Old 02-12-2019, 05:17 PM #16
Troymclure's Avatar
Troymclure Troymclure is offline
Real Name: Jake
Troymclure is on a distinguished road
Troymclure's Avatar
Real Name: Jake
Originally Posted by WhiteBoomer04 View Post
Here's my recommendation - speak to people who build and use roll cages and get their opinions. While not discounting the views of forum members who may or may not have worthy advice, see what people in the business say about your considerations. You mention the KOH build. Reach out to them, or their builder of the cage (Otwell) - they are all great people and have solid knowledge of what may or may not work for YOU. Then post back their thoughts.
Agreed. There is definitely a benefit to a cage in terms of safety in high speed crashes. The only downside for a street driven vehicle that I know about is lower speed safety in a crash. Less crumple zones and a more rigid vehicle with cage is no doubt safer if you roll at 80+ mph, but in a rollover around 40 mph, you can sustain more injuries from the stiffer body/chassis. With that said, only the OP can determine if their use would justify a cage, and the resulting trade offs that accompany it.
Troymclure is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 06:31 PM #17
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Thanks for this post, and I did call Otwell after you mentioned it.
Interesting conversation... basically we talking about cost as a financial limitation will often times be a stopping point, some options and logistics between internal vs external cage, tube bumpers front and rear… I need to put together some requirements and design goals before really getting into this.
He did a good job with helping me manage expectations with a project like this… basically if I wanted something to help protect from a roof collapse in a low speed roll, the requirements would obviously be a lot different than something that would need to pass inspection or certification for a certain type of race.
Considering I’ve toyed with the idea of an external cage before, and the fact that it does cost less from a fabrication standpoint, I would consider doing something like this just to add a little extra protection. The next real question is whether or not it is in my budget.
He also didn’t have any particularly negative to say about doing this on a street vehicle… but I do agree and understand some of the concerns about crumple zone and rigidity.
Old 02-18-2019, 01:25 AM #18
BlairB's Avatar
BlairB BlairB is offline
Real Name: Blair
BlairB will become famous soon enough
BlairB's Avatar
Real Name: Blair
Definitely want to echo what has been mentioned about never running a real cage (versus a simple roll bar in back) while not wearing a helmet.
If you roll a caged vehicle without a helmet that can very quickly turn into a fatal accident when you may have walked away without a scratch in a completely stock vehicle. Steel tube obviously has zero give and hitting your head on that during a roll over (or getting t-boned etc...) is not something you ever want.
Also, many (most?) injuries in roll-overs are not actually caused by roof deformation, but rather your head being in contact with the roof when the roof hits pavement. Think similar to diving into a shallow pool.
A cage is part of a safety system, and if you do it you should finish the system. That means helmet, full harness, race seat etc...
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
BlairB is offline   Reply With QuoteReply With Quote
Old 02-18-2019, 01:43 PM #19
Bumbo's Avatar
Bumbo's Avatar
Yes, I see that now. The keyword being “system”… you can’t really have one without the others. Without a seat and harness to keep you in place, solid metal bars all over the inside of the cab isn’t helping.
The idea of an exo-cage has really been growing on me… at least for a low speed roll or in an event where I was just to lay it on its side crawling. I could possibly maintain a regular interior, and provide some added protection from a roof collapse. Even minimize body damage, just have someone winch me back upright and off you go.
At least for how I envision myself using the truck, seems like a good middle ground because a properly done internal cage / system doesn’t really match my use case for this thing.
Any concerns or comments with a properly built exo from someone like Ottwell?
I don’t know how crazy I would go, but Otwell did make the comment, Considering the application / users desired use case, if it’s not something they would consider to be save, they would most likely decline even building the thing.
Some photos off google images for visual examples...
Old 02-18-2019, 01:51 PM #20
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Agreed. Hitting your head on a bar during a rollover may be a guaranteed fatal event. On the 4th gen, an even MORE fatal idea would be an internal cage that can be displaced by the airbag system. Imagine that instead of an airbag cushioning your head, one of the bars gets damaged in the rollover and then pierces your head when the airbag accelerates it directly at you. Imagine the scene in Final Destination where the airbag causes the girls head to fly at the broken end of a pipe.
It is my opinion that NO internal cage of ANY TYPE should be used where there are airbags nearby. Internal cages with airbags is possibly the worst idea I have ever read on the internet.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
off-road , pretty , roll , safety , truck
85-89 4R roll bar in my 3rd gen... Andy in Pa 3rd gen T4Rs 3 12-26-2017 01:42 PM
1st gen roll bar in 2nd gen 4runnerBrett Classic T4Rs 15 11-17-2013 04:19 AM
WTB first gen roll bar Robmills72 Want to Buy/Trade 5 11-06-2013 03:02 PM
wtb: 1st gen roll bar Zachpins34 Want to Buy/Trade 0 12-24-2011 02:40 AM
3rd Gen Roll Bar Big John Classifieds - buy & sell (no commercial ads please) 0 03-24-2010 07:43 PM
