Old 02-18-2019, 10:00 PM #1
climone climone is offline
climone is on a distinguished road
Prinsu roof rack install
Hey guys,
I just got a Prinsu roof rack for my 2008 4runner. I am nervous about drilling into the roof. Does anyone know of a thorough install guide or video? cant seem to find one.
Thanks!
2008 SR5 I F(X) PRO RIMS I YAKIMA RACK
climone is offline   Reply With QuoteReply With Quote
Old 02-18-2019, 10:39 PM #2
Auditechnician Auditechnician is offline
Auditechnician is on a distinguished road
No drill install on 4th gen.
Auditechnician is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 09:34 AM #3
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
yep no drill, get some clear silicone and seal the crap out of the bolts in the factory rivnuts though. Also I would recommend installing then ordering new spacers to get it to sit flush and with a proper spacer ID to actually fit the bolt size unless they've fixed that issue.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
blackoutt is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 10:39 AM #4
gfxcruncher's Avatar
gfxcruncher gfxcruncher is offline
gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about
Yep, no drilling needed.
Instead of the spacers, I went a cheaper route that worked pretty well. Used some 3/4x3/4 aluminum bar stock and drilled the mounting holes through that.
https://www.amazon.com/Pieces-ALUMIN.../dp/B01F80WM02
For the front or rear (can't remember which) I had to also stack a 3/4x1/8 aluminum strip (from local big box store) to bring it up a little bit. The spacing is nice and tight without touching the roof, about 1/16-1/8 space between rack and roof.
2007 SR5 4WD Nautical Blue -- Build Thread
gfxcruncher is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 01:26 PM #5
Rodtheviking's Avatar
Rodtheviking Rodtheviking is offline
Real Name: Chris
Rodtheviking will become famous soon enough
Real Name: Chris
Run a tap through the roof mounts to clear out any old loctite, I stripped one before I figured this out. Also be extra careful not to drop one of the nut inserts in the roof, if it falls in you have to pull the headliner to put in a new one.
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
Rodtheviking is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 01:33 PM #6
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
mine sits level and used provided spacers
LTDSC is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 06:24 PM #7
adkfinn's Avatar
adkfinn adkfinn is offline
adkfinn will become famous soon enough
adkfinn's Avatar
x2 Mine sits nice and level with no issues.
also big x2 on gratuitous silicone usage. I basically filled the spacers all the way up, then pushed the bolt through it and into the nutserts in the roof. This is an area where you can't use too much and it is truly cheap insurance against leaks and water damage to your head liner/etc.
2007 4Runner with some crap on it. Nice crap.
adkfinn is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 11:50 PM #8
bearisasquare's Avatar
bearisasquare bearisasquare is offline
Real Name: Topher
bearisasquare is on a distinguished road
Real Name: Topher
Like others have said, its an easy bolt on. There is no drilling required. Everything included in the box was needed to install properly. The spacers included set everything up nice and level. I set mine up on the 4runner piece by piece, but you can also loosely bolt everything together and then lift it on the vehicle. Took me a couple hours to put it all together.
Only thing you'll need are some tools, silicone and some rags to clean up the roof when you take off the old rack.
You can check out my insta (@shadow4runner), i took a couple photos during the install. A lot of guys who answered here helped when i asked as well.
2009 Limited 4WD V6 Shadow Mica
ICON Stage 2 Kit SCS Ray10 17x8.5 BFG KO2 285/70r17
Rago Modular Storage Panels & Ditch Brackets * Prinsu Rack * Baja Designs Sqaudron Sports
KC Hilites Cyclones under hood * Blue Sea 12 Circuit Fuse Block * White LEDs Interior
Kenwood DMX906S Kenwood X802-5 Amp Infinity Front REF-6530cx & Rear REF-6532ex Pioneer TS-A2000LD2
bearisasquare is offline   Reply With QuoteReply With Quote
Old 02-20-2019, 05:03 PM #9
SAC-CA-Runner SAC-CA-Runner is offline
SAC-CA-Runner is on a distinguished road
x3. Easy install. No drilling. Sits nice and level.
SAC-CA-Runner is offline   Reply With QuoteReply With Quote
Old 02-20-2019, 08:10 PM #10
chrisbriggs chrisbriggs is offline
chrisbriggs is on a distinguished road
Is Silicone all that is needed to make it watertight? I have seen others recommend a 3M Water Tight Sealant that is silicone based like this one...
3M™ Fire Barrier Water Tight Sealant 3000 WT | 3M United States
Don't want to waste my money if basic silicone is up to the task.
chrisbriggs is offline   Reply With QuoteReply With Quote
Old 02-21-2019, 04:40 PM #11
blackoutt's Avatar
blackoutt's Avatar
I know I know I'm anal. This was my front and rear gap with the 1" spacers provided. I went to 7/8" spacers in the front and 3/4" spacers in the rear with a smaller ID.
here's the after pics and a blurry comparison of the spacers
Old 11-20-2020, 10:42 AM #12
Currie_1's Avatar
Currie_1 Currie_1 is offline
Currie_1 is on a distinguished road
Currie_1's Avatar
you get these off amazon too? if so what will be the safe ID to go with ?
2005 Sport / v6 / Icon stage 2 / toytech 1'' body / DO Front / 285/75/17 BF Goodrich KO2s / Fifteen52 Turbomac HD / Prinsu Full Length / Baja Designs & Factor 55 Goodies / Overland Custom Designs Links
Currie_1 is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 10:00 AM #13
blackoutt's Avatar
blackoutt's Avatar
The old orders link takes me to a different part now that doesn't have the right ID. I used some that had 3/8" ID marked as 0.38" I suppose you could go slightly smaller ID even, and worst case have to drill them out a touch to fit the bolts.
Descriptions from the parts I bought back in 2017
"Round Spacer, Aluminum, Plain Finish, 3/8" Screw Size, 3/4" OD, 0.38" ID, 7/8" Length, Made in US (Pack of 5) "
"Round Spacer, Aluminum, Plain Finish, 3/8" Screw Size, 3/4" OD, 0.38" ID, 3/4" Length, Made in US (Pack of 5) "
find , install , prinsu , rack , roof
Roof Rack help! Prinsu Design... PAOOOO26 5th gen T4Rs 25 05-11-2021 03:55 PM
Prinsu Rack Install bearisasquare 4th Gen T4Rs 6 12-26-2018 03:51 PM
Roof Rack - Prinsu VS SSO genesis712 5th gen T4Rs 9 04-24-2018 03:20 PM
FS: 5th Gen Prinsu 3/4 roof rack sn_85 For Sale: T4R Items 2 01-19-2018 12:24 AM
Pads for Prinsu roof rack? mc813 5th gen T4Rs 3 07-12-2017 10:00 AM
