Old 02-18-2019, 06:33 PM #1
anonymousgromers's Avatar
anonymousgromers anonymousgromers is offline
Real Name: Brody
anonymousgromers is on a distinguished road
Real Name: Brody
Stripped bolts on skid plate
Okay pretty much every bolt on the front skid plate under the oil pan and filter are rounded and was wondering how to remove them. I've never had to remove stripped/rounded bolts before so am curious on how to do so.
2004 toyota 4Runner limited 4WD 4.7L V8 | Gibson cat back exhaust
2004 Toyota 4Runner Limited 4.7L V8 | Practically stock | Gibson cat back exhaust
anonymousgromers is offline   Reply With QuoteReply With Quote
Old 02-18-2019, 06:40 PM #2
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
Soak em good with your favorite penetrating oil and if you can still get channel locks on the heads, you might be able to get em free. Chances are they'll just shear off, though. Then you're looking at drilling them out and re-tapping the holes, or, if the welded nut breaks or you damaged the nut drilling, you're going to need to drill them out and use some nutserts.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
Old 02-18-2019, 06:59 PM #3
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
If you are looking for a penetrating oil, I had good results with this stuff. I usually spray down all my crusty bolts and fasteners with this before I do a job to give myself the best chance of having to use less swear words.
Penetrating-Lubricating Oils
Old 02-18-2019, 07:30 PM #4
Real Name: Brody
Real Name: Brody
Alright I'll give those a try thanks!
Old 02-18-2019, 09:41 PM #5
sumday sumday is offline
sumday is on a distinguished road
a couple of mine snapped off and didnt bother putting skid plates back on...oil changes real easy and prolly how i figured out my actuator leaks in only freezing weather
sumday is offline   Reply With QuoteReply With Quote
Old 02-18-2019, 11:51 PM #6
Burt Burt is offline
Burt is on a distinguished road
I had same problem years ago. Since some bots are recessed below the plate, I had to drill them out. Ended out be much simpler than originally thought. The bolts were made of aluminum so I drilled a 1/4" hole straight thru. After that, they backed out easily. I think Toyota may installed these cross-threaded somehow. Best of luck.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 02:33 AM #7
the new to me 4runner had missing bolts, different bolts, cross threaded and whatever else you could not think of they did...i see it all the time...getting oil changes anywhere (dealers too) and they screw up stuff all the time...lower engine covers a mess, oil filters finger tight and drain plugs so tight and/or stripped
Old 02-19-2019, 09:45 AM #8
Hiker865 Hiker865 is offline
Hiker865 is on a distinguished road
I had one bolt do this on the last oil change. I couldn't get it out so I just drilled a hole through the center of it.
Hiker865 is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 10:35 AM #9
Elan750's Avatar
Elan750 Elan750 is offline
Elan750 will become famous soon enough
Elan750's Avatar
HEAT! grind them a bit to get more of a hex shape back into them, then heat those puppies with a torch. with a propane torch hold it on there for a good minute.
2005 4Runner Sport 4wd v6 -totaled!
2003 Lexus GX470
Elan750 is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 06:29 PM #10
L8Shift's Avatar
L8Shift L8Shift is offline
L8Shift will become famous soon enough L8Shift will become famous soon enough
L8Shift's Avatar
Try to squirt the bolts from within the frame, to get the threads soaked..
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
L8Shift is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 09:02 PM #11
ElZilcho's Avatar
ElZilcho ElZilcho is offline
ElZilcho will become famous soon enough
ElZilcho's Avatar
Use a left twist drill bit. Half the time it grabs and spins the bolt right out. The other half of the time... well, you were drilling it out anyway, right?
Be healthy.
Be nice.
Do interesting things.
2008 4WD SR5 V8. 2.5/1.5 Daystar. 265/75R16 Duratracs #UZN215
ElZilcho is offline   Reply With QuoteReply With Quote
Old 02-20-2019, 12:26 AM #12
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
I remember following a DYI process on here for my skidplate bolts. I drilled them all out and tapped them either M8 or M10 (I can't remember off the top of my head) and replaced all the bolts. There's enough meat on the nuts welded to the frame to accept that size.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 02-21-2019, 12:14 PM #13
Real Name: Brody
Real Name: Brody
I'll get em out prob going to replace my skid plates with new ones anyway as they are so rusty that they are practically falling apart.
Old 09-02-2020, 09:27 PM #14
DASYOTA DASYOTA is offline
DASYOTA is on a distinguished road
Stripped Skid plate bolt
Just realized my skid plate is missing a few bolts from previous owner. I went to home depot and got the m8 size bolts that someone commented on an earlier thread.
When I tried installing them, they just slide all the way in with no bite.
I am looking to order a tap kit, just don't know if I should go with an m8 or m10. I was thinking of tapping them all to an m10 since the welded in nuts seem to be stripped pretty bad already.
DASYOTA is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 09:45 PM #15
TravThePro's Avatar
TravThePro TravThePro is offline
Real Name: Travis
TravThePro is on a distinguished road
TravThePro's Avatar
Real Name: Travis
You can get a decent metric tap set from AutoZone for $30, that's what I would recommend if you aren't a machinist. If an M8 bolt goes all the way through with pushing, I would say that an M8 tap is off the table (you can still try that first if you want, but it will most likely fail). Make sure you drill centered with the correct bit before you try and tap an M10.
If you're not sure what bit to use, they have many charts that show the correct bit for each thread size. Here is a link to a place with several charts: 23 Printable Tap Drill Charts [PDF] ᐅ TemplateLab
Good luck, let me know if you have any questions.
1996 T4R
TravThePro is offline   Reply With QuoteReply With Quote
bolts , curious , plate , remove , skid
What to do when you have stripped skid plate bolts. 2012sr5 5th gen T4Rs 54 03-07-2022 07:02 AM
Stripped the bolts on the factory skid plate.... now what? audiness 4th Gen T4Rs 18 07-21-2020 12:21 AM
Stripped skid plate nut willo 5th gen T4Rs 6 12-30-2018 07:11 PM
Stripped/Seized Bolts on Skid Plate! modelstudent101 3rd gen T4Rs 8 03-30-2015 02:57 PM
Stripped skid plate holes - Helicoil or not? Fumbler Maintenance/Detailing 2 12-06-2008 07:02 PM
