Old 09-03-2020, 12:19 AM #16
DASYOTA DASYOTA is offline
DASYOTA is on a distinguished road
Originally Posted by TravThePro View Post
You can get a decent metric tap set from AutoZone for $30, that's what I would recommend if you aren't a machinist. If an M8 bolt goes all the way through with pushing, I would say that an M8 tap is off the table (you can still try that first if you want, but it will most likely fail). Make sure you drill centered with the correct bit before you try and tap an M10.
If you're not sure what bit to use, they have many charts that show the correct bit for each thread size. Here is a link to a place with several charts: 23 Printable Tap Drill Charts [PDF] ᐅ TemplateLab
Good luck, let me know if you have any questions.
Alright cool appreciate it, I'm going to give the m10 a shot and get some new bolts. Saw on the chart M10 x 1.25 suggests an 8.9mm bit so i'll have to find that size at home depot.
DASYOTA is offline   Reply With QuoteReply With Quote
Old 09-03-2020, 01:26 AM #17
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
I’d use a helicoil set for the m8 bolt. Buy a kit off of eBay for $15.
The inserts are stainless steel and won’t rust.
royal T4R is offline   Reply With QuoteReply With Quote
Old 09-03-2020, 11:09 PM #18
amitchell24 amitchell24 is offline
amitchell24 is on a distinguished road
Hit it with some PB Blaster daily, torch it and JB weld a new bolt head on there. Should come off with that kinda combo.
amitchell24 is offline   Reply With QuoteReply With Quote
bolts , curious , plate , remove , skid
What to do when you have stripped skid plate bolts. 2012sr5 5th gen T4Rs 54 03-07-2022 07:02 AM
Stripped the bolts on the factory skid plate.... now what? audiness 4th Gen T4Rs 18 07-21-2020 12:21 AM
Stripped skid plate nut willo 5th gen T4Rs 6 12-30-2018 07:11 PM
Stripped/Seized Bolts on Skid Plate! modelstudent101 3rd gen T4Rs 8 03-30-2015 02:57 PM
Stripped skid plate holes - Helicoil or not? Fumbler Maintenance/Detailing 2 12-06-2008 07:02 PM
