Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 02-20-2020, 02:10 PM #121
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Originally Posted by firebirdguy View Post
curious why you used a hose barb? the drain line should be from the bottom trans line port on the radiator, when you pull the bottom rubber trans line there is a 3/8 port/nipple that the drain hose will connect directly to & then run it into a jug with 2 qts marked on it.... no need for a adapter barb.
then the gravity feed fill hose should go directly into the side fill hole on the trans & does not take a long time at all. & when using the funnel it can be hung from the hood like "xtremewlr" shows if youre by yourself but if you have a helper it can just be held above the passenger side fender, doesnt need to be above the hood. & as i explained in my last post, using the fill hole on the trans lets the fluid gravity feed very quick, takes about 2-3 minutes to fill 2 qts.
also curious what you used the valvoline jug threads for? when filling the new fluid you just pour it into the funnel & let it gravity drain into the trans fill hole. not sure what or why you needed to make a gravity feed tank from a 2 litre bottle.
in the future, i hope anyone reading this thread reads the whole thing & sees my posts & realizes that the procedure in the initial post by the OP is NOT the correct way to do this... there is no need to use an adapter & try to splice into the tans lines, just use the bottom trans line port on the radiator, it is the output for the trans fluid. & do not fill via the trans lines, just use the fill hole in the side of the trans as its designed to be used. or the dipstick if you have a non sealed trans. the rest of the write up & comments are fine... but why make this harder than it needs to be?
Yeah I missed your post. I used the upper transmission cooler port not the lower one -_-. If I'd used the lower one, it would have gone a LOT smoother/faster in retrospect.
The valvoline threads were from a bad idea to use the adapter from Walmart to directly connect to the valvoline bottles. Don't do this because air pressure is a thing.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 12:20 PM #122
lower rad port is just to connect the drain hose to. then fill via the fill hole on the side of the trans.
Old 02-21-2020, 02:05 PM #123
Honda pc Honda pc is offline
Honda pc is on a distinguished road
I did the the transmission flush by copying this guy on youtube. He is really good and camerwork is excellent. I didn't make the clear hose direction indicator.. Can use pump for other jobs too. I used walmart valvoline maxlife big jugs.
YouTube
Sent from my SM-N960U using Tapatalk
Honda pc is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 06:13 PM #124
YouTube
wow, thats a whole bunch of extra complicated steps he does in that video! thats great if that way worked for you but its sooo much easier to do the drain of 2 qts from the bottom rad port with a short piece of hose to a pan, then fill 2 qts via a funnel & hose to the fill hole on the sealed trans or in this guy on the videos case, through the dipstick with a funnel!
he made a basic trans flush way harder than it needs to be! i quit watching when he broke out the electric pump...
Old 02-21-2020, 08:29 PM #125
Really.. 2 quarts is a full flush of transmission?? Its more like a dran, refill job..
Most full flush are 10 quarts or more, which the video did. Atleast on gen 3 or others. My seinna van took 2.5-3 gallons.
Old 02-21-2020, 08:32 PM #126
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
No.
Drain 2 qts, fill 2 qts.
Drain 2 more, fill 2 more.
Repeat for about 10 qts.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 11:17 AM #127
if you read this thread or watched any other vids of how to do a FULL exchange... its done ~2qts at a time using the trans pump by starting the engine to pump it out, then stopping & refilling 2qts. you do that 5-6 times & youve done a FULL exchange.
if you're using an external elect pump or filling through the rad/cooler ports you are doing it wrong & making things way harder than they need to be...
Old 02-22-2020, 12:05 PM #128
Wmyend Wmyend is offline
Real Name: William
Wmyend is on a distinguished road
Real Name: William
Nice thread!
Wmyend is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 04:34 PM #129
stormrunner925 stormrunner925 is offline
stormrunner925 is on a distinguished road
Great info
Thanks OP! This will definitely save me some money as I need to do a full exchange when I hit 150k. Hope its the same for the 4.7 as the 4.0
stormrunner925 is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 04:43 PM #130
read the last couple pages before doing it like the OP shows....
Old 02-23-2020, 05:28 PM #131
sandpic sandpic is offline
sandpic is on a distinguished road
I'm the original owner of my 2003 v8 limited that now has 190,000 miles and I decided to tackle this today. I tried the gravity feed method at first and then realized there has to be a better way. Hooked my power bleeder and was done in an hour. I can definitely feel the difference, the shifting is so much smoother.
I appreciated the help from the members here.
sandpic is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 12:12 AM #132
MT Runner's Avatar
MT Runner MT Runner is offline
MT Runner will become famous soon enough
MT Runner's Avatar
Tackled this yesterday afternoon.
Definitely an easy overall process.
Unfortunately I couldn’t get one of the fittings undone for the return line that went directly back to the transmission like I had planned. So I had to use the inlet into the radiator instead.
I have an aux trans cooler installed too, so anything I pumped into the radiator would go through there and then through the aux trans cooler mounted on the radiator before finally returning to the trans. The bottom line is, gravity wasn’t going to work for me on this project, so I had to use a hand pump.
That part ended up being a pain in the ass, hand pumping 12 qts back into the trans wasn’t a quick process...
Glad I did it though, old trans fluid wasn’t black, but it was definitely a few shades darker red than the new stuff I put in. Transmission shifts like new again.
Can’t beat the piece of mind for the next 50k or so.
2005 SR5 V6
URD headers and MAF Cal
AFE Intake
Dobinson, JBA UCA’s, 255/75R17 KO2’s, Level 8 MK6 wheels
MT Runner is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 12:23 PM #133
why didnt you guys just use the fill hole on the side of the trans to fill? & the bottom port of the radiator to drain??
Old 02-24-2020, 01:15 PM #134
Ease of access was my takeaway from the original post.
Old 02-24-2020, 01:55 PM #135
that way is no easier than using the fill hole on the trans... & as you found it took a lot longer with a hand pump or power bleeder. you can fill 2-3 qts via the fill hole with a funnel & few feet of hose in about 2-3 minutes!
sorry for all the replies on this, just trying to help & make life easier on guys doing this....
fluid , hose , line , tranny , truck
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
V6 Transmission Fluid and Filter Replacement made easy Supersonic 4th Gen T4Rs 34 02-19-2019 11:41 AM
4th gen V8 ONLY alternator swap in 4 bolts easy peasy cloud 4th Gen T4Rs 0 04-04-2018 02:43 AM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
