Old 08-30-2019, 10:54 PM #226
4 runna 4 runna is offline
4 runna is on a distinguished road
Originally Posted by Az4runnin View Post
Not Bad at all. 06-09 Headlight Swap well worth it.
Looks great!
4 runna is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 03:37 PM #227
Pale Rider Pale Rider is offline
Pale Rider is on a distinguished road
I bought these for my '06 T4R.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The bulb sockets don't have the little plastic notch like the bulbs I'm replacing them with, and one side is marked positive (+) and the other negative (-). I want to avoid plugging these in incorrectly.
On the OEM wiring harness I'm plugging the bulbs into, which side of the harness plug is positive and which is negative? Looks like one wire to the harness is white and the other is red/black or just red, I couldn't tell in the bright sunlight.
2006 V6 SR5
Pale Rider is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 06:31 PM #228
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I don't know which wire is which...but if you have a test light or could borrow one from a friend or many auto parts stores loan out tools for free some requirement a refundable deposit, but using a test light will tell you for sure which wire is which.
2004 Limited V8
Old 09-17-2019, 08:36 PM #229
I don't have a light tester.
Will I do any damage if I install the bulb incorrectly with reversed polarity? If not, then it seems all I would have to do is simply pull the bulb, rotate it 180 degrees and plug it back into the harness.
2006 V6 SR5
Old 09-18-2019, 12:08 PM #230
BendRunner BendRunner is offline
BendRunner will become famous soon enough BendRunner will become famous soon enough
you're good. Just flip the bulb
BendRunner is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 10:32 AM #231
All good.
Got both bulbs in the correct position on the first try. These are great.
2006 V6 SR5
Old 09-27-2019, 09:41 PM #232
rwelch53 rwelch53 is offline
Real Name: Ryan
rwelch53 is on a distinguished road
Real Name: Ryan
So I got and installed the DTMoto black housing headlights with the Auxbeam H11 lows and Vehicode 1156 DRL's, and I am thoroughly impressed to say the least! Still have a little aiming to do which is almost as aggravating as the install itself LOL. One question though...what is the tiny amber bulb that seems to also be a DRL and is located below the 1156, facing forward? Apparently 1 of mine was blown and I never even realized they existed, but can't seem to find the size anywhere online.
06-09 LED headlight bulbs. MUST TRY list-bulb-2-jpg
rwelch53 is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 09:48 PM #233
Gen4SR5 Gen4SR5 is offline
Gen4SR5 is on a distinguished road
Its a parking light. Bulb size is 168. If one is burned out I recommend changing them both to LEDs. They can be found for cheap on amazon or ebay!
Gen4SR5 is offline   Reply With QuoteReply With Quote
Old 10-03-2019, 10:19 PM #234
Real Name: Ryan
Real Name: Ryan
Yup, they actually just got delivered today. Total PITA to get my hands in there to replace with the headlights installed though LOL.
Old 12-02-2019, 03:32 AM #235
gfluff's Avatar
gfluff gfluff is offline
Real Name: Gary
gfluff is on a distinguished road
gfluff's Avatar
Real Name: Gary
Super happy with the AuxBeam low beams. Wow, for $30?!?
Highs and fogs and back ups look like poop now. Feels like an addiction to better lighting is starting...
I like my droop droopy
Front: Swayaway 2.5s + TC UCAs--Rear: Swayaway 2.5s + Icon 3.0 springs + Light Racing Jounce Shocks — 285/70R17 BFG KO2s
My build: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gfluff is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 01:41 PM #236
gfluff's Avatar
Real Name: Gary
gfluff's Avatar
Real Name: Gary
Picked up back up bulbs. Sylvania 921 Zevo 6000K LED bulbs. Not nearly as impressive as the Auxbeam lows, but I think it has to do with the lens/housing? I’d guess it’s not designed to throw light, with the textured surface in it. I back up to my garage in the dark, nightly. No real difference in what I see. The bulbs look insanely bright in there, but the light just doesn’t travel...
Old 12-07-2019, 09:39 PM #237
AreaOne AreaOne is offline
AreaOne is on a distinguished road
Has anyone got the dashboard error lights when they installed the low beam lights? The error codes indicated ABS issues but then I put the stock bulbs back in I did not receive any codes.
Then I replaced one bulb at a time and the error codes appeared on each bulb, so I believe these bulbs are defective. I also installed the high beam bulbs and did not get a error code. So I’m asking for a replacement for the low beam bulbs and let’s see what happens.
2006 V-6 Sport Edition
If interested the codes were:
C0226, C0246, C0256 and C1223 all brake related. (I’m having no brake issues)
AreaOne is offline   Reply With QuoteReply With Quote
Old 12-08-2019, 11:07 AM #238
A search revealed a person with a similar issue like mine. Start with post #8
ABS, Brake, Slip-Indicator and blinking Multi-Terrain Trouble
Hopefully a new set will not cause this issue.
Old 12-08-2019, 02:15 PM #239
Wardbird's Avatar
Wardbird Wardbird is offline
Wardbird will become famous soon enough
Wardbird's Avatar
I bought this back-up bulb and have been disappointed in it: Philips 12789LPB2. Likewise it is supposed to be 6000k LED. It simply does not project very far and I back into my driveway and then the garage. There are no street lights on my street and my driveway is fairly long, 100ft. Often I have to get out and turn on the eve lights and garage lights to back it in.
Wardbird is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 08:14 PM #240
Results
I put in the replacement bulbs and do not get any error lights on the dash, so it appears the old bulbs were the problem. All is well now.
06-09 , bulbs , led , limited , morimoto
LED headlight bulbs? Nashvillerunner 4th Gen T4Rs 7 12-09-2013 11:53 AM
headlight bulbs ZombH8R 4th Gen T4Rs 13 09-12-2013 05:20 PM
Which headlight bulbs? TRDteen 3rd gen T4Rs 40 09-28-2012 12:10 PM
Which headlight bulbs? druuu88 4th Gen T4Rs 12 04-13-2006 09:20 AM
Got new headlight bulbs, how to put them in?! daytonaSURF Engines / Suspension / Wheels / Tires / Audio / Accessories 3 12-10-2004 06:30 PM
