Old 02-14-2019, 11:16 AM #1
SCT2018T4R SCT2018T4R is offline
SCT2018T4R is on a distinguished road
Random loose line on right side of engine bay V8
I found a loose line on the right side of the engine bay on my 2005 V8. Nothing else looks out of place and I can't see anywhere this line should go. Does anyone have a guess as to what this is?
Any idea how to attach a picture to this thread that's over the 136kb limit?
SCT2018T4R is offline   Reply With QuoteReply With Quote
Old 02-14-2019, 11:42 AM #2
DZNUTS DZNUTS is offline
DZNUTS will become famous soon enough
Without seeing a picture, I would say it’s the line that feeds your muffler bearing fluid
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
DZNUTS is offline   Reply With QuoteReply With Quote
Old 02-14-2019, 12:40 PM #3
Well obviously...what was I thinking.
Old 02-14-2019, 12:49 PM #4
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
That's on the driver side!
It's the blinker fluid breather.
In all seriousness start an Imgur account and upload your pics there.
Old 02-14-2019, 01:56 PM #5
TenTwelve's Avatar
TenTwelve TenTwelve is offline
Real Name: Eric
TenTwelve will become famous soon enough
TenTwelve's Avatar
Real Name: Eric
Yeah, there's a TSB.
2007 4.7 Limited - Let the fun begin!
TenTwelve is offline   Reply With QuoteReply With Quote
Old 02-14-2019, 05:15 PM #6
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
another option, if you have a PC, is to reduce the picture by using the built in Microsoft Photo editing software. You can reduce it for "web" or "document" or "email" setting. I usually use the document setting before uploading it to a forum board.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 02-14-2019, 11:59 PM #7
Thanks for the Imgur idea. Here's a couple picture links. This is on the drivers side between the battery and front of the engine block.
Imgur: The magic of the Internet
Old 02-15-2019, 12:24 AM #8
Mrtranxd Mrtranxd is offline
Mrtranxd is on a distinguished road
thats a breather hose. perfectly normal. probably clips into those two clips not holding anything.
Mrtranxd is offline   Reply With QuoteReply With Quote
Old 02-15-2019, 01:00 AM #9
vipergrhd's Avatar
vipergrhd vipergrhd is offline
vipergrhd is on a distinguished road
vipergrhd's Avatar
Differential breather
That is clip on the fender just below the fuse box, make sure the cap is lose so heat can escape from diff. housing.
vipergrhd is offline   Reply With QuoteReply With Quote
Old 02-15-2019, 08:35 AM #10
Ahh ok. The cap is definitely not loose. I assume it should work something like a one way valve to let heat escape?
Old 02-15-2019, 04:00 PM #11
RobD RobD is offline
RobD will become famous soon enough RobD will become famous soon enough
You're actually trying to relieve pressure. When the gear oil heats up, it expands and needs to vent somewhere. The valves are normally a one way device and sometimes get stuck closed. If they don't have the ability to vent, they can push fluid past seals.
As an example: https://s3-media2.fl.yelpcdn.com/bph...KSZifXQ/ls.jpg
RobD is offline   Reply With QuoteReply With Quote
Old 02-16-2019, 10:27 AM #12
Thanks for the help everyone.
bay , engine , line , loose , side
Loose driver side mirror nalbertasr5 3rd gen T4Rs 4 10-31-2019 05:18 PM
Loose side mirror base? T4R2014 3rd gen T4Rs 3 05-28-2017 09:33 PM
Loose Vacuum line above rear end. psraff 3rd gen T4Rs 10 07-17-2016 02:22 PM
broke trans cooler line loose from radiator. how do i flush the transmission homeinspector 3rd gen T4Rs 6 12-01-2014 06:51 PM
Hood loose on drivers side Smalss 3rd gen T4Rs 13 11-04-2009 07:51 PM
