Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 07-26-2019, 02:24 PM #46
montijo505's Avatar
montijo505's Avatar
Anyone ever get a clear answer on what size hose? I’m thinking maybe 3/8 but unsure. Thanks.
Old 07-27-2019, 03:16 PM #47
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
Before you do this check, and buy if needed, the trans oil cooler hard lines that run along the radiator support.
I live where they salt heavily in the winter and mine are quite rusted and on the verge of splitting.
Rockauto has them for around $30
Mantilgh is offline   Reply With QuoteReply With Quote
Old 07-27-2019, 06:58 PM #48
waypoint's Avatar
waypoint waypoint is online now
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
3/8" inside diameter. Lowe's has this in clear tubing for cheap, really helps watch the discharge so you can tell quickly when the old fluid is gone and clean fluid is pumping out.
waypoint is online now   Reply With QuoteReply With Quote
Old 07-28-2019, 11:49 AM #49
00GTvert 00GTvert is offline
00GTvert is on a distinguished road
that's what i used
00GTvert is offline   Reply With QuoteReply With Quote
Old 07-29-2019, 03:24 PM #50
vastano vastano is offline
vastano is on a distinguished road
I second this, mine were so rusty they just started leaking this week. I went with the Dorman, didnt think Rockauto would have them. Oh well!
vastano is offline   Reply With QuoteReply With Quote
Old 08-14-2019, 11:43 PM #51
montijo505's Avatar
montijo505's Avatar
Finally got around to this, I’ve had the WS in the garage for a week or two. Super easy.
This is what came out the first 3 quart run.... not terrible surprisingly at 145k
Easy Peasy transmission fluid exchange V6-img_1903-jpg
Then the second 3 quart run
Easy Peasy transmission fluid exchange V6-img_1906-jpg
Then the first two quart run, looking much better
Easy Peasy transmission fluid exchange V6-img_1907-jpg
And the second 2 quart run. At this point I figured the last 2 quarts to make 12 were unnecessary, but I was in it so I figured why not.
Easy Peasy transmission fluid exchange V6-img_1909-jpg
The last bit came out looking like what I was putting in, which is awesome.
Only recommendation is make sure you get the right size fitting for the hose connection. I got a 1/4 inch inner diameter brass fitting and it worked, but barely. I couldn’t find a fitting that was 3/8 outer diameter at Home Depot, they must have been out. I got a few drips at the connection but nothing a towel didn’t soak up.
Easy Peasy transmission fluid exchange V6-img_1905-jpg
Can’t stress how easy this was, took less than 2 hours total. Thanks OP!
Old 09-12-2019, 03:12 PM #52
MT Runner's Avatar
MT Runner MT Runner is offline
MT Runner will become famous soon enough
MT Runner's Avatar
I’m planning on doing this one of these weekends this fall.
I think I know the answer to this, but want to see what others think.
I added an auxiliary trans cooler to mine. So the tubing currently goes:
-Trans to top inlet on radiator
-Bottom outlet of radiator to one side of the trans cooler
- other side of the trans cooler back to the return line that normally would be hooked up to the bottom outlet on the radiator.
So, what I’m thinking is that I will have to disconnect in two spots; the top inlet of the radiator for the old fluid, and then the tube that used to be on the bottom outlet of the radiator. This way I’ll basically be bypassing the internal trans cooler that’s in the radiator and my aux trans cooler.
The reason I think I’ll have to do this, is in the way the OP did it, you’re relying on gravity to refill the trans on the return line.
On my setup, that return line will be leading to the aux trans cooler, which is a decent amount more tubing and mounted in the middle of the radiator, so gravity will be working against me to get that new fluid into the aux trans cooler and through, and back to the actual trans. I’m thinking the best bet will be to just bypass the radiator and trans cooler altogether and disconnect in two spots.
Am I overthinking this, or what do others think?
2005 SR5 V6
URD headers and MAF Cal
AFE Intake
Dobinson, JBA UCA’s, 255/75R17 KO2’s, Level 8 MK6 wheels
MT Runner is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 11:28 PM #53
montijo505's Avatar
montijo505's Avatar
This makes perfect sense to me, no reason this shouldn’t work.
Old 10-07-2019, 12:06 PM #54
gaswede gaswede is offline
gaswede is on a distinguished road
I preformed this exchange over the weekend. WOW what a crazy difference a fluid change makes in every day drive-ability. I truly couldn't believe it.
My trans fluid pumped out black as night (168k mi) and took about 8 out of 12 qts before i saw any change in color. by the time i got 12 qts in, the color was a deep red and satisfactory. probably could have taken another 2-3 qts to clear up even more but i was already $90 in at this point. im happy with the results.
my process took 3.5 hrs total. I equate the longer time frame to the fact that the orifice on my 'fill funnel' was probably smaller than others'.
for those that have not attempted this, do it!
also, as stated previously, patience is critical! the new fluid is not sucked in but rather gravity fed so...its slow!
I used Maxlife as other did. the bottle now states WS compatible on the label.
gaswede is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 12:19 PM #55
Here are a few pic of what I had to work with.
To get my marks on the jugs, I started by pouring in 2 qts from the maxlife to the first jug, marked it. Then poured from the first jug to the second jug and marked it.
Easy Peasy transmission fluid exchange V6-d9786dea-b36a-4551-b97a-5131a233e7c5-jpeg  Easy Peasy transmission fluid exchange V6-d195007c-ce64-4640-8c3d-965dd267f167-jpeg  Easy Peasy transmission fluid exchange V6-5a0351ab-7b62-4973-973f-1dcaea24351e-jpeg  Easy Peasy transmission fluid exchange V6-75b963e6-ac72-474c-83f8-674a173c17d9-jpeg
Old 11-14-2019, 06:53 PM #56
smurph smurph is offline
smurph is on a distinguished road
After looking at countless ways to do this procedure, I went with the one Streetfighter wrote up.
I had been experiencing shudder when going up hill or at certain speeds. It wasn’t all the time but often enough to make me wonder if my transmission or torque converter was failing.
I used 3/8” ID tubing and 1/4” air fittings to attach to the factory hose.
Valvoline Max from Walmart as I couldn’t find it anywhere else. (I hate Walmart!) :-)
I replaced about 13 liters of fluid and it shifts so smoothly now and no shudder. Mileage is also better.
2007 4Runner, 4.0L - 260,000 kms.
smurph is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 12:07 PM #57
i just did this fluid exchange on my 08 v6 a couple weeks ago, very easy to do & well worth it. at 145k the original WS fluid was very dark but the trans shifted ok with no shudder issues. after putting in 12qts of maxlife it shifts noticeably better & has less drag or when letting off the gas & coasting, seems to downshift on its own much smoother.
in the recent posts here of others doing it, im confused on why people are running a hose to the radiator connection on the driver side to refill... the easier/faster way is to run the hose on the pass side directly into the fill hole on the side of the trans & use a medium to large size funnel, mine took maybe 2 minutes to fill 2-3 qts that way.
all you need to do is disconnect the bottom radiator trans hose & connect the clear tubing to the radiator outlet fitting then into a jug to catch the fluid being pumped out. im seeing people use an adapter in the hose then connecting a hose to that. maybe thats different for a v8 with a aux trans cooler, but for the v6's its a direct connection off the lower rad fitting to drain, then run the funnel & hose into the fill hole on the trans to refill.
well worth the change however you do it. & be sure to follow the fluid check procedure, its very easy to use the trans fluid check feature on the gauge.
Old 11-15-2019, 12:08 PM #58
maxlife has stated WS compatible for almost 10 years now.
Old 11-15-2019, 01:17 PM #59
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
i wish i could pull the trigger on trying this, seems awesome, i just scheduled a $97 fluid exhange for tranny at local toyota. did all my diffs and t case and motor oil on my own though. kudos to those of you who did this and epic original post by this guy.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 12:14 PM #60
its very easy to do it yourself, especially with all the write ups here & vids on youtube.
also, check into the details of that $97 dealer fluid exchange, a full exchange usually runs almost double that price at the dealer. think they might just be doing a drain & fill for $97... & thats only ~3qts. 3qts for $97 is a SCAM! you can do a drain & fill in about 15 minutes & maybe $25-30 in WS fluid.
also do some research for yourself to decide if you want to use WS again... its been proven that WS is a non synthetic fluid & doesnt do too well with heat. maxlife & others are full synthetic & as good or better than WS. yes there are still the alarmists that think you NEED to use WS or your trans will explode... but thats not the case at all. some even report shudder issues went away with full maxlife exchanges.
fluid , hose , line , tranny , truck
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
V6 Transmission Fluid and Filter Replacement made easy Supersonic 4th Gen T4Rs 34 02-19-2019 11:41 AM
4th gen V8 ONLY alternator swap in 4 bolts easy peasy cloud 4th Gen T4Rs 0 04-04-2018 02:43 AM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
