I have a 5th gen so not sure if my input would be much help. I run Hikari 9600lm LEDs in my low beams and fogs. Both H11s. The low beams alone were not that bright, but with the added LED fogs, I'm happy with it.
For my low beams, I tried at least 4 sets from Amazon, but anything over 40mm width does not fit in the housing. Plus, the bulb needs to be clockable/rotatable as the diodes need to point 9 and 3 for maximum brightness because the bulb goes in sideways. Not sure why this low beam housing was designed this way.
Anything will fit in the fogs, but shorter cables will be nicer because the passenger lining has vents and the connections could get wet if it's dangling.
This was a good site to get info from:
BulbFacts | Compare headlight bulbs all in one place!
