I just picked this up at the BAMF/Pelfreybilt garage sale.
Pelfreybilt Inventory
Pelfreybilt Installation Instructions | Tacoma World No help to me what so ever but maybe useful for someone else.
Pelfreybilt Steel plate winch bumper (sans hoops)
w/ 20" recessed LED light bar cut out
w/ 3" recessed fog light mount
Mocked it up for fitment and found my first curveball. The hood wont close due to interference with the grill and the top of the bumper. Apparently there were two versions built for this model, 03-05 & 06-09. I either got the former or it was an engineering oversight. I only say that because the best that I could tell, when the model refresh came out (2006) Toyota put the blinkers in with the headlights. This bumper doesn't have provisions for blinkers.
So I considered my options.
Option 1: Trim for clearance.
Option 2: Lower the whole bumper. This would create an 1.25" gap at the headlights and fenders.
Option 3: Grill swap? I wasn't even sure if this would be a direct fit or create some other problem.
I chose option 1 and got to cutting. I scribed a line with a 1/4" gap in front of the grill. Then got out the cutoff wheel and started throwing sparks.
With the clearancing done I refit the bumper and checked out the progress. Success! (forgot to take the success pic) The hood closed perfectly and gave a small tolerance for shimmy and bumps to keep from chaffing. So I popped the hood to remove the bumper and found my next curveball. Can't reach the hood release lever! Now that the hood closes all the way the grill drops below the bumper.
After a couple of moments, some cussing, two adult beverages of inspiration, I think I found a work around. The little finger release lever has a connecting rod that reaches up to the release mechanism. So I can either drill a little hole in the finger lever and run a rigid wire with a finger loop up to another hole in the grill or I could run a rigid wire down from the release mech to another opening in the grill. Either way, not a big deal.
Yet another curveball. The A/C line runs up from the frame on the driver side, makes contact with the winch mount plate and then goes horizontal towards the passenger side directly in the path of the winch footprint. As well as the transmission cooling line ( I believe it's the tranny line anyway). I thing I can massage the A/C line with a tubing bender. The tranny line has soft lines attached to a rigid line that I think I can relocate as well.
Lastly, powder coat This being the "Wifey Rig" I must defer to her feedback for this. She had previously stated that she didn't want" some hitios beefy thing hanging off of the front end" (her words). Rather she prefered "sexy yet functional" ( I had an image of cowgirl boots and denim shorts in my head and said "that works"). I've normally just gone with black powder coat or black paint or even bed liner.
After talking around with powder coat shops they suggested matching it as opposed to using a generic white so I found this. Prismatic Powders, RAL 9003, "Pearl White". From what I can tell this matches the Toyota "Natural White" (paint code 056) as closely as one can without doing a special order.
A few questions for anyone out there who has ventured down this path ahead of me.
1. Have you had any powder coat work matched to your white rig (056, Natural White)? If so, what was the powder coat color & brand & code.
2. Anyone else mount up a Pelfreybilt to a 06-09 with the same grill issues?
3. Did you have issues with the lines interfering with your winch? If so,what did you do about it?
Thanks in advance for your help guys and gals. This place has been an excellent resource for my inspirations on future mods and I'm looking forward to your feed back.
