03-16-2019, 10:53 AM
#91
Real Name: Russell (OB #9908)
I got the 9005 high-beams yesterday. Both the bulbs and plugs were tougher than expected to get seated but the output is impressive. Look forward to road testing them and will post an update.
03-16-2019, 11:23 AM
#92
Originally Posted by Terminator03
What year is your truck? Mine is an ‘04 with the projector type fogs, so I was hoping they’d be fine with the projectors. I believe that the ‘06+ went back to reflector type fogs, correct?
I have a 06' so the fogs will probably output light better with your projector style
03-16-2019, 08:51 PM
#93
I actually rolled the dice and ordered them anyway. They work very well with the projector fogs! Of course now, the high beams look stupid because they are so yellow in comparison, that I’m going to do those too now. Also did the amber DRL/turn bulbs and they work and look awesome as well. A lot of money for all these bulbs but I’m very pleased with the results so far!
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
03-16-2019, 10:17 PM
#94
Originally Posted by Formidable
Ambient temp shown at time of testing the DRL temps. 5 mins was not significantly higher so waited 10 mins to show 10 deg elevation. Bulb back is cold to the touch at 10 mins constant on.
Needless to say, not concerned whatsoever. Will post when they burn out as promised.
Any possibility the heat warnings are related to bulb temps inside the housings? When confirming my new high beam LEDs were working, I could feel heat well out in front of them.
03-17-2019, 02:51 AM
#95
Temps of the headlight lens were at ambient both at 5 mins and 10 mins while testing the DRL’s. No change in lens temp. Again, not concerned whatsoever. You folks want to wait a year or two before these bulbs blow out be my guest. Will update when they blow out.
2002 Thundercloud | TRD Supercharger | TRD Headers | URD 2.2 Pulley | Toytec | Addicted Offroad | 4xinnovations | Icon | SCS | BRIDE
BUILD THREAD
03-17-2019, 08:04 AM
#96
Not sure if you had this problem, but my original sockets were burned by the heat from the halogen bulbs, so I don’t expect these to be any worse than that. Even the sockets I had replaced maybe 8 months ago,were already showing signs of heat (turning brown) when I took them out to install the LEDs. I’ll be keeping an eye on them, but halogens get super hot, and since those fit into a small, shallow part of the headlight, there isn’t much air space around them which is probably why you could feel the heat. Did you ever try to feel them prior to changing the bulbs? I didn’t, but chances are good they were just as hot, if not worse.
03-18-2019, 12:11 AM
#97
I got LED lights for all the head lights. Only thing I don't like is the fog light isn't bright enough. I might do some sanding on the fog light assembly as it does kind of look a bit fogged out.
My Divemoblie 4runner
2005 Toyota 4runner V6 SR5
03-18-2019, 10:53 AM
#98
Hey, I tend to be overcautious, no question. But my experience has been that product warnings range from strictly a legal CYA on one end to where the item will cause serious damage if the warning isn't followed on the other. Using these as DRLs is very likely toward the CYA end but that remains to be seen.
I really appreciate your time and effort in taking the temps. What we don't know is what those temps will be when someone's on a road trip and the DRLs are on for 10-12 hours straight except for brief stops. I'll be interested to see how these do over time and will definitely be getting them if they don't cause you any problems.
03-18-2019, 11:07 AM
#99
Understandable. There is only so much I can do and obviously no one knows how these will hold up 10-12 hours constant on. I would imagine it’s the same as or very similar to running the parking lights, (194 LED’s), always on. There are tons of folks on this forum that swapped their parking lights to LED’s. I have yet to read about any problems.
BUILD THREAD
03-18-2019, 02:02 PM
#100
Agree. You've been great about answering questions and getting the temps and so on and that is much appreciated.
My gut feeling is that these will work fine and I'll end up getting them and wishing I had done it earlier.
03-18-2019, 03:35 PM
#101
I think OP has started a trend. I ordered low, high, fog, and backup replacements.
I can't say i think they are spectacular, but all have been a decent upgrade. No problems yet.
Haven't recieved my fogs yet. Will post back after.
Sent from my SM-G950U using Tapatalk
03-21-2019, 06:55 PM
#102
So I got the H11 lows and they work fine. I also got the 9005 high beams and plugged them into my (2006 stock) headlamps but they did not work. Any ideas as to why?
03-21-2019, 10:50 PM
#103
Reversed polarity. Pull the LED plugs out of the OEM harness, rotate the plug 180 and reinstall. Do not put the bulbs back into the housing until you get them to fire up.
BUILD THREAD
03-21-2019, 10:57 PM
#104
More pics.
Nice truck! Really like your color and setup. If I were to buy again, I would love to get one in your color.
03-21-2019, 11:05 PM
#105
Thanks! Not my first choice but the Nautical Blue Metallic is the only blue I would consider.
BUILD THREAD
