Old 02-11-2019, 08:57 PM #1
tthrower1 tthrower1 is offline
tthrower1 is on a distinguished road
4 Wheel Drive Flashing Lights
I just had the actuator motor replaced on my 2008 4Runner. The system will function correctly now and will go into 4wd but the lights on the dash continue to flash like it’s not working. The light will turn solid when I push the differential bypass button. When I turn the differential back off, the rear light will flash. No problems with going into 4lo. It seems something is not calibrated or set right. The mechanic doesn’t know what to do. Any help or suggestions is greatly appreciated.
2008 4Runner Sport w 4.0L V6.
Thanks!
tthrower1 is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 11:32 AM #2
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
This is very likely not the issue since you seem to know what you're talking about, but just to cover all our bases: When switching modes, the engine is running with the gearshift in NEUTRAL, correct?
Montego Murph is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 12:47 PM #3
blackjackck's Avatar
blackjackck blackjackck is offline
Real Name: John
blackjackck will become famous soon enough
Real Name: John
I second this comment that I don't think this is the case as you seem to know what you're talking about BUT..... Did you switch to "D" and go slowly down the block to see if the blinking stop?
2008 V6 4x4 Sports Edition / Build Thread/ FJ Off Road Package, 265/70/17, 2012 FJ Wheels, Husky Liner, LED bulbs, Spare Bumper -current////// SOLD Past vehicles:1996 V8 Landcruiser Rebuilt; 1988 Jeep Wrangler- 2 inch lift with 33' tires; 1976 Jeep CJ 7 (inline 6) - Frame off restoration
blackjackck is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 03:24 PM #4
BagiMT's Avatar
BagiMT BagiMT is offline
BagiMT will become famous soon enough
BagiMT's Avatar
Thanks!
It's possible that the timing on the actuator is slightly of. Strange though that you are only having issue in 4Hi. To go from 2Hi to 4Lo you have to engage both 4WD (same as 4Hi) and 4Lo (there are two rods on the actuator). As @blackjackck said, first try engaging 4Hi and drive for a bit to see if blinking stops. It's normal for it to blink for a while when you first engage it and driving rotates the gears and lets it to engage.
Black 2008 Sport V6 4WD | Toytec BOSS 3/2 | JBA UCA | BFG KO2 255/75/17 | Rocksteady Skids | White Knuckle Sliders | TJM Front Bumper | Superwinch
BagiMT is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 10:10 PM #5
Thank you for the feedback. I have driven for several miles and the flashing is consistent. I’m wondering if a sensor is going bad or timing maybe? There was some discussion about resetting the ESU unit after replacing the actuator but I don’t know how to do that.
Old 02-13-2019, 02:10 AM #6
BagiMT's Avatar
BagiMT's Avatar
There is a timing switch inside the actuator that tells the 4WD ECU what position the actuator is in. If that switch is off the ECU does not know that 4WD has been engaged. The switch position can be seen from the outside, all you have to do is remove a small metal cover. When in 4Hi the blue mark lines up with the black mark. If it does not you have a timing issue. More details in this thread:
Water in actuator, now stuck in 4lo, and how to fix it
I am still confused why 4Lo would work but 4Hi not. Another thing to consider is that there is a second actuator on the front diff that needs to engage when you switch to 4WD. If that one does not engage (or was in the wrong position when the new actuator was installed) you might also get a flashing light as the ECU gets confused. If you had a mechanic install it I would have him deal with this before you mess with the new actuator.
Old 02-13-2019, 08:48 PM #7
One to add. After locking in the differential and when O unlock the differential, the green 4wd light will stay on but the yellow 4wd light will start blinking again.
Old 10-02-2024, 12:29 PM #8
hungryfobz hungryfobz is offline
hungryfobz is on a distinguished road
I know this is an old thread but were you able to find the issue? I have the exact same issue. I replaced the front transfer case actuator because it was shot. Everything works fine but the light is still flashing.
hungryfobz is offline   Reply With QuoteReply With Quote
4runner , differential , flash , light , turn
4wd dash light flashing, safe to drive? Mighty Buffalo 3rd gen T4Rs 5 08-11-2015 03:13 PM
green 4 wheel drive light doesn't come on, 4 wheel drive doesn't engage 4Runnerswa 3rd gen T4Rs 7 02-10-2014 01:51 PM
4 Wheel Drive light keeps flashing bluebaron 5th gen T4Rs 11 01-19-2013 03:27 PM
4 wheel drive indicator flashing rutledj 3rd gen T4Rs 10 11-30-2011 08:25 PM
My 2002 4 Wheel Drive Lights are stuck on and flashing? jimvertigorm3 3rd gen T4Rs 0 01-09-2010 12:34 PM
