01-31-2019, 06:15 PM
Conservative leveling kit
Howdy folks. I would appreciate some recommendations for a modest leveling kit, likely a 2/1. I'd like to keep the price modest too - but fully understand that sometimes "you get what you pay for." Thus, I don't necessarily want the cheapest thing out there either. Thanks in advance.
01-31-2019, 07:22 PM
Why are you wanting to go with a level vs an actual lift?
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
01-31-2019, 07:26 PM
I recommend the Daystar kit. I've had no issues with mine.
I suspect some others may chime in recommending the Toytec or Cornfed equivalents. I can't argue with them. From what I can tell they are pretty much the same thing. I went Daystar because it was the best price at the time.
Be healthy.
Be nice.
Do interesting things.
2008 4WD SR5 V8. 2.5/1.5 Daystar. 265/75R16 Duratracs #UZN215
01-31-2019, 07:28 PM
Subscribed.
A 2/1 spacer kit should be fine with Xreas suspension, no?
I’m just looking for getting closer to level and fitting 32’s.
2008 4wd V6 Limited Xreas - 2.5/1.5 Daystar - 17" TRD Wheels w/ 255/75-17 BFG KO2's - NFAB Steps - Debadged and 5th Gen REbadged - Maplight Mod - Interior LED Swap - LaminX Yellow Fogs - Gobi Stealth - Powerstop Z36 Brakes - Husky Liners - DeWalt Bluetooth Dongle - Blackedout Headlights with LED's
01-31-2019, 07:48 PM
To the best of my knowledge, yes; the spacer kits will work with Xreas.
Be healthy.
Be nice.
01-31-2019, 11:32 PM
Real Name: Ron
Real Name: Ron
I have a Daystar kit in mine with XREAS. Works great and didn't affect the ride noticeably. Good for light to moderate offroad, but not for severe.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
02-01-2019, 04:03 PM
get the kyb oem replacement kit off amazon. total with assembled fronts is under $300. they lift the front 1" and ride kickass
02-05-2019, 05:49 PM
Good question! My answer is that, in all honesty, I'm not completely sure what I want! I'm still pretty new to the game.
What I want to accomplish is this: I think I want to level the slightly nose-down stance of my truck. I don't know if there's a concrete, practical reason to do this; it just kind of bugs me a little to look at. Having said that, if there is an operational or safety-oriented reason NOT to do that, I would of course like to know that!
The second reason I'm thinking about it is that when I go to replace my current all-season tires with an all-terrain tire, I might want the option of going with something a size (or two at the most) bigger.
Thanks for all the helpful suggestions folks!
02-05-2019, 06:26 PM
Is there any adjustment to this kit? The previous owner replaced my suspension with a KYB kit, but the front still has the drop.
My truck is like yours, the nose needs some lift but I don't know how high I would want to go. I'm thinking of new front springs and the Bilstein adjustable shocks below that give from 0 to 2.5" of height.
Check out the reviews with pictures.
https://www.amazon.com/Bilstein-24-2...words=Bilstein
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
02-05-2019, 06:39 PM
on my 2016 runner I used 2 coil spring spacers on the pass side and 1 on the driver side.
coil spring pass side is smaller sized so I used smaller spacer than the driver side driver side coils bigger so bigger spacer..
why did I do this ???? the springs took a set dropped about 1 inch.. also the brake dive ,,, well all is good and I have no problems .. I had to pay $20 for the spacers and I had to cut the spacers so they fit perfect...
after the work I noticed the CV boots looked very good, nice straight,,,,,,,,, no rubbing on the boot sides ..much less brake dive..
suspension did not change much on ride quality very comfortable ..
it is unusual that this post did not get much feed back on your lift ..
02-05-2019, 10:14 PM
im going to start with 1" front strut top spacers to give 2" of front lift.
that was the difference in front to back from top of wheel to fender arch on my vehicle. I didnt figure frozen camber bolts into the budget, so i have to revisit with parts in hand including control arms to get the spacers fitted.
02-05-2019, 10:56 PM
I highly recommend Bilstein leveling struts. If your 4Runner has north of 100k miles I would do new springs as well. I have mine set at 1.75 and it sits about perfectly level with the rear, maybe a tad bit of rake to the nose. I did new springs in the rear as well. It drove like new, due to replacing the stock suspension that had 175k miles on it. I thought about going the spacer route but fact was my struts were just shot and needed replaced regardless.
I plan on moving a size up in tire, to 265/70-17. If I ever want to go bigger, the struts will be adjusted to the top setting and a 1.5” spacer added to the rear springs.
02-06-2019, 11:27 AM
Real Name: John
Real Name: John
I just did the same install as Bluesky in this thread, ended up with a 1.75" front 1" rear lift and leveling, allowed me to delete the Xreas as well. I just updated my build thread (in my signature) with a few pictures of my install.
https://www.toyota-4runner.org/3195449-post2.html
2004 4Runner V8 Limited - TRD Exhaust, LED Interior Swap, Pioneer HU, Tacoma TRD Front Suspension, FJ Rear Springs, 10" + 32" Light Bars, Prius Shift Knob, 275/65R18 Falken Wildpeak, 18x9 Level 8 MK6 Et0, GOBI Ladder, 06-09 Headlight Swap, TOTALED NOV 2019, RESURRECTED APR 2020 Build Thread
1998 Volvo S70 T5 - Custom Airlift Suspension, BBS Nebula Wheels, Brada Seats, Engine Bolt Ons - StanceWorks Build Thread
2010 Subaru Forester 2.5X - Wifes Car
02-07-2019, 01:22 PM
I bought my 4Runner with 136k miles on it and the shocks were toast. Like the OP, I didn't like the nose down and looked at different options for leveling. Not all of us want to lift our vehicles, we just want the level look. I went the Bilstein 5100 route, reusing my stock springs. I replaced all 4 shocks and the truck is nice and level and rides great. I have almost 50k miles on them now and I still think it was the correct decision.
Ryan
2004 4Runner SR5 V6 | 198k miles | Bilstein 5100's, front @ 1.75" | 245/75-17 Michelin LTX MS2 | FJ Cruiser steel wheels
