Old 03-07-2019, 10:54 PM #16
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Originally Posted by gaber6 View Post
All fixed!
There were a few issues.
1. Sub-par, generic waterpump gasket. The OEM has a metal, layered gasket with a bevel that mashes down to create the seal. The gasket that came with the pump had a flat layered gasket with rubber/plastic.
2. My torque on the 12mm bolts must not have been enough, or I didn't go back over the bolts enough times with the torque.
The failure was created from incorrectly torqued bolts alloweing the heat/steam pressure to push the rubber gasket material away from the mating surfaces.
I'm 41 and still learning lessons from saving $10 on a generic gasket and paying down the road.
Good outcome, and lesson learned on cheap parts. Can't beat the multi-layer steel gasket that Toyota/Aisin use, and torquing the bolts incrementally to spec in symmetric pattern as AuSeeker described...just a figure 8 from inner to outer bolts.
waypoint is offline   Reply With QuoteReply With Quote
10mm , bolts , gasket , supposed , waterpump
How much is too much to replace waterpump and radiator? az4runner02 4th Gen T4Rs 10 12-20-2016 11:21 PM
97 SR5 waterpump ? redagain 3rd gen T4Rs 4 04-01-2015 01:25 PM
timing belt and waterpump dave04v6 4th Gen T4Rs 1 07-31-2012 08:44 PM
Waterpump&Timing Belt Steve8v92 Classic T4Rs 0 03-11-2009 04:28 AM
Is '06 V6 oil plug supposed to have a gasket? sbbamafan 4th Gen T4Rs 8 06-04-2007 10:52 PM
