03-22-2019, 08:18 AM
#106
Anyone switched from HID kit to LED?
I'm going on 2 years with my cheap amazon hid kit. No issues but would likely switch when they go out. Seems like led has come a long way over the past few years, but are they as bright as a real hid system?
03-25-2019, 12:10 PM
#107
Anyone have an issue with condensation in their headlights after using these bulbs??
03-25-2019, 02:57 PM
#108
Yeah, mine are basically foggy all the time. I thought it was just me.
06 Curry Runner
03-25-2019, 03:05 PM
#109
Ok good to know. Had no issue with my cougar LED's, so apparently the seals on these are trash. I just took the seals off my old bulbs and they fit right on. Much thicker as well. I left my bulb out to dry it out and will reinstall when the lens is clear again.
I live a pretty minimalistic lifestyle (own a tiny house) so unfortunately, I have no access to a hairdryer to dry it out.
03-25-2019, 03:36 PM
#110
You guys sure it’s the bulb seal? Sounds more like a headlight lens seal problem to me.
I had this thing through rain and snow here in Seattle, as well as car washes with a pressure washer... zero issues.
2002 Thundercloud | TRD Supercharger | TRD Headers | URD 2.2 Pulley | Toytec | Addicted Offroad | 4xinnovations | Icon | SCS | BRIDE
BUILD THREAD
03-25-2019, 04:10 PM
#111
I've had no issues with the last two sets of bulbs I've ran. This new set, passenger foggy. No other changes. It could be but I think it's most likely the bulbs.
03-25-2019, 04:18 PM
#112
Gotcha. Could be the bulbs but I highly doubt it.
I also just happened to change my radiator. The mechanic left the upper rad pipe clamps off by mistake... exploded steam and coolant all over the engine bay including the back of all headlight bulbs. Headlights still have zero condensation issues.
BUILD THREAD
03-31-2019, 07:15 PM
#113
Pic of the LED DRL’s mentioned earlier in this thread lit. Don’t be fooled... the turn signals when activated are bright as hell. They illuminate further down the road than the headlights.
BUILD THREAD
03-31-2019, 10:12 PM
#114
That’s exactly what I did, had some cheap HIDs (but pretty good luck), bought these for hi & low beams on my 2008 Limited, so far so good. cant wait to rip out the ballasts and relay.
2008 4R Limited Salsa Red Pearl 3Q3
AVS Bugflector, Coastal Lockpick 2, Super Z V1 Radar Detector Mount
Please, no more Hope & Change!
03-31-2019, 11:32 PM
#115
The condensation could be a result of the LEDs not putting out as much heat as an HID bulb, causing the inside of the lens to be a different temperature than its used to. I've seen this on some other cars I've installed LEDs in as well, almost a few days later they start to condensate if the weather fluctuates drastically. Not sure if my reasoning is correct though, just food for thought.
'04 Toyota 4runner Limited | OME 885/Superflex
03-31-2019, 11:51 PM
#116
I think that’s a sound theory.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
04-01-2019, 02:29 PM
#117
I've been looking at these to replace my DRLs, and wondering if you've noticed them dimming - some comments on Amazon about it, and the seller responded:
Do these get dim after 5 seconds? What are the lumens output then?
Answer:
Hi, there, thanks for your inquiry. Yes, they will become dim after 5 seconds because of automatic temperature protection system. The dim mode lumen will be 1/3 of bright mode.
By VehiCode Seller on January 23, 2019
'99 4Runner SR5, 370k
'07 Limited v8, 100k
04-01-2019, 02:46 PM
#118
Yep they dim within a couple seconds of being on. In my opinion, you don’t need these to be bright for DRL’s so it really doesn’t matter what the lumens output is.
Blinker function is extremely bright... which is great for hazards, but not necessarily a good thing for blinkers.
Answer:
BUILD THREAD
04-01-2019, 06:19 PM
#119
Same here, and even when they dim, they are brighter than they were with the halogen bulbs they replaced. Also have a nice color which shouldn’t fade as the halogens do over time. I’ve literally replaced the bulbs in the past because they start to lose the nice deep amber and fade to pale yellow. Hopefully that will never happen with these. So far I’m very pleased with them!
04-02-2019, 01:12 AM
#120
Doing the 06-09 Headlight Swap in my 03 Soon. I just may go the LED Route. Looks like results are pretty positive. Thanks
@ Formidable
for all the work on this.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
