Old 03-22-2019, 06:53 PM #31
dannyg dannyg is offline
dannyg is on a distinguished road
Originally Posted by earthrealm View Post
Thanks for the youtube link,
if your motor is toast, it was likely caused by a leaking accumulator, so changing just the motor alone, would be postponing the evil day, i think buying a complete used unit will be a better option, and keep your failed unit for spares/back up.
btw, did you check the 40amp fuse, that powers the motor to be sure its not shorted out??
Hey, no I have not checked the fuse yet, do you know exactly which it is?
Funny now that I think about it, I did hear a clicking sound coming from the fuse box when I was doing the "test".
Would I just be able to pick up a new fuse at an auto part store?
Also, how can I be certain the accumulator is leaking? The fluid level does not seem low btw.
2003 Limited 4x4 v8
dannyg is offline   Reply With QuoteReply With Quote
Old 03-23-2019, 10:13 AM #32
earthrealm earthrealm is offline
earthrealm will become famous soon enough
in the engine bay, open the cover and look under, trace the fuse labelled abs/brakes or something like that, its a 40amp fuse...there is another 40amp fuse in there, you cud swap them and try depressing the brakes to observe if the motor will actuate
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 03-24-2019, 04:09 PM #33
So, I checked the fuse, swapped it with another 40, and the motor still did not run.
I think it's fair to assume that leaking fluid got to the motor/connector and caused the motor to go out... Sooo changing just the motor is no longer an option...
At this point I think I am down to 3 choices:
1. change the accumulator o-ring + the motor.
2. change the accumulator + o-ring + the motor.
3. find a reman, or new unit, and replace the whole thing.
(if I get a $600 used one on eBay, I'm not confident that it won't have the same issues down the road).
I was unable to remove the motor with the unit still attached to the vehicle.
I was also unable to remove the master cylinder assembly from the vehicle, I know its 4 bolts underneath the steering wheel holding it to the fire wall, but I cannot reach all 4 bolts (i can only even see 3/4).
Does anyone have instructions/advise on how to remove it?
Last, does anyone have instructions/advise on removing and replacing the accumulator/o-rings? Not sure if that is the source of the leak since it seems to be coming from the bottom of the black box that says AISIN, any thoughts?
Thanks!
2003 Limited 4x4 v8
Old 11-05-2019, 11:03 AM #34
hsu4runner hsu4runner is offline
hsu4runner is an unknown quantity at this point
Having just have the same issue as you described, up to the same spot as leaking I can hopefully offer some advise.
On the nut, the 4th nut is hard to get to, the top left nut. I had to use a swivel connector with a rachet. that was the easiest way to get it out.
I will be replacing the following items for this job:
1. abs pump Motor
2. Accumulator
3. MC piston kit.
To same money, for the pump motor # 1, I'm sending the unit to Eurton Electric for a rewind/rebuilt for around 265.
For the new OEM Accumulator(200 ish) and the OEM MC Piston kit(60ish), you can buy OEM from eBay. you save some money by buying them from United Emirates and shipping seems as fast as in the states. I ordered them on Sat and delivery is Wednesday.
I am hoping that this will fix my issue.
hsu4runner is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 11:48 PM #35
carolinatlc carolinatlc is offline
carolinatlc is on a distinguished road
1. abs pump Motor
2. Accumulator
3. MC piston kit.
What year is your 4Runner? Just bought my son a 2004 sport V8 and need to do this. Have part numbers for accumulator and MC kit and where you bought?
carolinatlc is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 09:32 AM #36
I have 2004 V6 SR5.
The part number for my vehicle for the accumulator is 47950-30010, the seller on ebay goes by triplecreations
The part number for my vehicle for the piston kit is 04493-60350, the seller on ebay goes by Partslane.
You'll want to verify for your vehicle for these parts online before ordering though
Old 12-15-2019, 09:19 PM #37
2Runner2Patagonia's Avatar
2Runner2Patagonia 2Runner2Patagonia is offline
2Runner2Patagonia is on a distinguished road
Hi all - I'm currently on a big road trip from California to Patagonia and this happened to me in Panama. I have a 2003 LTD 2WD with 181,000 miles. I just want to check to see if any of the posters here have come to a final resolution of this problem. I will be reunited with my car in Cartagena tomorrow and hoping to find the best/cheapest solution so I can continue my journey. Thanks!!
2Runner2Patagonia is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 10:37 AM #38
OBTone OBTone is offline
OBTone is on a distinguished road
ABS pump motor
I also have a 04 4Runner that had similar issue at 180k. Hard pedal, all lights on and continuous beep! The ABS motor is on the bottom of the master cylinder. It has two electrical connections and two allen head bolts. Itís not real fun to get out but with some creative tool combos you can get it out. Send the motor to...
Toyota 4 Runner 4705035010 ABS Motor Repair | Motor Repair & Rewinds | Eurton Electric
Motor was repaired for around $300 with shipping and my pedal has pressure again.
OBTone is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 07:17 PM #39
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
How long was the turn around time from when you sent your motor to them and got it back?
2004 Limited V8
Old 06-24-2022, 07:52 PM #40
Cruisertaz Cruisertaz is offline
Cruisertaz is on a distinguished road
Brake problems
I have an 04 4runner abs brake problem. The motor runís like it suppose to but the fluid seams to be going back in the reservoir after it sits for a while. Could it be the accumulator leaking. Need some help with this.
Cruisertaz is offline   Reply With QuoteReply With Quote
brake , home , lights , normal , vehicle
ABS/VSC TRAC/Brake Lights and Audible Alarm T4Rfirefighter 3rd gen T4Rs 11 10-30-2017 03:31 PM
ABS, VSC Trac, and Brake idiot lights on, audible alarm. What gives? Kardolf 4th Gen T4Rs 5 09-11-2015 02:48 PM
VSC Trac light + continuous beep Laotian Commotion 4th Gen T4Rs 1 10-08-2014 12:50 AM
'check engine', 'trac off', and 'vsc' lights came on. Plus 'abs' and 'brake' lights thehadley4 3rd gen T4Rs 0 10-23-2011 01:51 PM
VSC TRAC, TRAC OFF, ABS and BRAKE lights ENRIQUE Problems & Warranty Issues 3 02-03-2011 10:57 PM
