04-01-2019, 07:33 PM
#46
Thanks for the kind words!
Originally Posted by CaRamRod
Such a clean build. Good to see someone really pay attention to the smaller details. Like the shifter as well.
2002 Thundercloud | TRD Supercharger | TRD Headers | URD 2.2 Pulley | Toytec | Addicted Offroad | 4xinnovations | Icon | SCS | BRIDE
BUILD THREAD
04-01-2019, 07:52 PM
#47
Real Name: Matt
Real Name: Matt
Where did you find Nautical Blue spray paint?
2006 Nautical Blue V8 AWD - King resi CO's & 2.5" rears, Icon 2" Spring
Builtright UCA, Magflow 50 series (resonator delete), Morimoto D2S 4.0's...etc
Sold- 2002 Thundercloud Grey, Sport Edition- King Coilover's, Builtright UCA
04-01-2019, 11:57 PM
#48
eBay. Near perfect match. Just make sure to buy automotive primer, (available at local auto parts store), and practice if you are not used to working with rattle can paint.
Valspar Touch Up Paint For Toyota Lexus Color 209 3R1 3R3 3P1 3R7 3S8 8N7 8S6 | eBay
BUILD THREAD
04-02-2019, 10:24 AM
#49
Real Name: Scott
Real Name: Scott
Great looking truck
Really like the color as well as your mods. Was wondering how you like the DT MOTO Blackout headlights?
04-02-2019, 06:15 PM
#50
I was about to ask the same thing. I have to replace a headlight assembly and I am wondering about aftermarket.
-gl
04-02-2019, 06:32 PM
#51
Nice build! I was curious what tread pitched hardware all around the engine bay you used and the amount needed.
2005 4Runner V6 Bilstein 6112/5160 | Eibach 1" Rear Coils | 5th Gen Brakes SCS Ray 10's 17x8.5 | Falken Wildpeak AT3W 285/70R17 SCS F5's 17x8.5 | Falken Wildpeak AT01 275/70R17 06+ OEM Headlights | XenonDepot 5K HID
04-02-2019, 07:17 PM
#52
Thanks!
Hood: 4 M8x1.25 x 20mm
Engine bay: Roughly 40 M6x1.0 x 10-15mm and 2 M8x1.25 x 20mm
For the engine compartment it really depends how many bolts you want to replace. There’s probably 100 m6 bolts in there if you include timing cover, radiator support and other nonvisible fasteners
BUILD THREAD
04-04-2019, 11:52 PM
#53
Full RCI aluminum skid plates arrived... workmanship is outstanding. Welds are phenomenal. I have a few broken rusted bolts I need to extract before I install these. Nice weekend project.
BUILD THREAD
04-05-2019, 07:25 AM
#54
I also bought the powder coated aluminum version of the plates. Mine look different though, and I only bought them a couple of months ago during the group buy. I don’t have that welded on “bump out” plate. Is that a special request?
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
04-05-2019, 09:42 AM
#55
I requested RCI send me skids that work with a diff drop. If it’s not due to that then maybe it is a new design.
BUILD THREAD
04-05-2019, 09:53 AM
#56
Real Name: Ed
Real Name: Ed
OT - whats that pipe with all the pie cuts for?
04-05-2019, 10:05 AM
#57
It’s the center pipe of a GReddy 94mm titanium exhaust I took off of my other project.
BUILD THREAD
04-06-2019, 09:03 AM
#58
That might explain it. Doesn’t seem likely they’d change the design so soon, but you never know. Mine is flat across the bottom, with the exception of welded on bosses to protect the bolt heads from getting sheared off.
04-06-2019, 07:52 PM
#59
Previous owner broke a few skid plate bolts and stripped threads. My skid plates were held on with two bolts each...
Today I took the drill and m8 helicoil kit to the broken and stripped holes. Pic of one of the broken bolt tips next to the WD40 can and appropriate sentiment below.
The stainless threads are now stronger than stock. Not to mention the bolts go in butter smooth with permatex antiseize applied.
BUILD THREAD
04-19-2019, 09:44 AM
#60
JAOS grille was looking a bit empty. Filled it in with raptor lettering and lights. Lettering is held on with epoxy putty... which is incredible stuff. Also fixed my broken plastic fan shroud using this putty.
Still need to wire up the lights.
BUILD THREAD
