02-20-2019, 07:54 PM
Headlight Condensation
So I got a 3 year old oem headlight getting condensation. No cracks I can see with my eyes. I decided to pull the cover apart and reseal it with butyl from TRS. It worked for 2wks but came back again. So I tried baking it again and pushing it together to get a good contact.(I hope). Again everything is good for a few weeks and it is back. Any tips? I double check all rubber seals. Clueless at this point. Thanks
2022 Toyota 4Runner TRD OFF ROAD PREMIUM
02-20-2019, 07:59 PM
Real Name: Chris
Real Name: Chris
Maybe a poor seal on the bulb? Swap bulbs left to right and see if the problem follows the bulb.
02-20-2019, 09:47 PM
I did that and still the same. I pulled other bulbs I had laying around and stuck them in. Same. Sad. The headlight still look new too. LoL
02-21-2019, 09:36 AM
you have a weak seal, check the corners, especially the outside edges. and all screw holes.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
02-21-2019, 01:47 PM
I had the same issue a little while back. Bought some gorilla sealant, worked like a charm. Might be something to check out
02-21-2019, 02:02 PM
I did an inhumane thing.
I ran silicone around all the edges/gaps on both headlights.
07 T4R Sport Edition V6 4x4
02-21-2019, 03:21 PM
Thanks for the suggestions. Will try again lol
02-21-2019, 04:30 PM
I would buy new O-ring seals for the lamp sockets on the headlamp assembly from Toyota and install them. If the they are old , dry cracked , shrunk or do not fit snug , it could be your issue.
02-21-2019, 08:29 PM
This how I repaired mine as well. Used a hair dryer to drive the moisture out and ran a bead around the seal. Done, and done.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
02-22-2019, 08:26 AM
Not always... I’ve been chasing this issue with some aftermarket ‘06 projectors that I bought from Amazon for far too long now. I very carefully silicone sealed the driver’s side that started leaking a few months after they were installed. It was good for maybe a month, but once that side was fixed then the passenger side started. I did the same fix to that side, then a few weeks later the driver’s side started again! During the many times these have been out, I was super careful to use a Teflon based o-ring sealant on all the bulb sockets just to be certain it wasn’t originating there. At this point, I’m perplexed and beginning to think that maybe the vent is somehow defective and letting moisture in since I can honestly find no other way it can be entering at this point. At this point, I’m ready to just shitcan these, or sell them to someone looking to do a real projector retrofit or something and move on to some factory Sport ones. I like that my aftermarket ones are flat black on the reflectors, which looks awesome with my black truck, but I’d settle for the smoked Sport ones just to have clean looking lights for once!
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
02-22-2019, 01:36 PM
I'll get it split apart again and try a thicker bead of the rubber butyl but this time I'll use some ratchet straps but carefully. I do notice just right inside the bulb housing I see some brown stain. Not crusty but looks rusted. Don't know if that's normal or what. I remember my old oem housing non projector had the same problem on the same side.(weird) Split it apart and re-seal. No issue. Which is why I still have leftover butyl. So frustrating
02-27-2019, 12:44 AM
Guys, before even i proceed with "sealing" headlight, does anyone have any idea how to clean-up all that "watery mess"?
pic attached
02-27-2019, 02:35 AM
Real Name: Kyle
Real Name: Kyle
Clr?
06’ Sport 4WD, locked on 33’s
02-27-2019, 02:40 AM
pic attached
I pulled the low and high bulbs out. Stick a blow dryer to the high beam socket and waited. Eventually, they'll dry up. Heat the plastic from the outside helps too.
02-27-2019, 07:47 AM
That’s how I’ve usually done it, but in addition to that, I’ve taken along section of paper towel and twisted it into a diameter that can fit through the bulb hole making sort of a wicking rope to dry the puddles first. Usually I bring it in the house, flip it glass side down for a short time so the water pools. That makes it easier to wick up the bulk of it, then I use the hair dryer to evaporate most of the remaining moisture. It still helps to leave it in the house at least overnight to continue drying out. I run a pellet stove for heat this time of year, so I leave it near that, which helps a lot. I just wish I didn’t have to keep doing this! At this point, short of permanently sealing around the bulbs with silicone, and blocking the vent, I’m out of ideas. Who knows, maybe the adjusters need to be sealed too. Wish I could trash the vendor on Amazon, but they won’t allow me to post a review for some reason...hmm... wonder why that is...?
