Old 01-23-2020, 05:23 AM #286
WyEast-08's Avatar
WyEast-08 WyEast-08 is offline
WyEast-08 is on a distinguished road
WyEast-08's Avatar
I picked up a set of the Auxbeam LEDs for my lows a few months ago. They are a big improvement over the stock lights, much brighter. However, the throw is not as far as the old halogens, and the buzzing of the fans when I'm stopped with the engine off drives me nuts. So, Im working on whether to go with HIDs or maybe the GTR Ultra 2s. Ive heard really good reports on the the GTR Ultra's.
Swampdodo - how are the fan noise on those?
WyEast-08 is offline   Reply With QuoteReply With Quote
Old 01-23-2020, 08:25 AM #287
MDurbs68's Avatar
MDurbs68 MDurbs68 is offline
MDurbs68 is on a distinguished road
MDurbs68's Avatar
Fogs added
Originally Posted by MDurbs68 View Post
I just upgraded to the Auxbeam led hi and lows based on OP's suggestion. They were $25.32 for a pair of lows and $25.32 for the highs. Installed on Sunday so limited use. I like the upgrade.........but not as much as I thought I would. The light from the leds doesn't seem as crisp to my eye. Maybe I just need to get used to them. The high-beams are certainly brighter. I also purchased the the led for the drl/turn signals. I have not installed yet.
Thanks to formidable for the info.
I also added these fogs last night: Amazon.com: Alla Lighting 3800lm Xtreme Super Bright 9006 LED Bulbs Fog Light High Illumination ETI 56-SMD LED 9006 Bulb HB4 9006 Fog Lights Lamp Replacement - 3000K Amber Yellow: Automotive
I don't use my fogs often, really only in fog and snow. Had snow this morning and I was pleased with the combination of yellow fogs and the new Auxbeams.
2008 SR5 4WD, Window Tint, LED Interior Lights, TRD Pro Rims, Falken Wildpeak AT3 265-70-17, Cornfed 1.5/1 Spacers, New rear OEM springs, Rear Bilstein 4600
MDurbs68 is offline   Reply With QuoteReply With Quote
Old 01-23-2020, 05:32 PM #288
swampdodo swampdodo is offline
swampdodo will become famous soon enough
On my wife's CRV with the Ultra 2's...with the engine running of course you don't hear anything. With the engine off and hood closed, I didn't notice anything. With the hood open, I can barely hear the fans...no buzzing or vibration...just ever so slight fan sound.
swampdodo is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 12:55 AM #289
WyEast-08's Avatar
WyEast-08's Avatar
Maybe its just me.. The GTR Ultras seem to be pretty bright, how is the distance on those compared to the Auxbeams?
Old 01-24-2020, 11:16 AM #290
JONBOY345 JONBOY345 is offline
JONBOY345 will become famous soon enough
I've recently gotten rid of my Auxbeam lights that I bought for the Fogs and high beams and gone back to Halogen bulbs.
First, the fogs had no cutoff whatsoever and were blinding to drivers at night... I replaced them with some Vosla 9006 +120 bulbs from: VOSLA 9006 +120 "Super Brite Light"
Significantly better cutoff and much less glare from rain so I'm able to see the road markings instead of glare from the Auxbeam LEDs. The color of these bulbs, as well as the better cutoff, make these significantly better than the Auxbeams.
For high beams, I went with some Phillips 9011 HIR bulbs: https://www.amazon.com/gp/product/B00480J5CW
Here's a link with more information on HIR bulbs and how to modify them to fit: HIR bulb base modification
These bulbs have a significantly better hot spot and throw light much further down the road than the Auxbeams. The warmer color of these bulbs makes them much better in rainy weather than the cold LEDs as well. The LEDs look better due to our propensity to favor foreground light, but sight distance is much more important for high beams than just about anything else.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Shorties | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 03:54 AM #291
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey will become famous soon enough
For high beams, I went with some Phillips 9011 HIR bulbs: Amazon.com: Philips 9011B1 9011 Bulb: Automotive
I’ve done a fair amount of research over the past week or two (whilst planning a projector retrofit) and have decided against plug and play led bulbs in the stock H11 projectors. Nothing wrong with them, really I just want more...well that and I’m not really a fan of the 6000+k color temp most led chips used produced. Interestingly enough H9 halogens actually put out more intensity (and thus distance and foreground) than the Diode Dynamic SL1 bulbs. I’ve run these for a while and thought they were a pretty good upgrade, although they do burn out way quicker than the standard H11s
On the whole, it seems Diode Dynamics is a decent choice because they are engineered to closely mimic halogen lighting patterns of their intended housings. Different projectors/reflectors have different fitment/placement/intensity requirements for the chips and they seem to actually take this into consideration. In fact, their SLF 9006 fog bulbs intentionally limit the output in order to avoid blowing/washing out the foreground. Their 3000k yellow bulbs are actually yellow too instead of that weird green tint a lot of yellow LED bulbs have since their chips aren’t just 6000+k with a yellow coating...excellent if you like the yellow look. I’ve looked into putting these into my stock fogs but I really want to get some Stage Series 3 units down ...maybe once I get my retro project done.
I’ve also been running the 9011 HIRs for quite a while (and haven’t burnt them out yet) and they are by far the greatest bang for buck lighting upgrade for us imo. It seems quality LED units still give a greater overall intensity/hotspot/distance but you can’t go wrong with these, especially for the price. I haven’t quite picked out what I want but I may give the 9005 SL1s a go...or just keep my 9011 HIRs.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 02:24 PM #292
Schnurd Schnurd is offline
Schnurd is on a distinguished road
Just installed these last night and I can say they are awesome. Still retains the factory cutoff fairly well, and there is hardly any glare from them. My only complaint would be I wished I had found some that were less than 6500K.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Schnurd is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 09:23 PM #293
kevinpt's Avatar
kevinpt kevinpt is offline
kevinpt is on a distinguished road
kevinpt's Avatar
i just removed my auxbeam f16 h11si had been running for a few months. they started causing abs codes when i turned on my headlights but were still turning on. dont know what caused the problem but i dont feel safe running an led that has caused a abs code when i dont see how its possible. might go to morimoto 2 stroke if they fit with my larger agm battery
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch,MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
kevinpt is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 07:01 PM #294
I kinda wanna try these for the reverse lights...
Old 01-27-2020, 09:15 AM #295
No idea...never tried the Auxbeams LEDs.
Old 01-27-2020, 10:05 AM #296
I do have some LED reverse lights, they're extremely useful.
Old 01-27-2020, 03:47 PM #297
The kind with the projector at the end? Seems like they'd be useful!
Old 01-27-2020, 04:40 PM #298
No, mine don't have a projector, but they do have 3 large LEDs on the tip facing directly rearward once installed.
Old 01-27-2020, 07:56 PM #299
Ah gotcha, I linked one with the projector I'm probably gonna try out.
Old 01-28-2020, 11:14 AM #300
lsmo_guy's Avatar
lsmo_guy lsmo_guy is offline
lsmo_guy is on a distinguished road
lsmo_guy's Avatar
Hey Drift Monkey,
I recently added these to my 4Runner. They do not have a projector at the end, as you want, but there has been quite a bit of improvement. For example; when backing up at night, and looking at the backup camera in the dash display, everything is more noticable than before. The LED backup lights paired with LED plate lights help a lot!
Amazon.com: Alla Lighting 912 921 LED Reverse Light Bulbs Extremely Super Bright 4014 30-SMD CANBUS 921 LED Bulbs RV T15 T10 906 W16W Back up, Cargo Lights Replacement, 6000K Xenon White: Automotive
lsmo_guy is offline   Reply With QuoteReply With Quote
06-09 , bulbs , led , limited , morimoto
LED headlight bulbs? Nashvillerunner 4th Gen T4Rs 7 12-09-2013 11:53 AM
headlight bulbs ZombH8R 4th Gen T4Rs 13 09-12-2013 05:20 PM
Which headlight bulbs? TRDteen 3rd gen T4Rs 40 09-28-2012 12:10 PM
Which headlight bulbs? druuu88 4th Gen T4Rs 12 04-13-2006 09:20 AM
Got new headlight bulbs, how to put them in?! daytonaSURF Engines / Suspension / Wheels / Tires / Audio / Accessories 3 12-10-2004 06:30 PM
