Old 02-16-2019, 09:42 AM #1
lj4r lj4r is offline
lj4r is on a distinguished road
2004 V6. 4.0 squealing so badly it is setting off car alarms
Well I am stumped. Something on the front of our 2004 V6 4.0 is squealing so badly it is waking the dead. I had the hardest time tracking down the source. I thought I tracked it to the upper driver’s side idler pulley. I changed the upper driver’s side idler pulley with oem. Still squealing. I removed the upper passenger and lower pulleys. Both seemed fine. Tensioner pulley seems fine. All spin smoothly. Alternator is solid. Power steering has a little in and out play but spinning it is tight.
I intend to replace the upper passenger side pulley with oem I want to change the lower with oem but can’t find a part number. Also what is the tensioner pulley oem part number. Are there any alternatives to oem for the tensioner pulley?
Any secrets for tracking down the source of the squeal? Thanks. Stumped in San Diego. Phil
lj4r is offline   Reply With QuoteReply With Quote
Old 02-16-2019, 11:20 AM #2
Real Name: Skip
Real Name: Skip
Go to your autopart store ($10) or even better yet go to Harbor Freight (less than $5) and buy yourself an inexpensive mechanic's stheocope, it will be money well spent, it will come in handy for finding all those squeaks, squeals, knocking and tapping noises that are hard to pinpoint, just be very careful with the probe end around moving parts, belts, fans and etc. but if you're careful you will find the squeal.
Everyone that works on and or troubleshoots their vehicles needs to have one in their toolbox, you will wonder why you have never bought one before.
Mechanic's Stethoscope
2004 Limited V8
Old 02-16-2019, 12:27 PM #3
Ida4runner Ida4runner is offline
Ida4runner will become famous soon enough
Spray your belt with water,if the noise goes away it's your belt,if not it's a idler or your a/c, Alt,water pump or power steering is going out.
Ida4runner is offline   Reply With QuoteReply With Quote
Old 02-16-2019, 02:32 PM #4
BagiMT's Avatar
BagiMT BagiMT is offline
BagiMT will become famous soon enough
BagiMT's Avatar
The Gates 36174 is a replacement for the lower. There is no replacement for the tensioner pulley but I used the same Gates 36174 and it worked ok. The alternative is to replace the bearing or the whole tensioner assembly. See here for details:
Tensioner pulley on V6, does 36174 work?
https://www.amazon.com/Gates-36174-I.../dp/B001FHQZDI
Black 2008 Sport V6 4WD | Toytec BOSS 3/2 | JBA UCA | BFG KO2 255/75/17 | Rocksteady Skids | White Knuckle Sliders | TJM Front Bumper | Superwinch
BagiMT is offline   Reply With QuoteReply With Quote
Old 02-16-2019, 03:52 PM #5
JoeToyota's Avatar
JoeToyota JoeToyota is offline
JoeToyota is on a distinguished road
JoeToyota's Avatar
Finding high pitches squeaks/squeals can be difficult even with a mechanics stethoscope, but if your careful and methodical it can help a lot to rule things out and track down noises. They are certainly a must have tool in my opinion.
Before you do anything else you need to test and check the serpentine belt in every which-way. The belt is what will tell you where to look for the problem. Here is a good read.
2006 4Runner Sport V8
JoeToyota is offline   Reply With QuoteReply With Quote
Old 02-24-2019, 12:21 AM #6
Well after changing out both top idler pulleys and the bottom idler pulley with oem, picked them up on eBay for about $27 each. still screaming. A run to O’reilly’s for the gates tensioner pulley. Still screaming. Finally installed the new oem belt, current belt has 15,000 miles on it. Well that was it. The v6 is purring once again. I will hang on to the pulleys that I removed and keep them as spares. Toyota does not sell the tensioner pulley. They only sell the full assembly. I picked up a gates 36174 at O’reilly’s for $70. Probably could have saved $30 had I ordered it online.
Use your oem bolt and washer. Remember the tensioner pulley bolt is reverse thread.
I did pick up a stethoscope at harbor freight $3.99. Much safer than using a long screwdriver.
The various threads on the forum on pulley swaps were really helpful.
All the best.
Phil
oem , pulley , side , tensioner , upper
5100 top setting vs. stock setting with spacer RioRunner 5th gen T4Rs 9 09-10-2016 07:09 PM
Engine Alarms MattinLA 3rd gen T4Rs 10 02-16-2014 09:08 PM
Car alarms??? Troutsrunner 3rd gen T4Rs 2 03-23-2013 09:51 AM
Car Alarms, Necessary? JohnsD90 3rd gen T4Rs 23 08-04-2009 12:58 AM
Are Car Alarms Worth It? Iman74 4th Gen T4Rs 12 03-25-2004 06:56 PM
