Originally Posted by DZNUTS
For starters, the BMC doesn’t cut up anything g supportive to speak of. It just trims away a bit of steel that isn’t really needed. You can then replace it by welding in a new piece or just leave it open.
As for UCAs, JBA makes a great product. However, the UCAs they sell for non-lifting trucks is does not add any caster. In order to have additional caster you’ll need to install the UCAs designed for lifted trucks as well as lift your truck
I'll admit, I haven't really looked into what the BMC entails, I just don't like to cut stuff if I don't have to. As for the UCAs, I know it would have to be the ones that have extra caster designed in. From my understanding, lifting the trucks causes a loss in caster at ride height. So, the arms have more built into them by default. In theory, that would just mean that I would have an excess of positive caster at a lower lift height, right? Would this be so much that I would end up with a front end that could not be aligned properly? From reading around, more positive caster increases straight-line stability and steering effort. I'm thinking about just running with the slightly too positive caster for a little while until my XREAS dies or I decide to lift it early.
