles down the beach Saturday, camped saturday night. Tire pressures low at 12 PSI, sand wasn't too soft. Kept 4WD and center diff locked the whole time. No problems.
Broke camp this morning, raised tire pressures to 20PSI because 12 was too low, and not stable. Drive another 15 miles down the beach. A/T oil temp light came on right at the end for about 30 seconds. I was cruising between 20 and 40 depending on the sand conditions. It came on right after a bout of cruising at 35-40ish.
Light went back off, code reader didn't find any codes. Nothing leaking or broken underneath, I didn't hit anything. We turned around and drove 25 miles back on the same beach with no issues, and drove another 150 miles back home. No further problems.
What do I do next? I'm not sure if this was a fluke from driving too fast with the center diff locked, or what. I feel like i need to at least do a full tranny flush/fill. Really not sure what to do past that. Is this an actual indicator of a potential problem, or could this have been a non-problematic fluke?
Obligatory pic of the rig on said beach trip...A/T Oil Temp light came on, in 4wd, with diff locked, driving on the beach-dscn0191-jpg
f250ben is offline   Reply With QuoteReply With Quote
Old 02-10-2019, 08:59 PM #2
note: This was at Padre Island National Seashore on the South Texas Coast. Temps were in the high 40's today on the beach.
Also, I'm not sure how long the light was on before I noticed it, but it went off within 1 minute of me noticing it. Seems to me the temps couldn't have actually been too high, they would have taken longer than that to cool down again?
Old 02-11-2019, 10:34 AM #3
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
were you driving those speeds in 4l or 4h?
hinmo24t is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 03:04 PM #4
ghs215 ghs215 is offline
ghs215 is on a distinguished road
Transmission fluid is dyed red. You need to get a sample of your fluid and check against the color chart (google it).
Dark brown or black ATF can be an indicator of a transmission problem, vehicle abuse, or fluid that has far exceeded its useful life.
2006 4Runner SR5 4x4 V6 Shadow Mica => Mrs
2006 4Runner SR5 4x4 V6 Titanium Metallic => Mr
2012 Sequoia SR5 RWD 5.7L Magnetic Gray Metallic => "I get to drive it! (says hubby) No! I get to drive it! (says wife) Happy Wife - Happy Life
ghs215 is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 03:06 PM #5
Levinz11 Levinz11 is offline
Levinz11 is on a distinguished road
Eh. Probably no biggie. If in 4hi you might have been riding with the torque converter unlocked.
I've done some time on the Outer Banks and used 4low so it would grab a gear and stay there.
Get a USB dongle and start watching those tranny temps.
2003 SR5 V8 4WD. 173K.
1995 SR5 Limited. 3.0, 4x4, 5 spd., 210k, BFG 32x11.5 KO's
Levinz11 is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 04:11 PM #6
shmabs shmabs is offline
shmabs is on a distinguished road
If you were in 4 hi, and letting the transmission shift itself, a high temp is not out of the ordinary.
As others have mentioned, if 4 low works for the situation then use that. Also, pick a gear that works well for your given speed, and use that. At the speeds you described, I can imagine your transmission was probably shifting a lot, which generates heat.
shmabs is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 04:15 PM #7
when people talk about selecting a gear (4,3,2,L) the truck will shift only up until the gear selected and not beyond it? you dont start in 2,3, or 4 or else you wouldnt move right?
Old 02-11-2019, 04:30 PM #8
I'll have to go try to be 100% sure, but my understanding that the gear you select is the highest gear the truck will shift into. For example if you select 3 from a stop, the truck will shift 1-2-3 as speed and rpm increase, but will not go beyond 3.
Thinking back to yesterdays adventure in the snow, that seems correct.
Old 02-11-2019, 04:35 PM #9
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Not normal in my experience, but it could also be a fluke.
I drive around pretty regularly in heavy sand, both in 4Hi and 4Low and in hot desert environments… have yet to see any AT temp warnings.
Probably best to proceed with a fluid change and keep monitoring.
Old 02-11-2019, 04:35 PM #10
Legender Legender is offline
Legender is on a distinguished road
That is how my 4.7L Tundra works. Only has D 2 and L... sometimes I drop it too far and it ends up in 2nd. Won't shift above that, but then RPMs tell me something is wrong. I don't get but a few yards when I notice so no over revving.
2005 SE V8 FWD 177k
Legender is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 04:37 PM #11
Bumbo's Avatar
Bumbo's Avatar
That is correct… you are selecting the max gear and it starts off in 1st gear.. I do this often to prevent bogging down in the sand from an up shift or to hold a gear at speed.
back , beach , drove , light , miles
No VSC OFF light when center diff locked rjb75 4th Gen T4Rs 4 06-27-2015 12:11 PM
Navigatin/Phone contacts locked while driving! socal4rnr 5th gen T4Rs 11 10-08-2010 03:42 PM
Beach Driving SnoboardingDave 4th Gen T4Rs 5 06-30-2006 02:23 AM
What else do you need for beach driving? seancgn68 Off-Roading 7 08-11-2005 08:37 AM
Driving while locked gonzo 4th Gen T4Rs 7 09-09-2004 09:14 AM
