Old 01-15-2020, 09:23 PM #271
meepmeep meepmeep is offline
meepmeep is on a distinguished road
OK, so I may be a dullard, but I am not lazy. I have read through pages and pages of posts regarding plug and play LEDs for my T4R 2008 SR5. My OE lamps are just inadequate for my old eyes. Could someone summarize the types/sizes of LEDs for my vehicle. My priorities are: low beam, high beam, back-ups. Also interested in fogs and turn lights, but secondarily. If someone could do me the kindness of a brief summary I would be most appreciative.
meepmeep is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 12:43 AM #272
stormrunner925 stormrunner925 is offline
stormrunner925 is on a distinguished road
I swapped all of the lighting in my 4r to 5000k led using vleds.com. Night and day difference and 3 year warranty with solid customer service. They are a little pricier than the cheaper amazon vendors but stand behind their product. Also enjoy all of the bulbs having matching colors
stormrunner925 is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 10:19 AM #273
lsmo_guy's Avatar
lsmo_guy lsmo_guy is offline
lsmo_guy is on a distinguished road
lsmo_guy's Avatar
LED turn signal bulbs?
Hello all,
I have a 2006 4Runner, and I have tried a few different types of LED bulbs for the front turn signals. Unfortunately, none of them have panned out. Even the ones that are advertised as "anti hyper flash, built in resistor, blah, blah, blah." I tried the relay install, and I tried other types, but I have not had any luck as they all hyper flashed. Any suggestions?
I thought I could install the switchback DRLs, but there are two separate bulbs; one for the turn signal, and one that I assume is the daytime light, and it is size 168, too small for the switchbacks I bought.
lsmo_guy is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 12:00 PM #274
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho will become famous soon enough riceandpho will become famous soon enough
riceandpho's Avatar
Originally Posted by lsmo_guy View Post
Hello all,
now first things first, is your truck equipped with the drl?
if your truck did not have drl, the flasher relay is behind the inside fuse box, also its 8 pin.
if your truck has drl, you will need to take the flasher relay apart and shave the metal link, there was a tutorial, only take a little bit off at a time.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Bridgestone Dueler A/T REVO 2 265/70r17. retrofited S2000 projectors,Osram 66240CBB,Morimoto 5Five Ballast.2 pairs of Hella Supertones.Blue cluster and climate controls.Full led conversion on interior and exterior.HAWK LTS pads f+r, Stoptech slotted rotors and stainless steel lines f+r.Firestone CoilRite 4135.Bilstien 5100 @0.85, MOOG FJ Springs.
riceandpho is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 01:26 PM #275
lsmo_guy's Avatar
lsmo_guy's Avatar
I will admit, I am confused....
I read and re-read what RICEANDPHO replied with, and I read the information in the following link.
As mentioned, on my 2006 4Runner, on the front, there is a small bulb (size 168) that is continuously on while the vehicle is running. And, above, just to the right of the small bulb is the turn signal bulb (1156).
Are you saying that I can "shave" part of a fuse and then the turn signal would become the DRL and should only flash if the turn signal were on? And, the small (168) bulb would be disabled?
Daytime Running Lights 2006 4-Runner - 4 Runner Club - Toyota Owners Club of North America
Old 01-21-2020, 10:04 PM #276
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey will become famous soon enough
On my car, the 1156 is always running if the truck is started. The little parking light is a just a parking light.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 01:40 AM #277
innovation innovation is offline
innovation is on a distinguished road
Originally Posted by T4R416 View Post
Sorry to everyone who has these but get yourself a good HID kit.. especially with projectors!!! Leds just CANNOT compare to a good HID kit.. I bet you even the cheap ones.
that is for damn sure. i had LED after 1 of my hid burnt out and you can tell the difference. led is more clear but less visible light. does that make sense?
2006 4Runner Sport 4WD V8
Ti Silver|TRD OR Wheels|
innovation is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 09:28 AM #278
MDurbs68's Avatar
MDurbs68 MDurbs68 is offline
MDurbs68 is on a distinguished road
MDurbs68's Avatar
I just upgraded to the Auxbeam led hi and lows based on OP's suggestion. They were $25.32 for a pair of lows and $25.32 for the highs. Installed on Sunday so limited use. I like the upgrade.........but not as much as I thought I would. The light from the leds doesn't seem as crisp to my eye. Maybe I just need to get used to them. The high-beams are certainly brighter. I also purchased the the led for the drl/turn signals. I have not installed yet.
Thanks to formidable for the info.
2008 SR5 4WD, Window Tint, LED Interior Lights, TRD Pro Rims, Falken Wildpeak AT3 265-70-17, Cornfed 1.5/1 Spacers, New rear OEM springs, Rear Bilstein 4600
MDurbs68 is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 12:37 PM #279
So, I am replacing my forward bulbs with Xtreme LED Pro units. The H11 low beam units installed fairly easily. However the high beam 9005s will not twist into place. It seems that the three tabs are too thick to twist into the slots. I have pressed forward as hard as I can. What am I missing? Do the tabs need to be modified? Any suggestions appreciated!
Old 01-22-2020, 01:23 PM #280
adkfinn's Avatar
adkfinn adkfinn is offline
adkfinn will become famous soon enough
adkfinn's Avatar
I've run into this before - quick fix: check the thickness of the rubber gasket on the new bulbs compared the old ones. If the old ones are noticeably thinner I'd swap them and see if that helps.
2007 4Runner with some crap on it. Nice crap.
adkfinn is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 03:58 PM #281
Many thanks adkfinn!
Old 01-22-2020, 04:15 PM #282
Inv4drZm's Avatar
Inv4drZm Inv4drZm is online now
Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold
Inv4drZm's Avatar
I think I had the same issue and what fixed it was using a deep well socket around the bulb to help push harder and twist. If you can find the right socket size, 6 pt might help too.
2005 4R Sport 4WD "The last of the V8s!" - Custom TIG'd SS Dual Exhaust - Icon 2.5 Resi's. - 1.5" BL - SCS SR8's - 35's - Dana 60 - Build Thread
2005 Tundra 2WD RCSB V8
Inv4drZm is online now   Reply With QuoteReply With Quote
Old 01-22-2020, 04:42 PM #283
swampdodo swampdodo is offline
swampdodo will become famous soon enough
Just my .02 on using LED bulbs...
So, decided to 'splurge' a little on some lighting upgrades to both my '05 4runner and my wife's '16 CRV, which uses the H11 bulb.
Went through all the reviews and watched as many YouTube videos as possible on the subject.
For the 4runner, I decided to try out the Boslla bulbs (Boslla Bullet B4 9006/HB4 - The World's first 4 Color LED Headlight - Boslla).
This bulb has 4 modes...on 1st mode (white light), the light is very white, but the beam pattern seems too high...almost like the high beam. But in mode 2 (white+yellow light)...WOW. Really nice. Mode 3 is quite good as well, but haven't had a chance to try it in bad weather. Mode 4 is just nice to play with.
Now, on my wife's '16 CRV with the H11 bulb (and projectors)...decided to skip all the stuff on ebay and amazon and got the GTR Ultra 2...expensive, but I believe well worth it. Holy cow, the beam is white, bright and almost the same pattern as with the stock halogen bulbs. And the build quality of the bulb is outstanding. (LED Headlights - Ultra Series 2 - GTR Lighting)
On both the Boslla and GTRs, you have to make sure the orientation of the LEDs is correct in order to get the proper beam pattern and best light output. both had adjustable orientations of the LED arrays...another plus.
swampdodo is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 06:19 PM #284
Thanks Inv4drZm! I finally got them in. Just took more elbow grease than I was able to administer!
Old 01-22-2020, 11:09 PM #285
Jpilot Jpilot is offline
Jpilot is on a distinguished road
Auxbeams on sale
Guys, just picked up some more lights today. 50% off right now on all auxbeam stuff, code 12sale.
Jpilot is offline   Reply With QuoteReply With Quote
06-09 , bulbs , led , limited , morimoto
LED headlight bulbs? Nashvillerunner 4th Gen T4Rs 7 12-09-2013 11:53 AM
headlight bulbs ZombH8R 4th Gen T4Rs 13 09-12-2013 05:20 PM
Which headlight bulbs? TRDteen 3rd gen T4Rs 40 09-28-2012 12:10 PM
Which headlight bulbs? druuu88 4th Gen T4Rs 12 04-13-2006 09:20 AM
Got new headlight bulbs, how to put them in?! daytonaSURF Engines / Suspension / Wheels / Tires / Audio / Accessories 3 12-10-2004 06:30 PM
